Home » Modeling » Epsilon » testing a transformation
testing a transformation [message #1095057] Mon, 26 August 2013 11:03 Go to next message
Hello Everyone,
I am really new to Epsilon and am a bit lost.I am not very familiar with testing either. Could anyone please tell me how I can test my model transformation? Lets say, I have two meta models, M1 and M2 and a transformation in ETL from M1 to M2. I have a file where I have an model that conforms to M1. Now, I want to input this file to the ETL application that I have written and I want to see the output file that I get.
Could someone kindly guide me in this process?
I will really appreciate some help.
Thank you so much and looking forward to hearing from someone Smile
Chandrakana.
Re: testing a transformation [message #1095549 is a reply to message #1095057] Tue, 27 August 2013 03:47 Go to previous messageGo to next message
Okay, I already found the answer here : http://www.eclipse.org/gmt/epsilon/cinema
It is an excellent video tutorial Smile
Re: testing a transformation [message #1095731 is a reply to message #1095549] Tue, 27 August 2013 08:53 Go to previous messageGo to next message
Hi Chandrakana,
Thanks. I'm glad the tutorial helped!
Dimitris
Re: testing a transformation [message #1095750 is a reply to message #1095731] Tue, 27 August 2013 09:25 Go to previous messageGo to next message
Hi Dimitris,
However, I have another question now. I have written a transformation and also a JUnit test to check if the transformation works for a simple hello-world model. I have the helloworld code conforming to the input meta-model and I also know the output code that I expect from my transformation. However, in the tutorial it shows that in a source folder named model, they have stored the tree.model and graph-expected.model files.
Could you please tell me how I can generate the .model files? What I mean is, if I have a file that conforms to an xml meta-model and I want to generate a file conforming to some model X (say), then how will I get the .model file from the .xml file?
Thank you so much,
Best,
Chandrakana.
Re: testing a transformation [message #1096431 is a reply to message #1095750] Wed, 28 August 2013 07:39 Go to previous messageGo to next message
Hi Dimitris,
Could you please take a look at my last question? I am not able to understand how I can get the models conforming to my metamodel Sad
Basically, I have codes in text format that conform to the metamodels that I am dealing with. In this case, how can I test my transformation?
Thank you so much in advance,
Best,
Chandrakana
Re: testing a transformation [message #1096445 is a reply to message #1096431] Wed, 28 August 2013 08:01 Go to previous messageGo to next message
Does this help?
http://eclipse.org/epsilon/doc/articles/reflective-emf-tutorial/
Dimitris
Re: testing a transformation [message #1096477 is a reply to message #1096445] Wed, 28 August 2013 08:52 Go to previous message
Oh yes!! Thank you very very much Dimitris Smile This is exactly what I was looking for.
Best Regards,
Chandrakana.
[Updated on: Wed, 28 August 2013 08:52] by Moderator
Previous Topic:ETL Transformation incase of more than one package
Next Topic:Cloning elements in ETL
Current Time: Fri Nov 07 09:26:40 EST 2025
Powered by FUDForum. Page generated in 0.07880 seconds
