Please following below mentioned steps:
Use the pom.xml found here
Add carnot.properties and carnot.license file of 5.3.x release to Stardust_Testing_Embedded_Spring\embedded\src\main\resources folder. Also edit carnot.properties to point the following param to correct location of carnot.license as per your situation:
License.LicenseFilePath = E:/Stardust_Testing_Embedded_Spring/embedded/src/main/resources/carnot.license
Edit SimpleTest.java located at Stardust_Testing_Embedded_Spring\embedded\src\test\java\com\sungard\embed\embedded and fix the package of:
import com.sungard.embed.embedded.AbstractProcessContextTest;
Edit carnot-spring-context.xml and fix the package of the bean carnotAuditTrailInitalizer as below:
<bean id="carnotAuditTrailInitalizer" class="[b]com.sungard.embed.embedded.AuditTrailInitalizer[/b]">
<property name="dataSource" ref="carnotXaAuditTrailDataSource" />
<property name="auditTrailDdlFile" value="src/main/resources/audittrail_ddl.sql" />
</bean>
Once the above steps are done, run mvn clean install from within the folder where pom.xml of this project is. It will build and run the test SimpleTest.java.
We are in the process of updating the article to make it work with Startdust 1.0.
