Re: Resource Change Listener [message #1092412 is a reply to message #1092374] |
Thu, 22 August 2013 19:19 |
Ed Merks Messages: 33142 Registered: July 2009 |
Kevin,
On 22/08/2013 8:01 PM, Kevin Regan wrote:
> It seems that for a resource change event to fire, a change must
> happen to a resource that is currently open in an editor in the
> workspace.
No.
> In other words, I have added a file to my project and was hoping to
> listen for changes to this file from an external entity - however, the
> only time I get notified about changes to it is if I have it open in a
> text editor. Is there a way to make the resource change listener
> functionality notify me if the resource changes in the file system,
> regardless of whether it is open in the workspace?
That's normally how it works.
> Or am I forced to implement my own listener outside of the eclipse
> workspace domain?
No.
> /************* RESOURCE CHNAGE LISTENER TEST *********************/
> IResourceChangeListener listener = new
> IResourceChangeListener() {
> public void printDelta(IResourceDelta d, String indent) {
> IResource resource = d.getResource();
> IJavaElement javaElement = JavaCore.create(resource);
> String resourceName = null;
> if (javaElement instanceof IJavaProject) {
> resourceName = "Java project " + resource.getName();
> } else if (javaElement instanceof
> IPackageFragmentRoot) { resourceName = "PFR " +
> resource.getName();
> } else if (javaElement instanceof IPackageFragment) {
> resourceName = "PF " + resource.getName();
> } else if (javaElement instanceof ICompilationUnit) {
> resourceName = "CU " + resource.getName();
> } else {
> resourceName = resource.getName();
> System.out.println(indent.concat("Delta " +
> d.getKind() + " for resource " + resourceName));
> for (IResourceDelta childDelta :
> d.getAffectedChildren()) {
> printDelta(childDelta, indent.concat("\t"));
> public void resourceChanged(IResourceChangeEvent e) {
> if (e.getType() == IResourceChangeEvent.POST_CHANGE) {
Keep in mind that these are bit flags, so generally you should test by
using a bitwise or.
Try removing the guard so that you visit all changes for every delta...
> System.out.println("Post change event");
> IResourceDelta delta = e.getDelta();
> printDelta(delta, "");
> } else {
> System.out.println("Event type was " + e.getType());
> ResourcesPlugin.getWorkspace().addResourceChangeListener(listener);
> Thank you.
Ed Merks
Re: Resource Change Listener [message #1092493 is a reply to message #1092412] |
Thu, 22 August 2013 21:55 |
Kevin Regan Messages: 33 Registered: May 2013 |
Member |
Thanks a lot for your reply Ed. I implemented your suggestion to remove the guard (the examples I saw on line were doing equality checks but I should have looked at the javadoc and realized it was a bitmask):
IResourceChangeListener listener = new IResourceChangeListener() {
} else if (javaElement instanceof IPackageFragmentRoot) {
resourceName = "PFR " + resource.getName();
} else {
System.out.println(indent.concat("Delta " + d.getKind() + " for resource " + resourceName));
for (IResourceDelta childDelta : d.getAffectedChildren()) {
System.out.println("Resource change event type = " + e.getType());
//if (e.getType() | IResourceChangeEvent.POST_CHANGE) {
//System.out.println("Post change event");
/*} else {
Basically, I have a startup plugin that programmatically creates an Eclipse project using information passed in on the command line to eclipse. For testing purposes, I created a file in the project:
IFile myPropertyFile = project.getFile("mysettings");
if (!myPropertyFile.exists()) {
myPropertyFile.create(new ByteArrayInputStream("handle=1abcff23aa".getBytes()), true, getProgressMonitor());
In windows explorer I go to the file and edit it using a basic editor. I do not get any notification in the resource change listener when I do this. Am I doing something wrong here?
Note that I just did the same test by editing one of the Java source files that also reside in the project and did not get a notification about that either (just to make sure it didn't have to do with the type of element).
In both cases, if I subsequently go into eclipse and open the file that I previously modified outside of eclipse I get the notification at that time:
Resource change event type = 1
Delta 4 for resource
Delta 4 for resource Java project Test
Delta 4 for resource mysettings
[Updated on: Thu, 22 August 2013 21:57] Report message to a moderator
Re: Resource Change Listener [message #1092712 is a reply to message #1092493] |
Fri, 23 August 2013 05:46 |
Kevin,
If changes are made directly to the underlying file system (rather than
through Eclipse's IResource APIs) such changes are noticed only when the
workspace resources are refreshed. There are preferences that affect
how/when such refreshes occur (other than manual File->Referesh). I.e.,
Window->Preferences->Workspace->* I.e., "Refresh using native hooks or
polling" and "Refresh on access". If you often will make changes
outside of the IDE's APIs, you'd probably want to enable both these
options...
> bitmask):
> resource.getName();
> } else {
> e.getType());
> /*} else {
> Using windows explorer and VIM I go to the file created in the windows
> file system and edit the file. I do not get any notification in the
> here?
> type of element).
> at that time:
> Delta 4 for resource Delta 4 for resource Java project Test
Ed Merks
Re: Resource Change Listener [message #1095034 is a reply to message #1093088] |
Mon, 26 August 2013 14:29 |
Member |
Just answering my own question on the off chance that someone comes across this thread looking for the information. I was able to force the setting Ed mentioned during startup of my plugin via:
IEclipsePreferences prefs = InstanceScope.INSTANCE.getNode(PLUGIN_ID);
prefs.putBoolean(ResourcesPlugin.PREF_AUTO_REFRESH, true);
try {
prefs.flush();
} catch (BackingStoreException e2) {
e2.printStackTrace();
The polling is on a slow interval it seems and I have yet to find a preference or any way to change that interval.
[Updated on: Mon, 26 August 2013 14:29] Report message to a moderator
FUDForum. Page generated in 0.03277 seconds
