Home » Eclipse Projects » Eclipse Platform » The project description file for project is missing...
The project description file for project is missing... [message #163387] Fri, 28 November 2003 12:58 Go to next message
I am working on a Java project in Eclipse. All files related to the project
are stored on an external drive, which allows me bring work home. However,
at home the drive when connected uses the drive letter 'E' but at the office
it uses the drive letter 'F'.
I created the project on the machine where the drive's letter was 'E', and
now I cannot open the project on the machine where the drive's letter is
'F'. Eclipse says "The project description file (.project) for MyProject is
missing..."
Apart from setting the drive letter on one of the machines manually so that
the drive uses the same letter on both machines, is there any other solution
to this problem?
Thank you in advance.
Terence
Re: The project description file for project is missing... [message #164981 is a reply to message #163387] Tue, 02 December 2003 17:15 Go to previous messageGo to next message
Originally posted by: John_Arthorne.oti.com_
The only other workaround I can think of is to delete the project with
the invalid drive name and then do File > Import > Existing Project, and
select the project on the other drive.
Terence Song wrote:
> missing..."
> to this problem?
> Terence
Re: The project description file for project is missing... [message #165902 is a reply to message #164981] Thu, 04 December 2003 11:46 Go to previous message
Hi John,
Thanks for the reply.
I found a way round the problem. I specified the full path of the project
using unix-style, and it works. For example, my workspace is in
E:\Projects\workspace, and my project is in E:\Projects\MyProject (i.e. no
overlap between workspace and project folders, and on my work machine, the
drive letters would be F:). I simple specified a project path of
"/Projects/MyProject" when I created the project.
The only thing is, eclipse insists on using drive letters when adding
external jars to the build path. Although now I can access my project files,
I have to re-map external jars' path when I switch to a different machine.
Terence
"John Arthorne" <John_Arthorne@oti.com_> wrote in message
news:3FCD0F0B.7030804@oti.com_...
> Terence Song wrote:
> > Hi,
project
However,
office
and
is
> > missing..."
that
solution
> > to this problem?
> > Terence
Previous Topic:Launch Groups
Next Topic:Team dev plugin for RCS
Current Time: Sun Nov 09 06:51:47 EST 2025
Powered by FUDForum. Page generated in 0.03067 seconds
