Home » Modeling » GMF (Graphical Modeling Framework) » How to refresh decorators?
How to refresh decorators? [message #162936] Tue, 27 November 2007 16:28 Go to next message
Hi!
I have successfully implemented IDecoratorProvider and
IDecorator and want to refresh my decorators
programmatically.
Refreshing works fine if I call refresh() of all my
IDecorator instances.
But where do I get to know the currently existing
IDecorator instances?
Nicolai
I'm using an evaluation license of nemo since 86 days.
You should really try it!
http://www.malcom-mac.com/nemo
Re: How to refresh decorators? [message #163113 is a reply to message #162936] Wed, 28 November 2007 10:39 Go to previous messageGo to next message
Nicolai,
You will need to keep track of your IDecorator instances somewhere if
you need the ability to refresh them all. You might be able to keep a
static list in your IDecoratorProvider that is updated when a new
decorator is added.
Cherie
Nicolai Kamenzky wrote:
> Hi!
> programmatically.
> Cheers,
> Nicolai
Re: How to refresh decorators? [message #163163 is a reply to message #163113] Wed, 28 November 2007 13:40 Go to previous messageGo to next message
Hi Cherie,
I have already implemented it this way but I have
the problem that I don't know when to remove those
instances.
If I don't remove them from my list the number of
instances is only increasing and thus consume too
much memory.
Without adding them to my list those instances
would be garbage collected at some point.
Any suggestions?
Nicolai
In article <fik2am$n1u$1@build.eclipse.org> Cherie
Revells<crevells@ca.ibm.com> wrote:
> Nicolai,
> if you need the ability to refresh them all. You might be able to
> keep a static list in your IDecoratorProvider that is updated when
> a new decorator is added.
> Cherie
>> Hi!
>> programmatically.
>> Cheers,
>> Nicolai
Re: How to refresh decorators? [message #1036612 is a reply to message #163163] Mon, 08 April 2013 11:57 Go to previous message
Hy guys, it comes late but can be usefull, here is way to refresh
decorators :
EditPolicy ep = getEditPolicy(EditPolicyRoles.DECORATION_ROLE);
if (ep != null && ep instanceof GraphicalEditPolicyEx){
((GraphicalEditPolicyEx)ep).refresh();
Ludovic
Le 28/11/2007 19:40, Nicolai Kamenzky a écrit :
> Hi Cherie,
> instances.
> much memory.
> Any suggestions?
> Nicolai
> In article <fik2am$n1u$1@xxxxxxxxe.org> Cherie
> Revells<crevells@xxxxxxxx.com> wrote:
>> Nicolai,
>> Regards,
>> Cherie
>>> Hi!
>>> programmatically.
>>> Cheers,
>>> Nicolai
Previous Topic:EOpposite in diagram editor
Next Topic:DecoratorProvidor error
Current Time: Sat Nov 08 22:29:55 EST 2025
Powered by FUDForum. Page generated in 0.03602 seconds
