Dynamically instantiating enums independent of enum type [message #1095520] |
Tue, 27 August 2013 06:58 |
Caspar D. Messages: 35 Registered: July 2009 |
Member |
A plain Java enum can be instantiated from a String that
corresponds to one of the constants declared in that enum,
without knowing the actual enum type:
String enumValAsString = ...; // Obtained from storage
Class<Enum> enumClass = ... ; // No need to know which enum it is
Enum<?> z = Enum.valueOf(enumClass, enumValAsString);
Works. But EMF enums override toString to return their custom
literal, which isn't the same as the name of the corresponding
const -- the former being lowercase and the latter uppercase.
So when I persist my EMF enums the same way I persist all my
enums including plain-Java enums, i.e. in their "toString" form,
the above code doesn't work.
There is the static "getByName" method which I can invoke
reflectively, but since that takes the name, not the literal,
I would have to call getName on saving them, which means I would
have to treat EMF enums as 'special' on *both* save and load.
So my question is: is there some better way of doing this that I'm
overlooking? I would like to just treat EMF enums as any other enums
both when I save them to persistence and when I load them.
Caspar
Re: Dynamically instantiating enums independent of enum type [message #1095576 is a reply to message #1095520] |
Tue, 27 August 2013 08:32 |
Ed Willink Messages: 7655 Registered: July 2009 |
You are probably trying to be too clever. Let EMF do the work for you.
You should find that XXXFactoryImpl.convertYYYToString and
createYYYFromString do what is required.
Ed Willink
> Thanks
> Caspar
Re: Dynamically instantiating enums independent of enum type [message #1095624 is a reply to message #1095576] |
Tue, 27 August 2013 09:59 |
Member |
The methods you recommend are in the generated factory class. I
can't use those because the point is to perform the conversion
without being tied to specific packages.
However, I took a look at the base implementation in EFactoryImpl,
which delegates to EcoreUtil.convertToString, and that seems to
work fine, as does its converse EcoreUtil.createFromString.
[UPDATE] But I just realized that still doesn't allow me to treat
them as plain Java enums, which in fact they are.
Caspar
[Updated on: Tue, 27 August 2013 12:01] Report message to a moderator
FUDForum. Page generated in 0.02710 seconds
