Add some indentation inside the <div id="midcolumn"> section [message #15431] |
Thu, 12 January 2006 16:13 |
Originally posted by: olivier_thomann.NOca.ibm.comSPAM
I believe it would be nice to have a little indentation between the
border of the box and its contents. On the Eclipse web page, this
doesn't look too bad, because there is a list inside the box. But when a
text is added without being in a list, it would be nice to add a little
indentation on the left side.
Is it possible to do this in the Eclipse style?
If this is not possible in the global settings, I'll do it locally.
Olivier
Re: Add some indentation inside the <div id="midcolumn"> section [message #15660 is a reply to message #15563] |
Fri, 13 January 2006 14:28 |
Eclipse WebMaster (Denis Roy) a écrit :
> I think if you wrap your text with <p> that will add the margin you need.
> <div class="homeitem3col">
> <h3>Box title</h3>
> <p>This is some text</p>
> </div>
This is what I tried.
And it doesn't work. There is no indentation on the left.
Olivier
Re: Add some indentation inside the <div id="midcolumn"> section [message #15713 is a reply to message #15563] |
Fri, 13 January 2006 18:25 |
> <h3>Box title</h3>
> </div>
If I do this and I add the following line in the css file layout.css (in
the phoenix theme):
..homeitem3col p {
padding-left: 5px;
I can then get the expected padding.
Could this be changed? I think it looks better with an additional
padding on the left.
Any thought?
Olivier
FUDForum. Page generated in 0.03801 seconds
