JAXB : EclipseLink-3002 while unmarshalling xml even JAXB RI works [message #1092049] |
Thu, 22 August 2013 09:07 |
Arnaud MERGEY Messages: 243 Registered: March 2010 Location: France |
I have generated Java classes from a xsd file using jaxb-compiler
then while unmarshalling a valid xml file (against same xsd), I have stack trace provided above.
By debugging the code it seems that as xml is "human readable" meaning like this
<tag>
<subtag/>
<tag>
eclipselink wrongly try to bind "/n/t" instead of binding subtag directly
If I unmarshall using same xml and same generated java with JAXB RI, it works as expected,
Do you have an idea on what could be the problem, and how I could solve it ?
Local Exception Stack:
Exception [EclipseLink-3002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.ConversionException
Exception Description: The object [], of class [class java.lang.String], from mapping [org.eclipse.persistence.oxm.mappings.XMLDirectMapping[complexAtomicAttributeTemplate-->complexAtomicAttributeTemplate/text()]] with descriptor [XMLDescriptor(test.gen.moxy.ComplexViewAttributeDefinition --> [])], could not be converted to [class test.gen.moxy.TplComplexAtomicAttr].
at org.eclipse.persistence.exceptions.ConversionException.couldNotBeConverted(ConversionException.java:71)
at org.eclipse.persistence.internal.helper.ConversionManager.convertObject(ConversionManager.java:169)
at org.eclipse.persistence.internal.oxm.XMLConversionManager.convertObject(XMLConversionManager.java:183)
at org.eclipse.persistence.internal.databaseaccess.DatasourcePlatform.convertObject(DatasourcePlatform.java:160)
at org.eclipse.persistence.oxm.mappings.XMLDirectMapping.getAttributeValue(XMLDirectMapping.java:293)
at org.eclipse.persistence.internal.oxm.XMLDirectMappingNodeValue.endElement(XMLDirectMappingNodeValue.java:182)
at org.eclipse.persistence.oxm.record.UnmarshalRecord.startElement(UnmarshalRecord.java:635)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:506)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(XMLNSDocumentScannerImpl.java:376)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2717)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:607)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:116)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:489)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:835)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:764)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:123)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1210)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:568)
at org.eclipse.persistence.internal.oxm.record.XMLReader.parse(XMLReader.java:157)
at org.eclipse.persistence.internal.oxm.record.SAXUnmarshaller.unmarshal(SAXUnmarshaller.java:753)
at org.eclipse.persistence.internal.oxm.record.SAXUnmarshaller.unmarshal(SAXUnmarshaller.java:333)
at org.eclipse.persistence.internal.oxm.record.SAXUnmarshaller.unmarshal(SAXUnmarshaller.java:320)
at org.eclipse.persistence.internal.oxm.record.SAXUnmarshaller.unmarshal(SAXUnmarshaller.java:280)
at org.eclipse.persistence.oxm.XMLUnmarshaller.unmarshal(XMLUnmarshaller.java:306)
at org.eclipse.persistence.jaxb.JAXBUnmarshaller.unmarshal(JAXBUnmarshaller.java:115)
[Updated on: Thu, 22 August 2013 09:09] Report message to a moderator
Re: JAXB : EclipseLink-3002 while unmarshalling xml even JAXB RI works [message #1093082 is a reply to message #1092352] |
Fri, 23 August 2013 14:39 |
Hi Arnaud,
The bug you are hitting was also fixed in the EclipseLink 2.3.3 stream:
- http://www.eclipse.org/eclipselink/downloads/previous_releases.php
I ran your test case and was able to get the same exception as you when using EclipseLink 2.3.2. You can change the way you create your JAXBContext to get your use case to work. In general when creating a JAXBContext on a model generated from an XML schema I recommend one of the following two ways to ensure you get everything you need to processed.
Option #1 - Create JAXBContext on Package Name
JAXBContext jaxbContext = JAXBContext.newInstance("test.moxy");
Option #2 - Create JAXBContext on ObjectFactory Class
JAXBContext jaxbContext = JAXBContext.newInstance(test.moxy.ObjectFactory.class);
-Blaise
FUDForum. Page generated in 0.02898 seconds
