Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Warning in query implemented in Java
[Acceleo] Warning in query implemented in Java [message #1096513] |
Wed, 28 August 2013 09:38  |
Dear All,
I'm facing at repetitive warnings wrt a simple Acceleo query. The problem is that the warnings are listed in the error log view of Eclipse. And the list becomes longer and longer each time I perform a new generation.
Here is the simple query I use to format comments in C:
[query public formatComment(arg0 : String, arg1 : String, arg2 : String, arg3 : Integer) : String
= invoke('com.spacebel.acceleo.uml.to.c.services.commonServices', 'formatComment(java.lang.String, java.lang.String, java.lang.String, int)', Sequence{arg0, arg1, arg2, arg3}) /]
The associated java method is the following:
public String formatComment(String comment, String tagLine, String startLine, int lineSize)
String result = tagLine;
String[] yy = comment.replaceAll("\\r","").split("\n");
for (int i=0; i<yy.length; i++)
String line = yy[i];
if (i!=0)
result = result + "\n" + startLine;
if ((line.indexOf("@image") >= 0) || (line.length() <= lineSize))
result = result + line;
else
int size = 0;
String[] tokens = line.split(" ");
for (int x=0; x<tokens.length; x++)
String self = tokens[x];
if ((self.length() + size) < lineSize)
size = size + 1 + self.length();
result = result + self;
else
size = self.length() + 1;
result = result + "\n" + startLine + self;
if ((self.length() == 0) || (!self.endsWith("\n")))
result = result + " ";
return result;
The warning I have is: "It is strongly recommended not to return directly a String from a Java service in a query taking a primitive as its first parameter in order to ensure the precision of the traceability of each text region generated."
Does anyone know how to eliminate (kill) it ?
Regards;
[Updated on: Wed, 28 August 2013 09:38] by Moderator
Re: [Acceleo] [message #1096574 is a reply to message #1096513] |
Wed, 28 August 2013 11:26   |
Add an extra argument to your query so that it has on EObject to hang on to.
Just delete the irritations in the Problem View.
Ed Willink
On 28/08/2013 14:38, Johan Hardy wrote:
> Dear All,
> new generation.
> if (i!=0) {
> lineSize))
> else
> int size = 0;
> else
> (!self.endsWith("\n"))) {
> result = result + "\n" + startLine; return result;
> Regards;
Re: [Acceleo] [message #1096691 is a reply to message #1096574] |
Wed, 28 August 2013 14:34  |
Hi Ed,
Many thanks for your prompt answer. I used en EObject and it works !
[query public formatComment(arg0 : uml::Comment, arg1 : String, arg2 : String, arg3 : Integer) : String
= invoke('com.spacebel.acceleo.uml.to.c.services.commonServices', 'formatComment(org.eclipse.uml2.uml.Comment, java.lang.String, java.lang.String, int)', Sequence{arg0, arg1, arg2, arg3}) /]
Regards;
Current Time: Thu Sep 25 10:31:06 EDT 2025
Powered by FUDForum. Page generated in 0.06293 seconds
