[Solved] Eclipse e4 - No bundle loaded after exporting to exe [message #1097791] |
Fri, 30 August 2013 06:51 |
ALex W Messages: 56 Registered: July 2012 |
Member |
I'm creating my application using Eclipse Juno.
In eclipse everything works well. I have my 6 or 7 bundle interacting correctly with each other within a custom eclipse e4 application.
I tried to export the main application as an exe file.
The exe file is generated, I can run it, but the problem is :
I only have the main application. My bundles (weither they are contributing to the UI or not) doesn't start.
So I went and look inside the plugins folder of the exported app. I does not contain my custom bundle. I tried to manually copy them inside the directory, but no better.
Should I modify the config.ini in the configuration folder ?
Is there any trick to export those in eclipse.
Please note, that I don't want to add these bundles in the required-bundle because they definitely are not required.
Any advice ?
[Updated on: Wed, 25 September 2013 21:17] Report message to a moderator
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1100119 is a reply to message #1099770] |
Mon, 02 September 2013 18:01 |
Member |
I'm not sure what you mean.
- My bundles are listed in the run configuration.
- They are not in the product dependencies, since I can't make them required.
Everything goes well in eclipse, not when exported... I can't see the eclipse custom parts or menu...
The customs bundles are listed in my config.ini, and present in the plugins directory.
There is no log file in the workspace directory...
Is there any way to add them as optional plugins or something ?
thanks
[Updated on: Mon, 02 September 2013 18:18] Report message to a moderator
FUDForum. Page generated in 0.03792 seconds
