Home » Archived » BIRT » DataException : Error in saving files of data set cache.(DataException : Error in saving files of data set cache.)
DataException : Error in saving files of data set cache. [message #1097772] Fri, 30 August 2013 02:31 Go to next message
We are facing below exception while generating report , Please let us know
what is the exact issue.We have executed the query and dataset is working fine.
error generating report org.eclipse.birt.report.engine.api.EngineException: There is an error in saving files of data set cache.
/apps/GTS/tmp/p_wtydm_wl/ccerrep/cache/DataEngine_698590531_9065/DataSetCacheObject_699656275_5368/data.data (No such file or directory) (Element ID:2026)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1206)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1185)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.emitter.ReportItemEmitterExecutor.execute(ReportItemEmitterExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:249)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:260)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:85)
Caused by: org.eclipse.birt.data.engine.core.DataException: There is an error in saving files of data set cache.
at org.eclipse.birt.data.engine.executor.dscache.CacheUtilFactory$DiskSaveUtil.saveObject(CacheUtilFactory.java:183)
at org.eclipse.birt.data.engine.executor.dscache.DataSetToCache.saveDataSetResult(DataSetToCache.java:185)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.execute(DataSourceQuery.java:1031)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:441)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1495)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:233)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:173)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init>(QueryResultSet.java:98)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.doExecuteQuery(DataGenerationEngine.java:80)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:265)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:250)
Caused by: java.io.FileNotFoundException: /apps/GTS/tmp/p_wtydm_wl/ccerrep/cache/DataEngine_698590531_9065/DataSetCacheObject_699656275_5368/data.data (No such file or directory)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:194)
at org.eclipse.birt.data.engine.core.security.FileSecurity$5.run(FileSecurity.java:190)
at org.eclipse.birt.data.engine.core.security.FileSecurity$5.run(FileSecurity.java:1)
at org.eclipse.birt.data.engine.core.security.FileSecurity.createFileOutputStream(FileSecurity.java:186)
at org.eclipse.birt.data.engine.core.security.FileSecurity.createFileOutputStream(FileSecurity.java:170)
at org.eclipse.birt.data.engine.executor.dscache.CacheUtilFactory$DiskSaveUtil.saveObject(CacheUtilFactory.java:178)
at org.eclipse.birt.data.engine.executor.transform.ResultSetPopulator.cacheDataSet(ResultSetPopulator.java:205)
at org.eclipse.birt.data.engine.executor.transform.CachedResultSet.<init>(CachedResultSet.java:142)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
Re: DataException : Error in saving files of data set cache. [message #1098430 is a reply to message #1097772] Fri, 30 August 2013 23:55 Go to previous messageGo to next message
What version of BIRT are you using? What is your dataSet type? Are you able to reproduce this error in a report that I can run?
[Updated on: Sat, 31 August 2013 00:01] by Moderator
Re: DataException : Error in saving files of data set cache. [message #1099699 is a reply to message #1098430] Mon, 02 September 2013 00:41 Go to previous messageGo to next message
Version of BIRT - 3.7.0
it is regular dataset (SQL select Query)
We are not able to reproduce this error.This error is occuring randomly.
Re: DataException : Error in saving files of data set cache. [message #1101081 is a reply to message #1099699] Tue, 03 September 2013 21:36 Go to previous messageGo to next message
Are you reading/writing in or out to any files? Can you attach the design that's not working? Is this error coming from the designer or while deployed? Let me know.
Re: DataException : Error in saving files of data set cache. [message #1101539 is a reply to message #1097772] Wed, 04 September 2013 11:39 Go to previous messageGo to next message
We have encountered this exception when the report is running under app server not in report designer.
This issue is intermittent
We are using weblogic 11
We don't see this issue always
Looks like it is DataEngine related issue
Re: DataException : Error in saving files of data set cache. [message #1102249 is a reply to message #1101539] Thu, 05 September 2013 11:06 Go to previous messageGo to next message
Are you stuck using 3.7.0? Or could you try using the 3.7.2 runtime to run the reports to see if that makes a difference?
Re: DataException : Error in saving files of data set cache. [message #1106485 is a reply to message #1097772] Wed, 11 September 2013 02:47 Go to previous messageGo to next message
Hi Williams,
This issue is intermitent , it is not occuring frequently.
But we would like to know the root cause.
We are using Weblogic 11 app server running under JDK 1.6 with oracle 11g
Please let us know what might be the root cause for this type of exception.
Note: We have encountered this issue in production environmnet so we will not be able to upgrade to 3.7.2.
Purnima
Re: DataException : Error in saving files of data set cache. [message #1106770 is a reply to message #1106485] Wed, 11 September 2013 10:26 Go to previous messageGo to next message
Understood. I just wanted to see if you could run a parallel deployment of 3.7.2 and test it to see if it has issues. It could be a bug in 3.7.0 that was fixed. If you absolutely cannot do testing with 3.7.2 or higher, I'll just have to let you know if I find something that might be the cause. I've not seen this error before or heard of anyone else getting it either. Hopefully I can find something for you. Please log a bug for this in the bugzilla to see if they have any info on it.
Re: DataException : Error in saving files of data set cache. [message #1106773 is a reply to message #1106770] Wed, 11 September 2013 10:28 Go to previous messageGo to next message
One more question. Is this only with one report? Or does this happen with random reports? If it's just one report, can you attach the report in here? Or email it to me at mwilliams.actuate at gmail? Thanks!
Re: DataException : Error in saving files of data set cache. [message #1114763 is a reply to message #1097772] Mon, 23 September 2013 03:03 Go to previous message
We have created a Bugzilla entry for this
Bug # 416204
[Updated on: Mon, 23 September 2013 03:03] by Moderator
Previous Topic: Runtime update of Reports throuht python API
Next Topic:First time Performance of BIRT report
Current Time: Thu Oct 30 05:12:39 EDT 2025
Powered by FUDForum. Page generated in 0.05925 seconds
