Home » Modeling » GMF (Graphical Modeling Framework) » intermittent missing or disappearing svg
intermittent missing or disappearing svg [message #164787] |
Fri, 07 December 2007 15:05  |
Originally posted by: jacob.barde.swri.org
--------------000308070908000107080805
During different builds (eclipse product builds), I experience problems
with the display of SVG figures. It affects one or two of the SVG
files, so any figure based on a particular file is affected. As for
which SVG file, it's usually only one or two, but it's pretty random at
which SVG files will be affected.
Typically, when opening a diagram, the diagram is rendered and then: the
affected figures will show briefly and then disappear; or those affected
figures will not even show (or perhaps it shows/disappears too quickly
for me to see). I've check the log, but there aren't any error messages.
Sometimes a restart of the product will fix the problem, other times, not.
Sometimes the deletion of the
workspace\.metadata\.plugins\org.eclipse.core.resources\.his tory
and
workspace\.metadata\.plugins\org.eclipse.core.resources\.roo t
and a restart will clear up the problem (and I don't much care for this
method).
Or at least these solutions will clear up the problem temporarily, as it
seems the more you work with diagrams, eventually you may have a problem
the next time you start the product (that's what my test users tell me).
This particular behavior makes me think that if GMF caches the svg,
perhaps the cached file is getting corrupted or moved, but that's just a
guess on my part.
Snapshot of missing_pipe.jpg is supposed to have the figure pictured in
PIPE.jpg where the selected figure shape is.
The SVG images are exports from Visio (which makes me skeptical as MS
has been known to perverse exports to standards-based formats).
Has anyone else experienced this problem (see attached images)? Perhaps
found a solution or reason for this behavior?
Jacob
Content-Type: image/jpeg;
name="missing_pipe.jpg"
Content-Disposition: inline;
filename="missing_pipe.jpg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEB
AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEB AQEBAQEBAQEB
AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQH/wAAR
CAAvAM4DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+/iqaNEdQukFpIk62di0l +bdViuYnn1EQ
2iXQO+aSydJ5pbdhttl1CGRCTdvgXTtPSK7gSxs0g1CS4mv4VtoFivZbtQl1 LdxhAlzJcoAl
w8yu0ygLIWHFfh1/wUkm1f4w/ts/sU/sS6/8aviN8CP2bPE/wV/aW/aN+LU3 wZ+I2qfBDxh4
61n4O698Efh38NfA9/8AFrwtqGi+L/CPgO3ufi9rWqatpHhPW9Cn8T6jb6Lp t/eSWdvFb1Mp
KEXJ3sleyV2/RdWH9fefujRX8+//AA7E/YI/6Ok/a8/8Wk/tYf8Az+6jf/gm V+wFE9pHJ+1T
+1xHJqGpaVo1hG//AAVM/auR73WNd1K00bRNKtEb4+BrnUtZ1i/sdJ0qxhD3 Wo6le2ljaRTX
VxDE+P1lf8+q/wD4L9PPz/rS65l/TXl5/wBW9L/0AO0Q1C1Q2kjztZ3zR34t 1aK2iSfThNaP
dE74ZL13gmit1G25XT5pHINomblfhD+zj8PrT9jD/gpF8PP2VvBnxi/aV+Jf wf8A2if2W/it
8YbL4a/tB/GXxb+0F4e+G3j/AOAPxB+G+jz+NvAnjD4uav4q+I3hXU/EumfF m20y+8M6Tr3/
AAil8bO61u5tLfVrTTi/7rfZLT7X9v8As1v9u+z/AGT7Z5Mf2v7J5nnfZvtG 3zvs/nfvfJ3+
X5nz7d3NawmqkIzje0ldX33tra/buMsVTumiWfThJaSXLveOsEyW6zLp8o0+ +c3c0jHNpG8C
TWAuEyzS3sVqRsuXIF07T0iu4EsbNINQkuJr+FbaBYr2W7UJdS3cYQJcyXKA JcPMrtMoCyFh
xVe506JxpEEVjpb2Wn3kU3k3NsrCyitLK6Syl0iNUMVteW12bNIn2osNkbpY isvlCrA1KKr/
AGS0+1/b/s1v9u+z/ZPtnkx/a/snmed9m+0bfO+z+d+98nf5fmfPt3c1Guna ekV3AljZpBqE
lxNfwrbQLFey3ahLqW7jCBLmS5QBLh5ldplAWQsOKAC+aJIEM1pJeobzTlEM VutyySvqFqkF
2Y3ICx6fO0d/NcD5rSK2e6QF4VFXKy7zTontbGC2sdLcafeaZNZw3lsrWtlF aXEKSy2McaEW
15bacblNMeJUWG4MKsVg8wVc+yWn2v7f9mt/t32f7J9s8mP7X9k8zzvs32jb 532fzv3vk7/L
8z59u7mgCxVPUWiTT7557STUIEs7pprCG3W7lvYlgcyWkVq5CXMlygMKW7kL MziNjhjQunae
kV3AljZpBqElxNfwrbQLFey3ahLqW7jCBLmS5QBLh5ldplAWQsOKr32nRPp6 wWdjpbz6fGJt
EhvrZW0+y1C0gdNNlWOJC9tHbOVQPaKk8MBdbcqcCgDUorP/ALJ0r7B/ZX9m af8A2Z/0DvsV
t9g/132n/jz8v7P/AMfH7/8A1f8Arv3v3/mqxJaWk09tdTW1vLdWfnfZLmSG N57X7QgjuPs0
zKZIPPjAjm8pl81AFfcoAoAsVT05on0+xeC0k0+B7O1aGwmt1tJbKJoEMdpL aoSltJbIRC9u
hKwshjU4UVJHaWkM9zdQ21vFdXnk/a7mOGNJ7r7Ohjt/tMyqJJ/IjJjh81m8 pCVTapIrPtNJ
tP7GttKv9M0fyfs8P2zTrSyj/sb7XuW5uPs1nNHt+z/bt88Pmx+Zu2yv++y1 AGxRVeS0tJp7
a6mtreW6s/O+yXMkMbz2v2hBHcfZpmUyQefGBHN5TL5qAK+5QBRHaWkM9zdQ 21vFdXnk/a7m
OGNJ7r7Ohjt/tMyqJJ/IjJjh81m8pCVTapIoAjsWieBzDaSWSC81FTDLbrbM 8qahdJPdiNCQ
0eoTrJfw3B+a7iuUunAeZhXwb/wVY+Fvjr42f8E0/wBu/wCFHwx8Pah4u+If jz9lT43aB4L8
J6RA93rHijxLdeAtabSfDmjWkYMl5rOuXkcWl6TZoN11qN1bW4IMmR9zW2k2 n9mNpV5pmj/Y
ftF3s062so/7M+yf2jNc2G6zlj8n7R5P2ee7xH5f9o+dLD8uxq0JLS0mntrq a2t5bqz877Jc
yQxvPa/aEEdx9mmZTJB58YEc3lMvmoAr7lAFAH+a5+0F/wAFFPFtt+1X4g+I 37Mfj/4NXfwX
8VfF/wCCPxn8V2Xiv9p/9kb4ReL/ABrYaF+wx+yn+zr4y+EPjv4afHD49fDX 4n/D3W/BXi34
W/E7TNV0vxV4OtGTxVb+G/Eunx3cGhaVe3f9LX/BP/8A4Kjf8E2Pgj+wr+xl 8G/iZ+3T+yR4
T+JXwn/ZP/Zv+GnxF0D/AIX58LdZ/srx14B+Cvgbwl4r0w6x4a8TaxomrnR9 c0e90b+09N1K
+06+GnC50u8vdKksb24/of1L4c/D3Wb241LV/Ang3VdRu2D3Woal4X0S+vbl 1RY1e4urqxln
mZURUDSSMQiqoOAAP4//ANjD/gr18J/j/wD8F3fjV8D4YPD+pfsmfFnRr39n P4GaHqvhrwRP
4D0r4t/ALxF41bSPif4EvbLT4ok0b4/Rf8JVb/bL6zHiPxXqWv8Awv0G61Cf RvBXha2P6Hk/
B3GHiRwxnFTh3hrC4zLPB/g/F8RcR4/J8ro0Mxp8OYjiPDUq+Z59iqP77NJY HGZ3aGMxSlPB
ZVS+rqpHCYLD0qfFUrYfB1qUatdxlj8RGjRhUnJwdWNF2p0k3aHNCk3yqylU fNZylJv6y/4K
Z/8ABTP9gr9o79gr9qb9nD9nD9qb4Q/tC/tAftC/CHxX8Efgv8F/gj4rsPiZ 8SfiF8SfiZYS
eFPCugaB4V8KSajqUyzalqMU2o6jNFDpuk6bDdahqF1BBAzH+lbwJo134d8D +DfD+oeV9v0L
wp4e0a98l/Mh+16ZpFnZXPlSYXfF50D+W+0blw2BnFM0jwB4E0C9j1LQvBXh LRNRiWRIr/SP
DejabexpKjRypHdWdlDOiyxs0cirIA6MysCpIrpY7S0hnubqG2t4rq88n7Xc xwxpPdfZ0Mdv
9pmVRJP5EZMcPms3lISqbVJFfm9GjGjFxi27u7btvZLp6HaWK/Bv9t7/AJTE /sCf9mg/tOf+
tSfsL1+8lfhn+2ToNxrn/BY/9gPT49TtdBuNT/Ys/bTl0DUdSsWv7O91rwf8 bf2MPGkumQ2K
6lo8uqTCy0kTXtnZ6jBdW2nySXxKxREm5SUEpy0jCUJSdm7RjOLbstXZJvQm abi0t2rH6eV8
9/tP6Xput/C3TtG1nT7LVtI1b40/sy6dqml6lawX2nalp97+0p8Jba8sb+yu Ultruzu7eSSC
5tp45IZ4XeORGRiD69/wjvxM/wCh08C/+G21/wD+epXAfEv4P/EX4l+GLfwv cfFLw94Zij8Z
fDbxY2teHfhncPrtq3w8+I3hX4gxx6Q3iD4ga7odtqF9J4YTT7W+1fQde07T 5bpb670LWoLd
9MuvblnWWuMl7aTunp7GrrptrBLXbV2PLWErpp8qVmteZaa+p+Pv7AXxZ+JP xk/a/wD+CcPj
b4hQxeLdY1L9kD/gpHour/EW+0Z5tb06L4dftaeAPh74F8Mt4kjwkY1vwdoU cmsLqbXWueMr
7wNZeINRv73UdL1W8uf6d6/Arxj4I8SfCL/gpd+yV4Q/ZT8LfCe8vfh7+wZ+ 1vN4e+A3jL4q
eIvhD4W1+98SfGj9nmRfG/ijxB4U+GXxo1+xtLS5bxrNrPj+f4b+L9X1Dxx4 zgsrzzLvxrre
t2f3t/wsb/gqb/0Zv+wB/wCLLP2iv/pTtfM5dTqUsDhKVWq69WnQhTq15JqV apBcs6sk3Jp1
JJzacpNN7vc+u4ix+AzXiDPc0yrLaeTZZmWcZnj8tyik4OllWAxmNr4jB5bS dOFKm6eBw9Sn
hYOFOnBxpLlhCNor7/r+fn/goD/wXG/4Yi/4KpfsQf8ABNX/AIZjuPiV/wAN a3H7Olx/wuaH
44/8INH4F/4aD/aA8d/s8eRd/Db/AIVD4u/4TO38If8ACN/8JqsX/Ce+F/7d u7i20fdo39n/
ANr3fnv/AAWh/aC/4Kv/AA0/4Jv/AB28Y6P8KP2bv2btU0/xT+zfp9j8Z/2c /wDgoH8bPGnx
h8H3HiP9qT4K+Go4vC3hnxT/AME/vgH4b1Oy8TnWP+EP8XjXfiz4U0q08E6/ 4jv74a/b2snh
nWfjH4IfEH/g58+KfxD/AOCTvj7SrjxDefsxeItJ+F0//BQu78V/D79jX4W+ IbqOz/bh+N2m
fE651PwT8VPCngn43adNP+x7ZfCWVNS+Cvhqx0HxPA8Xin4V3Gq65rUusX/2 a4Yqy4NqcZrN
+H1QpcTUuGJZDPOMHDiqdWvlVbNYZvh8glUWPxHD9KGHqYLGZxSpPB4LMauB wVepGtj8NGXg
+3X1hYf2dW7ouv7VU5OgkqipunKrbljVfMpRpt80oKckrQlb+hf/AIbI/aK/ 6RO/t/8A/hxv
+CWX/wBMso/4bI/aK/6RO/t//wDhxv8Agll/9Msr7/or5k2P5mf+Ctv/AAcI +NP+CXPhH9mr
XfHX/BN/40W2r/tC+KPjZp1v4J+MP7RfwC+Gvi7Q9O+BUHwI1iHxNZX37Oep /tp+Cdf8L+Or
n4vXnh42WqeMPB/irS5/BOuC+8Ny6Rruh6tP+w/iz9q/48+HPFXibw9o/wDw TJ/bf8e6RoPi
DWdG0vx14T8ff8E27Pwr4007S9RubGx8WeGbPx1/wUG8F+NrXw/4jtoItY0a 28Y+DvCfiqDT
ry2i8Q+GdC1dbzS7X7Xurj7NGsnkXFxuuLS38u2i82Rftd3Da+ey7lxb23nf abuXP7m1imm2
t5e02KAPgD/hsj9or/pE7+3/AP8Ahxv+CWX/ANMsr8+P+Cof/Bbf4i/8E4v2 TrP9o3x//wAE
2/2iPDv/AAkXx48A/ATSfCfxo+PP7LHw+u9d/wCFg/Db43eOr/xf4N8U/s0f E/8AbX2XHgf/
AIVFZabqukeNfD/gb7bJ450bUfDmq61/YuvWVp/QNX5A/wDBav8A4ew/8Mse Af8Ahzp/yc1/
w0B4V/4Tn/k23/khP/Cuvir/AMJN/wAnR/8AFv8A/koH/Csf+QP/AMVj/wBA /wD4kv8AwkNA
H3/+yd8dP+GoP2WP2af2l/8AhFv+EH/4aI/Z/wDg38dP+EK/tv8A4Sb/AIQ/ /hbfw68OeP8A
/hFv+Ej/ALI8P/8ACQf8I/8A8JB/ZP8Abf8AYOif2r9k+3/2Rpv2j7HD7/X5 gfCD9uG++D/w
T+A3w6/bQ8Fftf6v+114d/Z/+BH/AA01qHwt/wCCe37ZPxx8CXHx21f4ReDN d+KX9hfFL9lH
9mn4gfs5eKPK8Z6nrEGp/wDCoPF2r+DtE1iLUPDtl9gm0i40yy9A/wCHln7O v/ROf2//APxU
7/wVN/8AoN6APv8AqnpyxJp9ikF3JqECWdqsN/NcLdy3sSwII7uW6QBLmS5Q CZ7hAFmZzIow
wr4M/wCHln7Ov/ROf2//APxU7/wVN/8AoN6km/4KN/s8aRLLpMvwy/bztZdL kfTpLbTv+CVn
/BTbVNPt3smNs8Fjqfh/9kTUtB1GzhaIx21/omo3+kXkCpcabe3VlJDPIAff dFfAH/Dyz9nX
/onP7f8A/wCKnf8Agqb/APQb0f8ADyz9nX/onP7f/wD4qd/4Km//AEG9AH3n YrEkDiG7kvUN
5qLGaW4W5ZJX1C6ee0EiABY9PnaSwhtz81pFbJauS8LGrlfAkv8AwUb/AGeN LYW0nwy/bzt2
ljh1ER2P/BKz/gptqMDJq8SatFO9xon7Il/ZR3l1Fepc6jYTTx6vpeoTXWme ILLTdes9S061
j/4eWfs6/wDROf2//wDxU7/wVN/+g3oA+/6/D34H/wDBP79grwj/AMFXP2ob 3wj+xn+yZoV9
8Nf2Tv8AgnJ8Xvh7JoX7O/wa0yb4XfFvXPjz/wAFIotZ+IXgJtM8GW03gnx9 rdv8OPhxe6t4
s0R7DxNqUnhLwlc3epzR6DoQsfsP/h5Z+zr/ANE5/b//APFTv/BU3/6DeuF/ Za8Yw/GT9vX9
rj47+FPhz8cvCXwv8U/sffsDfDvQfFPxq/Zz+Ov7OFz4r8c/Df42f8FItY8c 6VpPhr4+/Dr4
Z+MNTuvCmh/Eb4eTatP/AGD5dvYeJfDs6Svp+p6XPcgH6c0UUUAU1sYEiu4Q 94UvZLiWZm1H
UHlRrlQkgtJ3uWn0+NQM28NhJbRWjZe1SFyWr5l/aT/Y4+Af7W+i+H/Dvx18 CxeI4/Ab3Wpf
DDxzoniLxV4O+L3wz8R6zpOo+HvEWueAPip4T1bRvHPg3UdS0KeytJ9Q0DxB aXWoSRedqZuZ
bLTZYPqaq62+27muvPuG863trf7M0ubWL7NJdyefDDt/d3Fx9r8u6l3HzY7a 0Xavk5YA/Jf/
AIcsfsi/2B/wjX/Cw/23v7O/tj+3PtP/AA3r+1n/AG/9t+xfYPI/4Sz/AIWt /wAJT/Y/kfvP
+Ee/tn+wPtv/ABMv7M/tH/SquT/8EZv2TLjUPDupyeP/ANtJbnwvZ6RY6bHB +3L+1Ha6fcwa
JObizfxFpNt8TYtK8X3k0jFdX1HxbZ63qHiCDFtr1zqVsqxD9ZKKnlj/ACx+ 5f10X3Csuy/r
/hl9x8N/s2/8E8f2ZP2UfH3jL4n/AAn8J+J7r4lfEiyisPHXxX+JXxX+KnxW +J+paRperDWN
B8E6T4l+IHi3xBJ4Y+GllfXepX03w88LLoXg6a/h0a5m0G4l020ktftz7NH9 r+2brjzvs/2b
Z9ru/svl+Z5u77B532H7Ru4+1/Z/tfl/ufO8n5KGt913DdefcL5NvdW/2ZZc Wsv2mS0k8+aH
b+8uLf7J5dtLuHlR3N2u1vOytiq22GU1sYEiu4Q94UvZLiWZm1HUHlRrlQkg tJ3uWn0+NQM2
8NhJbRWjZe1SFyWr8Cf29f8AghYv7bn/AAVI/Ym/4KUJ+1HJ8MU/Y5j/AGbo k+C03wYl8ey/
EVf2e/2iPGPx7Uy/E6f4v+Fp/DEni4eLB4UeabwP4ql0VtPPiCR9ce8OkW/9 AVV5rfzpLSTz
7iL7JcNceXDL5cdzutbq18i7XafOt1+0/aViyuLu3tpt37rawB8Af8MW/tDf a/tn/D2T/goP
532f7Ns/4QT/AIJefZfL8zzd32D/AIds/YftG7j7X9n+1+X+587yfkqNf2KP 2hEiu4R/wVl/
4KFlL2S4lmZvBP8AwTBeVGuVCSC0nf8A4JutPp8agZt4bCS2itGy9qkLktX6 F0UAfzO/8FXv
+DeHxl/wVI8Ifs0eGPG//BSj4yPqn7OeufHTVLTx38cP2fvgP8TfF+v6Z8Z9 M+BunweFLSP9
nvTv2MvB+j6H4PuPg1d6zBfa14S8Z+L9e1Px3qy6l4pi0vR9F0y3/XvxZ+yN 8dPEfjTxN4t0
f/gpx+3P4C07XtY1nUNL8BeE/Bn/AATmvPBfgvSdU1a51Ox8K+GU8df8E/8A xp4putH8OQTx
aNo2qeMfFPizxpPpNnbDxD4s13UWvNRuvt+6t/tMax+fcW+24tLjzLaXypG+ yXcN15DNtbNv
c+T9mu4sfvrWWaHcvmbhYoA/PRf2KP2hEiu4R/wVl/4KFlL2S4lmZvBP/BMF 5Ua5UJILSd/+
CbrT6fGoGbeGwktorRsvapC5LV8Ef8FMv+CHfxD/AOCkX7Kei/sxePP+Cln7 QmtJoPx8+G/x
v0bxv8efgh+y98Q5fDi+APhx8a/h9e+F/Deh/s3/AAx/Yunlk8aD4vWWr694 h8d+IvH8tm3g
TSbPQNL0l9a8QX17/QFVe7t/tdrdWvn3Ft9pt5rf7TaS+Td2/nRtH59tNtby riLd5kMu1vLk
VW2nGKAPAP2WPgFH+zX+yj+zb+y/N4ruPG0f7Pf7P/wY+BbeN7XT7vwXP4v/ AOFQ/D3w14EH
imPRrLXdYuvDX/CQt4dGqtokXiTWP7NS8bTH1fVI4nurj3+S2jlntrlmuBJa +d5Sx3d3DA3n
oI3+02sMyWt5tUAw/a4Z/s75kt/KkJY2KKAK8dtHFPc3KtcGS68nzVku7uaB fIQxp9mtZpnt
bPcpJm+yQwfaHxJcebIAwz7TTG/sa206/kuPO+zw/bJLTVtZ8z7XuWe4+zar Ne/2z9n+071h
8288z7Lttn/c5irYqvaW/wBktba18+4ufs1vDb/abuXzru48mNY/Puptq+bc S7fMml2r5kjM
20ZxQASW0cs9tcs1wJLXzvKWO7u4YG89BG/2m1hmS1vNqgGH7XDP9nfMlv5U hLEjto4p7m5V
rgyXXk+asl3dzQL5CGNPs1rNM9rZ7lJM32SGD7Q+JLjzZAGFiigDHttMb+zG 068kuNv2i72S
W2raz9r+yf2jNPYbtVlvf7W+0fZfs63eLzy/M862h/0HZFWhJbRyz21yzXAk tfO8pY7u7hgb
z0Eb/abWGZLW82qAYftcM/2d8yW/lSEsS2t/s0bR+fcXG64u7jzLqXzZF+13 c115CttXFvbe
d9mtIsfubWKGHc3l7jYoArx20cU9zcq1wZLryfNWS7u5oF8hDGn2a1mme1s9 ykmb7JDB9ofE
lx5sgDDPh0xvsl3p1xJcfYftC/YJIdW1n+0/snl207/a9Ve9/tH7R/aP2xV8 m88v+zvs1sfl
82Ktiq8Nv5Ml3J59xL9ruFuPLml8yO222tta+RaLtHk27fZvtLRZbN3cXU27 97tUAJLaOWe2
uWa4Elr53lLHd3cMDeegjf7TawzJa3m1QDD9rhn+zvmS38qQliR20cU9zcq1 wZLryfNWS7u5
oF8hDGn2a1mme1s9ykmb7JDB9ofElx5sgDCxRQB//9k=
name="PIPE.jpg"
filename="PIPE.jpg"
/9j/4AAQSkZJRgABAQEAWgBaAAD/4QAWRXhpZgAATU0AKgAAAAgAAAAAAAD/ 2wBDAAUDBAQE
AwUEBAQFBQUGBwwIBwcHBw8LCwkMEQ8SEhEPERETFhwXExQaFRERGCEYGh0d Hx8fExciJCIe
JBweHx7/2wBDAQUFBQcGBw4ICA4eFBEUHh4eHh4eHh4eHh4eHh4eHh4eHh4e Hh4eHh4eHh4e
Hh4eHh4eHh4eHh4eHh4eHh4eHh7/wAARCAALAC8DASIAAhEBAxEB/8QAGQAA AgMBAAAAAAAA
AAAAAAAAAwUABAYH/8QAKBAAAQIEAwkBAQAAAAAAAAAAAQIEAAMFEQYSVAcV FiExlaPR0kEU
/8QAFwEAAwEAAAAAAAAAAAAAAAAAAQIEA//EAB4RAQABBAIDAAAAAAAAAAAA AAECAAMRIVGR
BBIx/9oADAMBAAIRAxEAPwCls4q7/FWJ6u1rlAcv5aHk8qrBnLAvnUcq7qsT zAGXoLcrc46N
wxQ9D5V+4vYpw1SaZiOoM6cl60bJnrWmTKfz0oSVnMrKkLsBdRNhyH5CzdLf UVPuTj7inyr1
u9P2twIGAwK7Dbvn7xQiIbaLwxQ9D5V+4nDFD0PlX7gW6W+oqfcnH3E3S31F T7k4+4mo0Xhi
h6Hyr9wjf58M7RsJz6DOnsFzv7EzRLnKyzAJIsFJJsoC9+Y684b7pb6ip9yc fcaPZnhOhP8A
GrV7UG097OYyZq2xcvJ01KCsBCjlUopNwT1B/D1AhZCmq2sXIwksjOk7EOmv /9k=
Content-Type: text/xml;
name="PIPE.svg"
filename="PIPE.svg"
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.0//EN" "http://www.w3.org/TR/2001/REC-SVG-20010904/DTD/svg10.dtd">
<!-- Generated by Microsoft Visio 11.0, SVG Export, v1.0 PIPE.svg Page-1 -->
<svg xmlns="http://www.w3.org/2000/svg" xmlns:v="http://schemas.microsoft.com/visio/2003/SVGExtensions/" width="0.52in"
height="0.12in" viewBox="0 0 37.44 8.64" xml:space="preserve" color-interpolation-filters="sRGB" class="st4">
<v:documentProperties v:langID="1033" v:viewMarkup="false"/>
<style type="text/css">
<![CDATA[
.st1 {fill:#b3b3b3;stroke:#000000;stroke-linecap:round;stroke-lin ejoin:round;stroke-width:0.72}
.st2 {fill:#0000ff;stroke:#000000;stroke-linecap:round;stroke-lin ejoin:round;stroke-width:0.24}
.st3 {fill:#ff0000;stroke:#000000;stroke-linecap:round;stroke-lin ejoin:round;stroke-width:0.24}
.st4 {fill:none;fill-rule:evenodd;font-size:12;overflow:visible;s troke-linecap:square;stroke-miterlimit:3}
</style>
<g v:mID="0" v:index="1" v:groupContext="foregroundPage">
<title>Page-1</title>
<v:pageProperties v:drawingScale="1" v:pageScale="1" v:drawingUnits="0" v:shadowOffsetX="9" v:shadowOffsetY="-9"/>
<g id="group1-1" transform="translate(0.72,-0.72)" v:mID="1" v:groupContext="group">
<title>Sheet.1</title>
<g id="shape2-2" v:mID="2" v:groupContext="shape">
<title>Rectangle</title>
<v:userDefs>
<v:ud v:nameU="visVersion" v:val="VT0(11):26"/>
</v:userDefs>
<rect x="0" y="1.44" width="36" height="7.2" rx="1.152" ry="1.152" class="st1"/>
</g>
<g id="shape3-4" v:mID="3" v:groupContext="shape" transform="translate(8.90206,3.01003) rotate(90)">
<title>Triangle.2</title>
<v:userDefs>
</v:userDefs>
<path d="M4.34 8.64 L2.02 4.81 L-0.31 8.64 L4.34 8.64 Z" class="st2"/>
</g>
<g id="shape4-6" v:mID="4" v:groupContext="shape" transform="translate(35.6725,-0.216) scale(-1,1)">
<title>Rectangle.3</title>
<v:userDefs>
</v:userDefs>
<rect x="0" y="1.872" width="1.04661" height="6.768" class="st3"/>
</g>
</g>
</g>
</svg>
--------------000308070908000107080805--
Re: intermittent missing or disappearing svg [message #164898 is a reply to message #164801] |
Mon, 10 December 2007 11:33   |
Thanks Christian,
That's seems to have done the trick.
I also noticed, that the problem would only surface upon opening an
example diagram in which each figure (22 different SVG-based figures)
was represented.
Hope this helps you in figuring out the root cause of this. Perhaps
SWT's anti-aliasing chokes after hitting a certain number of SVG files?
Jacob
Christian W. Damus wrote:
> Hi, Jacob,
> There seems to have been some regression in SWT in Eclispe 3.4, that causes
> icons and stuff not to appear on diagrams when anti-aliasing is enabled.
> Try disabling anti-alias to see what you get. Have a look at the
> GeoshapePreferenceInitializer in the GeoShapes example plug-in for an
> example of how to do that.
> HTH,
> Christian
> -----8<-----
Re: intermittent missing or disappearing svg [message #164906 is a reply to message #164898] |
Mon, 10 December 2007 12:06   |
Doh!
Spoke too soon...
The problem still persists.
-Jacob
Jacob Barde wrote:
> Thanks Christian,
> was represented.
> Jacob
>> Hi, Jacob,
>> causes
>> HTH,
>> Christian
>> -----8<-----
Re: intermittent missing or disappearing svg -- Batik's CSSEngine? [message #171963 is a reply to message #164801] |
Sat, 09 February 2008 12:16   |
--------------000203070501010907070201
Christian,
I've been doing some further work on this problem. I even dusted off my
PERL skills and used it to sanitized my SVG files, removing all non-SVG
markup (i.e. MS SVGExtension), removed HTML/XML comments, as I heard
from someone they may have interfered with the rendering... doubtful,
but I was desperate. The SVG images are validated SVG 1.0.
During a few debugging instances, I caught the following errors in my
console log. This error doesn't appear in any regular frequency, but it
would only appear when some of the SVG images weren't rendering (but not
every time the images weren't rendering). I'm kinda figuring that this
may be [one of] the culprit(s)?
Perhaps this is cause to update the Orbit plugin for Batik (it's using
v1.6, current Apache release is v1.7)??
Wasn't sure if this belonged as a bug report as I can barely reproduce
the problem to result in console log entries. If it does, I'll gladly
submit the bug report.
-Jay
> Hi, Jacob,
> HTH,
> Christian
> -----8<-----
name="svg_css_error_20080207.txt"
filename="svg_css_error_20080207.txt"
org.w3c.dom.DOMException: http://www.w3.org/2000/svg:
The attribute "stroke" represents an invalid CSS value ("#000000").
Original message:
at org.apache.batik.css.engine.CSSEngine.getCascadedStyleMap(Un known Source)
at org.apache.batik.css.engine.CSSEngine.getComputedStyle(Unkno wn Source)
at org.apache.batik.bridge.CSSUtilities.getComputedStyle(Unknow n Source)
at org.apache.batik.bridge.CSSUtilities.convertDisplay(Unknown Source)
at org.apache.batik.bridge.GVTBuilder.buildGraphicsNode(Unknown Source)
at org.apache.batik.bridge.GVTBuilder.buildComposite(Unknown Source)
at org.apache.batik.bridge.GVTBuilder.build(Unknown Source)
at org.eclipse.gmf.runtime.draw2d.ui.render.awt.internal.svg.Im ageTranscoderEx.transcode(ImageTranscoderEx.java:309)
at org.apache.batik.transcoder.XMLAbstractTranscoder.transcode( Unknown Source)
at org.apache.batik.transcoder.SVGAbstractTranscoder.transcode( Unknown Source)
at org.eclipse.gmf.runtime.draw2d.ui.render.awt.internal.svg.SV GImageConverter.setUpTranscoders(SVGImageConverter.java:148)
at org.eclipse.gmf.runtime.draw2d.ui.render.awt.internal.svg.SV GImageConverter.renderSVGtoSWTImage(SVGImageConverter.java:7 4)
at org.eclipse.gmf.runtime.draw2d.ui.render.awt.internal.svg.SV GImage.renderImage(SVGImage.java:67)
at org.eclipse.gmf.runtime.draw2d.ui.render.internal.AbstractRe nderedImage.getSWTImage(AbstractRenderedImage.java:130)
at org.eclipse.gmf.runtime.draw2d.ui.render.internal.RenderHelp er$1.run(RenderHelper.java:103)
at java.lang.Thread.run(Unknown Source)
The attribute "stroke-linecap" represents an invalid CSS value ("round").
Original message:
ERROR: null
Enclosed Exception:
Original message:
Original message:
ERROR: null
Enclosed Exception:
Original message:
Original message:
ERROR: null
Enclosed Exception:
Original message:
The attribute "fill" represents an invalid CSS value ("#F2F4EC").
Original message:
ERROR: null
Enclosed Exception:
Original message:
ERROR: null
Enclosed Exception:
Original message:
Original message:
at org.eclipse.gmf.runtime.draw2d.ui.render.awt.internal.svg.SV GImageConverter.renderSVGToAWTImage(SVGImageConverter.java:5 5)
at org.eclipse.gmf.runtime.draw2d.ui.render.awt.internal.svg.SV GImage.renderImage(SVGImage.java:78)
ERROR: null
Enclosed Exception:
Original message:
name="svg_css_error_20080205.txt"
filename="svg_css_error_20080205.txt"
The attribute "stroke-width" represents an invalid CSS value ("0.72").
Original message:
The "stroke-width" property does not support identifier values.
at java.lang.Thread.run(Thread.java:619)
Original message:
ERROR: null
Enclosed Exception:
Original message:
ERROR: null
Enclosed Exception:
Original message:
--------------000203070501010907070201--
Re: intermittent missing or disappearing svg -- Batik's CSSEngine? [message #172135 is a reply to message #171963] |
Mon, 11 February 2008 09:11  |
Hi, Jacob,
The exceptions appear to indicate SVG constructs that Batik doesn't
recognize, but I know little about CSS and much less about SVG or the Batik
API. Perhaps someone that knows more about these subjects can provide more
information, here.
On the subject of 1.7: the GMF project had looked, early on in the Ganymede
release, at adopting this version. However, they were unable to arrange
with the Batik team to have it released in time for Ganymede, so the matter
was dropped. If it looks like there's movement in the Batik project, you
might take the matter up again with GMF.
Christian
Jacob Barde wrote:
> Christian,
> -Jay
>> Hi, Jacob,
>> causes icons and stuff not to appear on diagrams when anti-aliasing is
>> enabled.
>> HTH,
>> Christian
>> -----8<-----
Current Time: Sat Sep 27 07:29:41 EDT 2025
Powered by FUDForum. Page generated in 0.03923 seconds
