Error Log - Problem occurred when invoking org.eclipse.ui.navigator [message #1092390] |
Thu, 22 August 2013 18:33 |
Shannon Sims Messages: 1 Registered: August 2013 |
Hi everyone, this is my first post so I hope I'm in the right forum.
Just days ago, I download and installed Kepler. I created a simple Dynamic Web Project with an index.html and a Hello.java with a main method. I can run the project and see the html fine. However, for some reason, I'm not seeing the Hello.class file anywhere in the project. The default output folder is JBossTest/build/classes. I did a clean and build, but still no classes. So, I thinking this is due to the following error in the Error Log (see below).
How can I resolve this issue or can this be ignored? If this can be ignored, is there any other reason why I'm not seeing the class file in the classes directory?
Thanks for viewing my post!
Environment:
Eclipse Kepler Build id: 20130614-0229
JBoss 7.1.1 Final
Java JDK 1.6.0_45
Windows 7 SP 1
Error Log:
eclipse.buildId=4.3.0.I20130605-2000
java.version=1.6.0_45
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
Error
Sun Aug 18 12:30:39 CDT 2013
Problems occurred when invoking code from plug-in: "org.eclipse.ui.navigator".
org.eclipse.core.runtime.CoreException: No property tester contributes a property org.eclipse.core.resources.open to type class org.eclipse.jst.jee.ui.internal.navigator.web.WebAppProvider
at org.eclipse.core.internal.expressions.TypeExtensionManager.getProperty(TypeExtensionManager.java:123)
at org.eclipse.core.internal.expressions.TestExpression.evaluate(TestExpression.java:96)
at org.eclipse.core.internal.expressions.CompositeExpression.evaluateAnd(CompositeExpression.java:53)
at org.eclipse.core.internal.expressions.AndExpression.evaluate(AndExpression.java:29)
at org.eclipse.core.internal.expressions.CompositeExpression.evaluateOr(CompositeExpression.java:68)
at org.eclipse.core.internal.expressions.OrExpression.evaluate(OrExpression.java:21)
at org.eclipse.core.internal.expressions.EnablementExpression.evaluate(EnablementExpression.java:53)
at org.eclipse.ui.internal.navigator.NavigatorPlugin$Evaluator.run(NavigatorPlugin.java:245)
at org.eclipse.ui.internal.navigator.NavigatorPlugin.safeEvaluate(NavigatorPlugin.java:260)
at org.eclipse.ui.internal.navigator.actions.CommonActionProviderDescriptor.isEnabledFor(CommonActionProviderDescriptor.java:235)
at org.eclipse.ui.internal.navigator.actions.CommonActionDescriptorManager.addProviderIfRelevant(CommonActionDescriptorManager.java:258)
at org.eclipse.ui.internal.navigator.actions.CommonActionDescriptorManager.findRelevantActionDescriptors(CommonActionDescriptorManager.java:235)
at org.eclipse.ui.navigator.NavigatorActionService.fillActionBars(NavigatorActionService.java:248)
at org.eclipse.ui.navigator.CommonNavigatorManager.selectionChanged(CommonNavigatorManager.java:222)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:164)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:162)
at org.eclipse.jface.viewers.StructuredViewer.updateSelection(StructuredViewer.java:2188)
at org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1211)
at org.eclipse.ui.navigator.CommonViewer.handleSelect(CommonViewer.java:478)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1241)
at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:239)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:233)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:403)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
FUDForum. Page generated in 0.10248 seconds
