CDT Project [message #1089926] |
Mon, 19 August 2013 13:00 |
Ivan Evstegneev Messages: 4 Registered: August 2013 |
Junior Member |
Hello everyone,
Recently installed Eclipse (Kepler)... Ok will provide some more info about that:
I downloaded Eclipse IDE for C/C++ Devepores. As I can understand you don't actually need to install it.. just run an *.exe file. Am I right?
My problem,or actually a question I would like to ask, is about some sort of warning message, when I open my new C project.
While opening the New C Project I have two tool-chains to use: "Cross GCC" or "Microsoft Visual C++".
According to WIKI I need to prefer the "Cross GCC" in all cases:"unless I'll develop my own OS".
So now to the point:
When using Cross GCC I get this error message:
Description Resource Path Location Type
Program "gcc" not found in PATH project [Discovery Options] page in project properties C/C++ Problem
The second problems is:
When using a Microsoft Visual tool-chain, I get this one:
Invalid project path: Include path not found (C:\Program Files (x86)\Windows Kits\8.0\Include\gl). project pathentry Path Entry Problem
Now about those "Discovery options", I googled those problems a little I found some sort of solution,but, guys I don't actually have those options in my Kepler, here is some print-screen image:
So, I don't have any as you can see. Maybe these settings moved to other place?
In any case any help will be greatly appreciated, I would like to know what is the meaning of those errros and how can I fix them.
Thanks a lot,
Ivan.
Because I'm new out here and I have posted only this message, I can't add pictures from other sites, here link to my print screen -> ://s23.postimg.org/p8xqq87tn/eclipse_pref.jpg just add an "http" before.
[Updated on: Mon, 19 August 2013 14:49] Report message to a moderator
Re: CDT Project [message #1089992 is a reply to message #1089926] |
Mon, 19 August 2013 14:52 |
On 8/19/2013 8:00 AM, Ivan Evstegneev wrote:
> Hello everyone,
> about that: I downloaded Eclipse IDE for C/C++ Devepores. As I can
> file. Am I right?
> So now to the point: When using Cross GCC I get this error message:
http://www.eclipse.org/forums/index.php/t/161206/
Re: CDT Project [message #1090141 is a reply to message #1090070] |
Mon, 19 August 2013 19:00 |
On 8/19/2013 11:15 AM, Ivan Evstegneev wrote:
> Russell you are just incredible......
> I saw this link(and all the other "stickers"). Still, thought it will be
> more appropriate to write it down here.
> Maybe the simplest way is just duplicate my thread.
Not sure if it helped. And, I'm sorry I just don't enough about your
second question to offer any suggestion even as lame as the first one.
FUDForum. Page generated in 0.09671 seconds
