Re: Using the source [message #167413 is a reply to message #163809] |
Tue, 25 April 2006 06:23 |
Frits Jalvingh wrote:
> I checked out the WTP sources from CVS HEAD from within Eclipse so that
> I can learn it's inner workings (and perhaps fix some rather irritating
> bugs in the Tomcat server provider :-)
> But after checking out lots of modules have build problems that I could
> only fix by altering the checked out modules. Some of the fixes I needed
> to make to get it (mostly) working are:
> - Make Eclipse PDE fix the classpath for all of the checked-out modules
> - Add a dependency on org.eclipse.wtp.common.environment to a lot of
> modules
> - Add dependencies on org.eclipse.debug.core to some modules
> etc.
> The result does work more or less but it makes me wonder if I am doing
> something wrong 8-/
> I have the following questions:
> 1. Is it normal for the CVS head to be inconsistent or am I doing
> something wrong?
> 2. Do I indeed need all of the modules present in CVS to build a
> complete WTP? Are there obsoleted plugins or is there a list of stuff
> one needs? Some of the modules do not build because of very basic
> reasons like failing to provide many interface functions which leads me
> to believe they are no longer maintained..
> Thanks for your time in answering me ;-)
You may not be doing anything wrong, and there may also not be
anything wrong with the snapshot of HEAD as you checked it out.
Several plugins in WTP have requirements for building cleanly
according to PDE's rules when we actually create our builds and run
them.
You're not crazy.
- Nitin
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.03582 seconds
