changing .uml model file do not change .di model file [message #1084409] |
Sun, 11 August 2013 13:44 |
Hello All,
I am working on updating UML statemachine model using Epsilon EWl. In my work I manipulate UML statemachine model that was created bye papyrus. I manipulate .uml model file and delet some element and add another one. When my .uml model file has been changed, I can not see this change in graphical representation of model (.di model file). How I can solve this problem?
Best Regards,
Amin
Re: changing .uml model file do not change .di model file [message #1747495 is a reply to message #1747369] |
Tue, 15 November 2016 13:17 |
It seems that both screen-shots are identical (at least I could not tell the difference). So, please update. A .png is generally preferable compared to a word document.
I understand that some code you have modifies UML elements (seems to be activities). So what does not work? Elements that have been added on the model level do not automatically appear? Please clarify
Re: changing .uml model file do not change .di model file [message #1747522 is a reply to message #1747495] |
Tue, 15 November 2016 16:07 |
taghreed altamimi Messages: 184 Registered: October 2014 |
Sorry for confusing,
I used EOL to change the deployment diagram and i added device5,then i synchronized the diagram to model then i got in the diagram the whole elements before change in the model plus the new one (device5)but also activity1 and activity2 appeared in the deployment diagram even they are not new elements and not related to the deployment diagram . i tried also to synchronize the activity diagram with the model i got all elements (the one that was there before change and the new one) of the activity diagram scattered beside the diagram itself as in the attached picture.
Is there a way to synchronize the diagram with the model? and if so how can do that without mixing up the whole elements together
[Updated on: Tue, 15 November 2016 16:17] Report message to a moderator
Re: changing .uml model file do not change .di model file [message #1747625 is a reply to message #1747535] |
Wed, 16 November 2016 15:23 |
Thanks for your prompt reply i followed the procedure to synchronize part of the activity diagram with the model after i added new activity partition but i got the whole elements are scattered beside the diagram ,it seems that its user responsibility to gather them again to get the new diagram am i right??
I tried to set the radio button to false ,nothing changed or the diagram did not go back to its previous state.I don't know why??
Taghreed
[Updated on: Wed, 16 November 2016 15:26] Report message to a moderator
FUDForum. Page generated in 0.04075 seconds
