Home » Language IDEs » C / C++ IDE (CDT) » Auto-insert Switch/Case & Do/While incorrect(This seems to be a recurring problem, auto-insertion of Switch/Case & Do/While)
icon4.gif  Auto-insert Switch/Case & Do/While incorrect [message #1089973] Mon, 19 August 2013 14:34 Go to next message
Missing name Mising name is currently offline Missing name Mising nameFriend
Member
Eclipse Kepler Configuration
eclipse.buildId=4.3.0.M20130731-0800
eclipse.commands=-os
win32
-ws
win32
-arch
x86
org.eclipse.cdt (8.2.0.201306112328) "Eclipse C/C++ Development Tools"
*** Plug-in Registry:
org.eclipse.cdt (8.2.0.201306112328) "Eclipse C/C++ Development Tools" [Starting]
org.eclipse.cdt.core (5.5.0.201306112328) "C/C++ Development Tools Core" [Active]
org.eclipse.cdt.core.win32 (5.3.0.201306112328) "C/C++ Development Tools Core for Windows" [Resolved]
org.eclipse.cdt.core.win32.x86 (5.2.0.201306112328) "C/C++ Development Tools Core for Windows (x86)" [Resolved]
Background:
I have created a C/C++ Code Style Formatter Custom Profile based on the built-in
Whitesmiths profile.
I configured the custom profile to conform to our coding standard, using the preview
pane to verify the format. The preview pane is a great tool.
Next I configured the Editor Templates to use the formatter.
From Custom Formatter Profile (Braces tab):
   switch (bar)
      case 0:
         ++bar;
         break;
      case 1:
         --bar;
      default:
         bar += bar;
         break;
From Custom Formatter Profile (White Space tab):
switch (number)
   case RED:
      return GREEN;
   case GREEN:
      return BLUE;
   case BLUE:
      return RED;
   default:
      return BLACK;
while (condition)
do
while (condition);
From Templates Preview:
switch (${key}) {
   case ${value}:
      ${line_selection}${cursor}
      break;
   default:
      break;
do {
} while (${condition});
ISSUE:
Most of the supported templates are inserted a expected. I have found two templates
(switch/case, do/while) which do not conform to the configured formatter options
when auto-inserted.
I was able to find possibly related bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=246627
https://bugs.eclipse.org/bugs/show_bug.cgi?id=161024 (from 2006, subsequent reports marked a duplicate????!!!)
Inserted incorrect format:
switch (key)
   case value:
   break;
   default:
   break;
do
}while (condition);
Workaround:
I have disabled the "Use code formatter" option and updated each of the templates
to produce the desired results.
Am I missing something?
Thanks in advance for any response.
Sad Sad
Major System Configuration:
Windows 7 64-bit
Eclipse IDE for C/C++ Developers
v 4.6.2 (Neon)
v 4.7.3a (Oxygen)
v 4.8r (Photon)
v 2018_09
PyDev
MinGW
MSys
GNU Toolchain
Perforce
Re: Auto-insert Switch/Case & Do/While incorrect [message #1090744 is a reply to message #1089973] Tue, 20 August 2013 15:22 Go to previous message
Axel Mueller is currently offline Axel MuellerFriend
The bug reports you listed are for JDT the Java editor.
But there is indeed a problem in the CDT code templates with respect to code formatter
https://bugs.eclipse.org/bugs/show_bug.cgi?id=244912
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Previous Topic:warning
Next Topic:Symbol 'NULL' could not be resolved
Current Time: Fri Apr 26 06:39:14 GMT 2024
Powered by FUDForum. Page generated in 0.03101 seconds
