Home » Archived » Orion (Archived) » Problem with import git from bitbucket
Problem with import git from bitbucket [message #1081043] Tue, 06 August 2013 14:29 Go to next message
Tyr import git from private bitbucket but dont work:
https://WHK@bitbucket.org/WHK/whk-conversor.git: 412 Password required
Chose and password and key ssh but nothing.
If change status of private to public project works! but in private mode with ssh key dont work.
[Updated on: Tue, 06 August 2013 14:29] by Moderator
Re: Problem with import git from bitbucket [message #1081944 is a reply to message #1081043] Wed, 07 August 2013 18:39 Go to previous message
Any chance you are seeing this issue? More specifically:
Workaround is to press "More", and enter the ssh password in the Git Credentials dialog that opens.
Previous Topic:[orionhub.org] Limit storage space
Next Topic:[SOLVED] Passing Regex flags for patterns in Syntax Highlighting Grammar
Current Time: Wed Mar 19 09:49:29 EDT 2025
Powered by FUDForum. Page generated in 0.03288 seconds
