Re: Importing/Opening xmi file from OMG [message #1085999 is a reply to message #1083043] |
Tue, 13 August 2013 16:58  |
Kenn Hussey Messages: 1620 Registered: July 2009 |
Alessandro,
The problem with these references (four of them) is that they do not
include information about the UML type that the reference represents. In
the absence of such information, UML2 tries to create and instance of
Classifier but because Classifier is abstract, it fails.
To fix the problem, insert 'xmi:type="uml:Stereotype"' into each of the
references, for example:
<general xmi:type="uml:Stereotype"
href="http://www.omg.org/spec/UML/20110701/StandardProfileL2.xmi#Trace"/>
Kenn
On 13-08-09 7:41 AM, Alessandro Romero wrote:
> I have downloaded the sysml.xmi
> (www.omg.org/spec/SysML/20120401/SysML.xmi) from OMG, and I have tried
> to open in eclipse JUNO (Version: Juno Service Release 2
> Build id: 20130225-0426).
> I am using UML Editor (UML2 4.0.2) to try open.
> There are 4 errors, They occurr in line like the following. It is a
> reference problem. I tried pathmap://... but it did not work.
> <general href="www.omg.org/spec/UML/20110701/StandardProfileL2.xmi#Trace"/>
> The entire error message for this line is below.
> I have experienced similar error with another OMG XMI file
> (www.omg.org/spec/SyM/20120320/SysML4Modelica-Profile.xmi).
> Has anyone had similar problem?
> Is there a general solution for reference problem? How can I register a
> model?
> OBS: I suppressed http:// in links and references.
> Thanks in advance.
> Alessandro
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException:
> org.eclipse.emf.ecore.xmi.IllegalValueException: Value
> mailto:'org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl@a04083
> (eProxyURI: pathmap://UML_PROFILES/StandardL2.profile.uml#Trace eClass:
> mailto:org.eclipse.emf.ecore.impl.EClassImpl@eb87f7 (name: Classifier)
> (instanceClassName: null) (abstract: false, interface: false))' is not
> legal. (platform:/resource/BouncingBall/profile/orig/SysML.xmi, 1209, 98)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
> at
> org.eclipse.uml2.uml.editor.presentation.UMLEditor.createModelGen(UMLEditor.java:918)
> at
> org.eclipse.uml2.uml.editor.presentation.UMLEditor.createModel(UMLEditor.java:938)
> at
> org.eclipse.uml2.uml.editor.presentation.UMLEditor.createPages(UMLEditor.java:1026)
> at
> org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:358)
> at
> org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:138)
> at
> org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:96)
> at
> org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:313)
> at sun.reflect.GeneratedMethodAccessor55.invoke(Unknown Source)
> at
> org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
> at
> org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:861)
> at
> org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:841)
> at
> org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:113)
> at
> org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:321)
> at
> org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:242)
> at
> org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
> at
> org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
> at
> org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
> at
> org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:894)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:629)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:731)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:702)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:696)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:681)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1115)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:67)
> at
> org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
> at
> org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
> at
> org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
> at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
> at
> org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
> at
> org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
> at
> org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
> at
> org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
> at
> org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
> at
> org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
> at
> org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
> at
> org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
> at
> org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
> at
> org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
> at
> org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
> at
> org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
> at
> org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
> at
> org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
> at
> org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:422)
> at
> org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:389)
> at
> org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:606)
> at
> org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:332)
> at
> org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1029)
> at
> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3047)
> at
> org.eclipse.ui.internal.WorkbenchPage.access$22(WorkbenchPage.java:2969)
> at
> org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:2951)
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2947)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2911)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2902)
> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:655)
> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:614)
> at
> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:360)
> at
> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:167)
> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
> at
> org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
> at
> org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
> at
> org.eclipse.jdt.internal.ui.navigator.OpenAndExpand.run(OpenAndExpand.java:50)
> at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:221)
> at
> org.eclipse.ui.navigator.CommonNavigatorManager$3.open(CommonNavigatorManager.java:185)
> at
> org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
> at
> org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
> at
> org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
> at
> org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
> at
> org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:462)
> at
> org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
> at
> org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
> at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
> at
> org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
> at
> org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
> at
> org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
> at
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
> Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2658)
> at
> org.eclipse.uml2.uml.internal.resource.XMI2UMLHandler.setFeatureValue(XMI2UMLHandler.java:179)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2643)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFeatureType(XMLHandler.java:2162)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHandler.java:2030)
> at
> org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHandler.java:128)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1809)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1018)
> at
> org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:81)
> at
> org.eclipse.uml2.uml.internal.resource.XMI2UMLHandler.processElement(XMI2UMLHandler.java:142)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:996)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:707)
> at
> org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:163)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser.emptyElement(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown
> Source)
> at
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:240)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1505)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1284)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
> ... 109 more
> Caused by: java.lang.ClassCastException:
> org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl cannot be cast to
> org.eclipse.uml2.uml.Classifier
> at
> org.eclipse.uml2.uml.internal.impl.GeneralizationImpl.eSet(GeneralizationImpl.java:490)
> at
> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1071)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1204)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2653)
> ... 139 more
FUDForum. Page generated in 0.03534 seconds
