virgo 3.6.2 java.lang.NoClassDefFoundError: javax/servlet/Servlet [message #1100542] |
Tue, 03 September 2013 08:27 |
Hi Everyone,
I met a strange issue in the virgo 3.6.2. however, this issue can't show in 3.5.0. it is great if someone can give me some suggestions. the issue occur in the spring beans init in the blurprint. the log message is as following:
[2013-09-02 15:26:16.937] ERROR region-dm-14 org.eclipse.virgo.medic.eventlog.default AG0000E Application context creation failure for bundle 'com.hp.atom.wssupport' version '3.1.0.SNAPSHOT'. org.springframework.beans.factory.BeanCreationException: Error creating bean with name '.org.eclipse.gemini.blueprint.service.importer.support.OsgiServiceCollectionProxyFactoryBean#0': FactoryBean threw exception on object creation; nested exception is java.lang.NoClassDefFoundError: javax/servlet/Servlet
at org.springframework.beans.factory.support.FactoryBeanRegistrySupport.doGetObjectFromFactoryBean(FactoryBeanRegistrySupport.java:149)
at org.springframework.beans.factory.support.FactoryBeanRegistrySupport.getObjectFromFactoryBean(FactoryBeanRegistrySupport.java:102)
at org.springframework.beans.factory.support.AbstractBeanFactory.getObjectForBeanInstance(AbstractBeanFactory.java:1441)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:248)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:581)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:60)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:325)
at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:290)
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:137)
at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.lang.NoClassDefFoundError: javax/servlet/Servlet
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2427)
at java.lang.Class.privateGetPublicMethods(Class.java:2547)
at java.lang.Class.privateGetPublicMethods(Class.java:2557)
at java.lang.Class.getMethods(Class.java:1410)
at org.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:413)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateUsingFactoryMethod(AbstractAutowireCapableBeanFactory.java:1015)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:911)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:284)
at org.eclipse.gemini.blueprint.config.internal.adapter.OsgiServiceLifecycleListenerAdapter.retrieveTarget(OsgiServiceLifecycleListenerAdapter.java:96)
at org.eclipse.gemini.blueprint.config.internal.adapter.OsgiServiceLifecycleListenerAdapter.unbind(OsgiServiceLifecycleListenerAdapter.java:278)
at org.eclipse.gemini.blueprint.service.importer.support.internal.util.OsgiServiceBindingUtils.callListenersUnbind(OsgiServiceBindingUtils.java:67)
at org.eclipse.gemini.blueprint.service.importer.support.internal.collection.OsgiServiceCollection.afterPropertiesSet(OsgiServiceCollection.java:328)
at org.eclipse.gemini.blueprint.service.importer.support.OsgiServiceCollectionProxyFactoryBean$1.run(OsgiServiceCollectionProxyFactoryBean.java:211)
at org.eclipse.gemini.blueprint.service.importer.support.AbstractServiceImporterProxyFactoryBean.getObject(AbstractServiceImporterProxyFactoryBean.java:103)
at org.springframework.beans.factory.support.FactoryBeanRegistrySupport.doGetObjectFromFactoryBean(FactoryBeanRegistrySupport.java:142)
... 15 common frames omitted
Caused by: java.lang.ClassNotFoundException: javax.servlet.Servlet
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
... 38 common frames omitted
however, I can load this class in the osgi console through the clhas and clload command. the javax.servlet packages info is as following:
osgi> packages javax.servlet
javax.servlet; version="2.6.0"<javax.servlet_3.0.0.v201112011016 [109]>
com.springsource.bsh_2.0.0.b4 [84] imports
com.springsource.org.codehaus.groovy_1.7.3 [96] imports
com.springsource.org.h2_1.0.71 [98] imports
javax.el_2.2.0.v201108011116 [107] imports
javax.servlet.jsp_2.2.0.v201112011158 [110] imports
javax.xml.rpc_1.1.0.v201005080400 [111] imports
org.eclipse.virgo.web.servlet.adapter_3.6.2.RELEASE [119] imports
org.springframework.orm_3.1.0.RELEASE [128] imports
org.springframework.web_3.1.0.RELEASE [131] imports
org.eclipse.gemini.web.core_2.2.2.RELEASE [133] imports
org.eclipse.gemini.web.tomcat_2.2.2.RELEASE [134] imports
org.eclipse.virgo.web.core_3.6.2.RELEASE [135] imports
org.eclipse.virgo.web.dm_3.6.2.RELEASE [136] imports
org.eclipse.virgo.web.servlet.adapter_3.6.2.RELEASE [138] imports
org.apache.catalina_7.0.35.v201302131125 [141] imports
org.apache.tomcat.api_7.0.35.v201302120746 [148] imports
osgi.enterprise_4.2.0.v201108120515 [151] imports
javax.servlet; version="3.0.0"<org.eclipse.virgo.web.servlet.adapter_3.6.2.RELEASE [119]>
javax.servlet; version="3.0.0"<org.eclipse.virgo.web.servlet.adapter_3.6.2.RELEASE [138]>
osgi> clhas javax.servlet.Servlet
Bundles containing [javax/servlet/Servlet.class]:
109 javax.servlet
/javax/servlet/Servlet.class
osgi> clload javax.servlet.Servlet
Successfully loaded [javax.servlet.Servlet] from:
133 org.eclipse.gemini.web.core
[provided by 109 javax.servlet]
240 org.apache.servicemix.specs.jsr311-api-1.1.1
215 com.jolbox.bonecp
211 com.hp.atom.jackrabbit-all
138 org.eclipse.virgo.web.servlet.adapter
180 com.hp.atom.management_client
192 com.hp.atom.repodumper
109 javax.servlet
107 javax.el
96 com.springsource.org.codehaus.groovy
175 com.hp.atom.wssupport
247 org.springframework.web.servlet
236 org.apache.santuario.xmlsec
237 org.apache.servicemix.bundles.opensaml
218 com.springsource.javax.servlet.jsp.jstl
98 com.springsource.org.h2
234 org.apache.cxf.bundle-minimal
203 com.hp.atom.ium_jars
193 com.hp.atom.raptor
128 org.springframework.orm
224 com.springsource.org.apache.commons.jxpath
136 org.eclipse.virgo.web.dm
167 com.hp.atom.persistence
156 com.hp.atom.classloader
204 com.hp.atom.repository_server
119 org.eclipse.virgo.web.servlet.adapter
134 org.eclipse.gemini.web.tomcat
141 org.apache.catalina
67 org.eclipse.osgi.services
110 javax.servlet.jsp
185 com.hp.atom.rule_engine
162 com.hp.atom.codec
233 org.apache.commons.configuration
242 org.jboss.netty
151 osgi.enterprise
84 com.springsource.bsh
179 com.hp.atom.central_management
111 javax.xml.rpc
148 org.apache.tomcat.api
131 org.springframework.web
135 org.eclipse.virgo.web.core
osgi>
the wssupport bundle's infomation as following:
osgi> b 175
com.hp.atom.wssupport_3.1.0.SNAPSHOT [175]
Id=175, Status=RESOLVED Data Root=C:\virgo-tomcat-server-3.6.2\work\org.eclipse.osgi\bundles\175\data
"No registered services."
No services in use.
Exported packages
com.hp.atom.wssupport.i18n; version="0.0.0"[exported]
Imported packages
javax.ws.rs; version="1.1.1"<org.apache.servicemix.specs.jsr311-api-1.1.1_1.9.0 [240]>
org.apache.cxf.jaxrs.provider.aegis; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.apache.cxf.helpers; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.apache.cxf.interceptor.security; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.apache.cxf.resource; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.xml.sax; version="0.0.0"<org.eclipse.osgi_3.8.1.v20120830-144521 [0]>
org.apache.cxf.phase; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.apache.cxf.transport.servlet; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.apache.cxf.aegis.databinding; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.springframework.core.io; version="3.1.0.RELEASE"<org.springframework.core_3.1.0.RELEASE [125]>
org.apache.cxf.io; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
javax.xml.parsers; version="0.0.0"<org.eclipse.osgi_3.8.1.v20120830-144521 [0]>
javax.security.auth; version="0.0.0"<org.eclipse.osgi_3.8.1.v20120830-144521 [0]>
org.w3c.dom; version="0.0.0"<org.eclipse.osgi_3.8.1.v20120830-144521 [0]>
com.hp.atom.kernel; version="0.0.0"<com.hp.atom.kernel_3.1.0.SNAPSHOT [154]>
org.apache.cxf.configuration.security; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.apache.cxf.aegis; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.springframework.jmx.export.annotation; version="3.1.0.RELEASE"<org.springframework.context_3.1.0.RELEASE [124]>
org.apache.cxf.common.security; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
javax.xml.transform.stream; version="0.0.0"<org.eclipse.osgi_3.8.1.v20120830-144521 [0]>
javax.xml.validation; version="0.0.0"<org.eclipse.osgi_3.8.1.v20120830-144521 [0]>
org.osgi.service.http; version="1.2.1"<stale>
org.apache.cxf.jaxrs.provider.json; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.apache.cxf.jaxrs.provider; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
javax.security.auth.login; version="0.0.0"<org.eclipse.osgi_3.8.1.v20120830-144521 [0]>
org.apache.cxf.frontend; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.apache.cxf.common.classloader; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
com.hp.atom.kernel.metadata; version="0.0.0"<com.hp.atom.kernel_3.1.0.SNAPSHOT [154]>
org.apache.cxf.jaxrs; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.apache.cxf.message; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.apache.cxf.jaxb; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
com.hp.atom.commons.context; version="0.0.0"<com.hp.atom.commons_3.1.0.SNAPSHOT [155]>
com.hp.atom.kernel.config; version="0.0.0"<com.hp.atom.kernel_3.1.0.SNAPSHOT [154]>
com.hp.atom.kernel.util; version="0.0.0"<com.hp.atom.kernel_3.1.0.SNAPSHOT [154]>
org.apache.cxf.jaxws; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
com.hp.atom.kernel.logging; version="0.0.0"<com.hp.atom.kernel_3.1.0.SNAPSHOT [154]>
org.osgi.service.blueprint.container; version="1.0.0"<org.eclipse.gemini.blueprint.core_1.0.2.RELEASE [75]>
org.apache.cxf.transport; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
com.hp.atom.commons.container; version="0.0.0"<com.hp.atom.commons_3.1.0.SNAPSHOT [155]>
com.hp.atom.kernel.i18n; version="0.0.0"<com.hp.atom.kernel_3.1.0.SNAPSHOT [154]>
javax.ws.rs.core; version="1.1.1"<org.apache.servicemix.specs.jsr311-api-1.1.1_1.9.0 [240]>
org.apache.cxf.interceptor; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
javax.security.auth.callback; version="0.0.0"<org.eclipse.osgi_3.8.1.v20120830-144521 [0]>
org.apache.cxf.service.factory; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.apache.cxf.transport.http; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.apache.cxf; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
com.hp.usage.i18n; version="0.0.0"<com.hp.atom.ium_jars_3.1.0.SNAPSHOT [203]>
org.apache.cxf.security; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.apache.cxf.databinding; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
com.hp.atom.commons.resource; version="0.0.0"<com.hp.atom.commons_3.1.0.SNAPSHOT [155]>
org.slf4j; version="1.7.2"<stale>
org.eclipse.gemini.blueprint.service; version="1.0.2.RELEASE"<org.eclipse.gemini.blueprint.core_1.0.2.RELEASE [75]>
org.apache.cxf.aegis.type; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
javax.xml.transform; version="0.0.0"<org.eclipse.osgi_3.8.1.v20120830-144521 [0]>
com.hp.atom.commons.wssupport; version="0.0.0"<com.hp.atom.commons_3.1.0.SNAPSHOT [155]>
org.apache.cxf.common.i18n; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
javax.xml.bind; version="2.0.0"<org.eclipse.osgi_3.8.1.v20120830-144521 [0]>
org.apache.cxf.endpoint; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
org.apache.cxf.transport.servlet.servicelist; version="2.6.2"<org.apache.cxf.bundle-minimal_2.6.2 [234]>
javax.servlet.http; version="2.6.0"<javax.servlet_3.0.0.v201112011016 [109]>
org.eclipse.gemini.blueprint.compendium.config; version="1.0.2.RELEASE"<org.eclipse.gemini.blueprint.core_1.0.2.RELEASE [75]>
org.eclipse.gemini.blueprint.blueprint.config; version="1.0.2.RELEASE"<org.eclipse.gemini.blueprint.core_1.0.2.RELEASE [75]>
org.eclipse.gemini.blueprint.config; version="1.0.2.RELEASE"<org.eclipse.gemini.blueprint.core_1.0.2.RELEASE [75]>
org.osgi.service.blueprint; version="[1.0.0,2.0.0)"<unwired><optional>
No fragment bundles
Named class space
com.hp.atom.wssupport; bundle-version="3.1.0.SNAPSHOT"[provided]
No required bundles
osgi>
the war bundle's structure is as following:
[Updated on: Thu, 05 September 2013 01:54] Report message to a moderator
FUDForum. Page generated in 0.04370 seconds
