Home » Eclipse Projects » EclipseLink » @JoinColumn @Convert(Any way to tweak the way @JoinColumn treats foreign keys?)
icon5.gif  @JoinColumn @Convert [message #1083663] Sat, 10 August 2013 05:04 Go to next message
Is there some way to modify the way a @JoinColumn handles foreign keys for null fields? I think I'm looking for something like a @Convert that I can apply to the @JoinColumn, similar to how I can apply @Convert to @Column.
More specifically, what I need to do is to convert a DB field with all spaces to null when reading, and convert a entity field that is null to all spaces when writing, but let the join behave normally in all other cases (i.e. look up and return the entity instance with the referenced id).
New to JPA and EclipseLink, hope there is a simple and obvious answer?
Background:
Trying to join a simple entity (A) to another entity (B) using a plain join and a single field key in a legacy DB.
Problem is that the DB schema states all fields as NOT NULL, using spaces to indicate an absent key. This works just fine when writing native SQL, but I have problems doing this with a JPA mapping. Since this concerns a legacy DB with lots of manual SQL based on these conventions, changing the DB schema is not an option.
Using a plain @JoinColumn seems to work ok when I read entity A, since it fails to find an entity B with all spaces as key (albeit presumably with some cost for trying to look it up), and entity A is loaded with null in the field for entity B.
But when I try to write entity A (insert or update) I get errors complaining about trying to insert null into not nullable field for B in table A.
Simple illustration - READ:
TableA
id, fkB (NOT NULL)
'A1', 'B1'
'A2', ' '
TableB
id
'B1'
Desired result when loading entities from TableA:
a1.b: b1
a2.b: null
Simple illustration - WRITE:
a1.b: b1
a2.b: null
Desired result when writing entities to TableA:
TableA
id, fkB (NOT NULL)
'A1', 'B1'
'A2', ' '
TableB
id
'B1'
[Updated on: Sat, 10 August 2013 05:09] by Moderator
Re: @JoinColumn @Convert [message #1083668 is a reply to message #1083663] Sat, 10 August 2013 05:14 Go to previous messageGo to next message
This message about Converters for non-basic types seems to be similar?
[Updated on: Sat, 10 August 2013 05:16] by Moderator
Re: @JoinColumn @Convert [message #1085870 is a reply to message #1083668] Tue, 13 August 2013 09:35 Go to previous messageGo to next message
Sounds like your data model is not correct. If a relationship can be null, the foreign key should be nullable.
Re: @JoinColumn @Convert [message #1087904 is a reply to message #1085870] Fri, 16 August 2013 04:58 Go to previous messageGo to next message
One may have an opinion about the design of the DB schema (and it is not mine Smile, but as stated above - since this concerns a legacy DB with lots of manual SQL based on these conventions, changing the DB schema is not an option.
I did however find a way of handling this - almost Sad
I use @Basic and @Convert annotations with a custom converter that converts between object value and data value. Simple example:
@Converter(name="myConverter", converterClass=MyConverter.class),
public class MyEntity {
    @Convert("myConverter")
    @Basic(fetch=FetchType.LAZY, optional=true)
    private MyOtherEntity counterCompany;
This works fine and maps objects back and forth as desired. However, I cannot get the LAZY fetch to work (I do weaving, and lazy fetch on @ManyToOne mappings work just fine). Considering how some of these objects are used, LAZY fetch is crucial for decent performance.
So I guess the question would be slightly modified:
1 - is there a good reason for my converter being called on load despite @Basic(fetch=FetchType.LAZY)?
2 - is there some other way to do this (could a DescriptorCustomizer help me?)
Re: @JoinColumn @Convert [message #1090520 is a reply to message #1087904] Tue, 20 August 2013 04:51 Go to previous messageGo to next message
About Q1:
"@Basic
TopLink JPA ignores the fetch attribute. Default FetchType.EAGER always applies."
(http://www.oracle.com/technetwork/middleware/ias/toplink-jpa-extensions-094393.html#LazyLoading)
But on the other hand:
"Use the @Basic annotation to do the following:
configure the fetch type to LAZY;"
(http://wiki.eclipse.org/EclipseLink/UserGuide/JPA/Basic_JPA_Development/Mapping/Basic_Mappings/Basic)
Still a mystery to me. Anyone else seeing this problem?
Re: @JoinColumn @Convert [message #1095792 is a reply to message #1090520] Tue, 27 August 2013 10:26 Go to previous messageGo to next message
What product and version are you using? EclipseLink supports lazy basics through fetch groups which require weaving to enhance your entities : http://wiki.eclipse.org/EclipseLink/UserGuide/JPA/Advanced_JPA_Development/Performance/Weaving
Best Regards,
Chris
Re: @JoinColumn @Convert [message #1095894 is a reply to message #1095792] Tue, 27 August 2013 13:30 Go to previous message
Chris Delahunt wrote on Tue, 27 August 2013 16:26
Best Regards,
Chris
I'm using 2.5.0, and I do static weaving that works just fine for regular @JoinColumn mappings mappings (e.g. @ManyToOne).
What do you mean by "through fetch groups" - is there something I need to do to get @Basic to do lazy fetch that I don't have to do for more "sophisticated" mappings?
N.B. I'm doing static weaving, running resource-local POJOs (not server managed), if it matters.
[Updated on: Tue, 27 August 2013 16:01] by Moderator
Previous Topic:ReadOnly mapping attribute causes inserts
Next Topic:Jpa UNION and MySql
Current Time: Mon Sep 22 09:36:36 EDT 2025
Powered by FUDForum. Page generated in 0.03588 seconds
