Home » Eclipse Projects » Eclipse Platform » Getting references from IType
Getting references from IType [message #163066] |
Thu, 27 November 2003 19:04 |
Teemu Kanstren Messages: 5 Registered: July 2009 |
Junior Member |
How can I get all references to other types from an IType? I mean things
like class fields, method parameters, local variables, ...
I managed to use SearchEngine to find them, but I could only find the type
name as written in the source. This I managed by getting the compilation
unit and getting the substring between start and end (in a Collector).
However, I would prefer to get a real object that can tell me the fully
qualified name, etc.
For now, I just want to count the number of different types. So just finding
the names would be ok, but if someone imports java.util.List and declares
two variables "List foo" and "java.util.List bar", I will get two
references to java.util.List but with different names..
Re: Getting references from IType [message #163276 is a reply to message #163066] |
Fri, 28 November 2003 12:26 |
Jerome Lanneluc Messages: 572 Registered: July 2009 |
Have you tried SearchEngine.searchDeclarationsOfReferencedTypes(...) passing
the ICompilationUnit as the enclosing element?
Jerome
"Teemu Kanstren" <kibaltsis@hotmail.com> wrote in message
news:bq5hqk$vb$1@eclipse.org...
finding
Re: Getting references from IType [message #163406 is a reply to message #163066] |
Fri, 28 November 2003 18:17 |
Originally posted by: pmuse.pmayer.net
Hi Teemu,
There is a difference between types,fields,methods on the one hand and
local variables, method parameters (and other smaller elements) etc. on the
other hand. There are no ITypes for the latter, only AST Nodes.
If you parse a compilation unit using
ICompilationUnit current = ...
CompilationUnit cu = AST.parseCompilationUnit(current, true);
you can access the AST Nodes in cu (for example via a Visitor). The "true"
in parseCompilationUnit tells the parser to resolve the information so that
you can get the full qualified name of variable's type etc.
However, I think its not possible to directly convert from I<Something> to
AST<Something>. You have to do it via the whole CompilationUnit.
-phil
Re: Getting references from IType [message #163411 is a reply to message #163276] |
Fri, 28 November 2003 18:41 |
Junior Member |
No, I had not tried that. I now got it working great with that approach.
Thanks a lot !
A small problem; for some reason searchDeclarationsOfReferencedTypes() is
not calling my aboutToStart() and done() methods in the collector. Only the
accept(). Can you think of any reason for this? I can work around it easily
though, so its not such a big deal.
-Teemu
"Jerome Lanneluc" <jerome_lanneluc@fr.ibm.com> wrote in message
news:bq7eps$pfm$1@eclipse.org...
passing
> Jerome
type
> finding
declares
Re: Getting references from IType [message #163908 is a reply to message #163411] |
Mon, 01 December 2003 11:15 |
This sounds like a bug. I entered
https://bugs.eclipse.org/bugs/show_bug.cgi?id=47787 to investigate.
Jerome
news:bq84ru$l33$1@eclipse.org...
> Thanks a lot !
the
easily
> -Teemu
> passing
> > Jerome
things
> type
compilation
fully
> > finding
> declares
Current Time: Fri Apr 26 11:38:03 GMT 2024
Powered by FUDForum. Page generated in 0.03210 seconds
