Home » Archived » BIRT » D3 chart in BIRT(BIRT and D3 charts)
D3 chart in BIRT [message #1099872] Mon, 02 September 2013 06:27 Go to next message
As per BIRT 4.3 features list, it supports D3 reports now. Request you to give the working example as I am not able to get the Bubble chart example working.
gg
Re: D3 chart in BIRT [message #1100889 is a reply to message #1099872] Tue, 03 September 2013 14:57 Go to previous messageGo to next message
Can you attach a report showing what you've got so far? A sample I can run preferrably. Smile Thanks!
[Updated on: Tue, 03 September 2013 14:58] by Moderator
Re: D3 chart in BIRT [message #1101169 is a reply to message #1099872] Wed, 04 September 2013 01:04 Go to previous messageGo to next message
I am trying to print "Hello World!" using D3 to start with. But I want to implement the bar chart and bubble chart (as shown in new features doc of BIRT 4.3)
The code is not returning to callback function when I am using headjs. Also in other example (trial2),its not executing the D3 code.
PFA sample code and d3 snippet.
gg
Re: D3 chart in BIRT [message #1102643 is a reply to message #1099872] Thu, 05 September 2013 20:33 Go to previous messageGo to next message
Grabbing the body only seems to work when running in preview in a browser. If you create your own div to append "Hello World" to, it works. The text box code looks like this:
<script>
head.ready(
function ()
alert("entering head.ready")
div1 = document.getElementById("mydiv");
d3.select(div1)
.append("p")
.text("Hello World!");
</script>
<div id="mydiv" />
This works in all of the html outputs. I also moved the css url to a style in the outline. Attached is the working report.
Re: D3 chart in BIRT [message #1104069 is a reply to message #1102643] Sat, 07 September 2013 16:37 Go to previous messageGo to next message
But we need to integrate d3 chart in BIRT I tried in BIRT4.3
with this code but .style is not working can you please check
var dataset = [ 5, 10, 15, 20, 25 ];
d3.select("body").selectAll("div")
.data(dataset) // <-- The answer is here!
.enter()
.append("div")
.attr("class", "bar")
.style("height", function(d) {
var barHeight = d * 5;
return barHeight + "px";
Re: D3 chart in BIRT [message #1104071 is a reply to message #1099872] Sat, 07 September 2013 16:39 Go to previous messageGo to next message
This script is not working in BIRT4.3
var dataset = [ 25, 7, 5, 26, 11 ];
.enter()
.append("div")
Re: D3 chart in BIRT [message #1106446 is a reply to message #1104071] Wed, 11 September 2013 01:33 Go to previous messageGo to next message
I also don't see this showing as it should. Let me test a little on this and I'll let you know if I get it working.
Re: D3 chart in BIRT [message #1106449 is a reply to message #1106446] Wed, 11 September 2013 01:38 Go to previous messageGo to next message
Thanks and could you please provide sample a rpt design for D3 chart which would be very helpful.
Re: D3 chart in BIRT [message #1106646 is a reply to message #1106449] Wed, 11 September 2013 07:09 Go to previous messageGo to next message
Hi Michael, I have created a a simple d3 chart, with a circle,and appended text "Hello world" to it, but when I download it in any format(pdf,etc), the circle and the text is not coming in the downloaded file. The file is empty. Can you please take a look on this. Thanks.
Re: D3 chart in BIRT [message #1106656 is a reply to message #1099872] Wed, 11 September 2013 07:22 Go to previous messageGo to next message
Hi Michel How to get the data from .csv or .tsv file in D3. I have attached RPT please help . I am also facing Same problem while downloading PDF or Excel
Re: D3 chart in BIRT [message #1106838 is a reply to message #1106656] Wed, 11 September 2013 12:06 Go to previous messageGo to next message
Rahul,
Unfortunately any non html output will not have the client side content.
Re: D3 chart in BIRT [message #1106848 is a reply to message #1106838] Wed, 11 September 2013 12:23 Go to previous messageGo to next message
Padmasridhar,
You should be able to bind the text box to the dataSet you're wanting to use, then use <value-of> tags to call your data from the dataSet and store that to a variable in your script. Hope this helps.
Re: D3 chart in BIRT [message #1107427 is a reply to message #1099872] Thu, 12 September 2013 07:31 Go to previous messageGo to next message
Hi Michael, I have successfully got D3 charts working in BIRT viewer. But have a small issue, the style tags used in HTML are not rendering or getting applied. What can I do to get them working.
Re: D3 chart in BIRT [message #1107680 is a reply to message #1107427] Thu, 12 September 2013 15:39 Go to previous messageGo to next message
Can you attach your working example with style tags so I can see the issue? Thanks!
Re: D3 chart in BIRT [message #1107931 is a reply to message #1107680] Fri, 13 September 2013 01:09 Go to previous messageGo to next message
Hi I have attached pie chart with style tags and data.csv
  • Attachment: pie.rptdesign
    (Size: 5.00KB, Downloaded 592 times)
  • Attachment: data.tsv
    (Size: 0.07KB, Downloaded 413 times)
Re: D3 chart in BIRT [message #1108055 is a reply to message #1107931] Fri, 13 September 2013 05:14 Go to previous messageGo to next message
Thanks D3 working fine now with <style> tag .Not able to download as pdf
[Updated on: Fri, 13 September 2013 05:43] by Moderator
Re: D3 chart in BIRT [message #1108581 is a reply to message #1108055] Fri, 13 September 2013 23:04 Go to previous messageGo to next message
So, everything is working as expected now? The PDF won't work because of the d3 charts being done on the client side. Let me know if everything other than that is working.
Re: D3 chart in BIRT [message #1108962 is a reply to message #1108581] Sat, 14 September 2013 13:44 Go to previous messageGo to next message
HI
I have doubt in D3 instead of taking data from csv or tsv file is it possible to get data from dataset
Re: D3 chart in BIRT [message #1111362 is a reply to message #1108962] Wed, 18 September 2013 01:33 Go to previous messageGo to next message
Let me take a look at your design from above to see what you've done with the TSV. I'll let you know.
Re: D3 chart in BIRT [message #1111395 is a reply to message #1111362] Wed, 18 September 2013 02:42 Go to previous messageGo to next message
Hi i tried circular heat chart but its not coming .i dont know where i did mistake please help in this
Re: D3 chart in BIRT [message #1111834 is a reply to message #1111395] Wed, 18 September 2013 16:07 Go to previous messageGo to next message
Still having issues bringing in data from a dataSet? Or having issues just creating the circular heat chart? Let me know.
Re: D3 chart in BIRT [message #1112032 is a reply to message #1111834] Wed, 18 September 2013 23:30 Go to previous messageGo to next message
yes i am having both issues i am not able to get data from dataset and circular chart
Re: D3 chart in BIRT [message #1113119 is a reply to message #1112032] Fri, 20 September 2013 13:18 Go to previous messageGo to next message
Okay. Let me take a look at the report. I'll post if I get it working.
Re: D3 chart in BIRT [message #1220535 is a reply to message #1107427] Thu, 12 December 2013 07:18 Go to previous messageGo to next message
I am essentially trying to do the same and stuck , using D3 with BIRT. I tried your sample pie report, but do not see the graphics. Can you please give some pointers on how to get this working?
Re: D3 chart in BIRT [message #1692547 is a reply to message #1102643] Thu, 16 April 2015 08:25 Go to previous messageGo to next message
Hi Williams,
I am new to the BIRT. I want to integrate BIRT with D3 Chart. Could you please help me how to do . I am using Eclipse BIRT 4.4.1 with Apache 7 for generating report. I am fetching the Data from external API using XML data source. Please guide me how to do. I want to view my report in all types of browser.
Thanks $ Regards:
kshirod Mishra
Re: D3 chart in BIRT [message #1692553 is a reply to message #1108055] Thu, 16 April 2015 08:57 Go to previous messageGo to next message
Hi Padma,
I am new to the BIRT. I want to integrate BIRT with D3 Chart. Could you please help me how to do . I am using Eclipse BIRT 4.4.1 with Apache 7 for generating report. I am fetching the Data from external API using XML data source. Please guide me how to do step-by-step with exmaple of D3. Say: I want to fetch the data from using xml datasource and i want to prepare a Dashboard. I want to view my report in all types of browser. Please help me
Re: D3 chart in BIRT [message #1693358 is a reply to message #1100889] Thu, 23 April 2015 09:03 Go to previous messageGo to next message
Hi William,
I am using Eclipse BIRT 4.4.1 . I want to integrate BIRT with other java script chart like D3 chart , AMcharts and Zing Chart also. I am using XML data source for getting the data to my BIRT report. Please guide me how to solve the issue.
Thanks & Regards:
kshirod Mishra
Re: D3 chart in BIRT [message #1693359 is a reply to message #1107427] Thu, 23 April 2015 09:05 Go to previous message
Hi Padma,
Could you please guide me how to inegrate BIRT with D3.
Thanks & Regards:
kshirod
Previous Topic:Birt Viewer DataException
Next Topic:BIRT 4.2.2 blank PDF pages
Current Time: Sat Jul 05 03:25:24 EDT 2025
Powered by FUDForum. Page generated in 0.10996 seconds
