Home » Modeling » Epsilon » Eugenia creating nested Shape Figure
Eugenia creating nested Shape Figure [message #1087816] Fri, 16 August 2013 02:13 Go to next message
Hi all,
I want to ask you, is there anyway to create nested shape ?
example; Polygon in Rect in Ellipse ?
i add sample nested shape to attachment
Re: Eugenia creating nested Shape Figure [message #1087953 is a reply to message #1087816] Fri, 16 August 2013 06:46 Go to previous message
EuGENia does not have direct support for this, I'm afraid. However, you could approximate that particular shape using figure="polygon" and providing the appropriate coordinates in polygon.x and polygon.y:
http://eclipse.org/epsilon/doc/articles/eugenia-gmf-tutorial/
You will probably need to tweak the GMF models in order to place the label at the bottom-right corner of the figure, though. You could start with label.placement="external" and then see if you can make GMF place it at that corner.
Previous Topic:Standalone from Java
Next Topic:EWL - Update UML statemachine model
Current Time: Fri Nov 07 09:26:37 EST 2025
Powered by FUDForum. Page generated in 0.03322 seconds
