Home » Eclipse Projects » Eclipse 4 » e4 compatability layer: add toolbar item in main toolbar
e4 compatability layer: add toolbar item in main toolbar [message #1080081] Mon, 05 August 2013 12:50 Go to next message
Dennis Melzer is currently offline Dennis MelzerFriend
I'm using e4 with the compatibility layer an want to expand the the main toolbar
My product definition is based on "org.eclipse.ui.ide.workbench" application.
So when I launch my product, the direct tool item isn't shown.
I added a fragment.e4xmi. This fragment contains:
<?xml version="1.0" encoding="ASCII"?>
<fragment:ModelFragments xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:fragment="http://www.eclipse.org/ui/2010/UIModel/fragment" xmlns:menu="http://www.eclipse.org/ui/2010/UIModel/application/ui/menu" xmi:id="_i66q4Pt9EeKex-36mnvnVw">
  <fragments xsi:type="fragment:StringModelFragment" xmi:id="_q25C8Pt9EeKex-36mnvnVw" featurename="children" parentElementId="org.eclipse.ui.main.toolbar" positionInList="after=additions">
    <elements xsi:type="menu:ToolBar" xmi:id="_bWQKIPt-EeKex-36mnvnVw" elementId="myTest">
      <children xsi:type="menu:DirectToolItem" xmi:id="_5jUbIPt9EeKex-36mnvnVw" elementId="directtoolitem.0" label="Test" iconURI="" contributionURI="bundleclass://documenteditor/test.MyTest"/>
    </elements>
  </fragments>
</fragment:ModelFragments>
But doesn't work Sad...
Second try was to do it programmatically.
   <extension
         id="id"
         point="org.eclipse.e4.workbench.model">
      <fragment
            uri="fragment.e4xmi">
      </fragment>
      <processor
            beforefragment="false"
            class="test.MenuProcessor">
         <element
               id="org.eclipse.ui.file.menu">
         </element>
      </processor>
   </extension>
The MenueProccesor is executed, but the MMenue is null and the window.getChildren() is empty. So what i have to do?
public class MenuProcessor
    // I get this via the parameter
    // of the process definition
    @Inject
    @Named("org.eclipse.ui.file.menu")
    private MMenu        menu;
    @Inject
    private MApplication application;
    @Execute
    public void execute()
        System.out.println("hier");
        // System.out.println("Starting processor");
        // Remove the old exit menu entry
        if (menu != null && menu.getChildren() != null)
            List<MMenuElement> list = new ArrayList<MMenuElement>();
            for (MMenuElement element : menu.getChildren())
                System.out.println(element);
                // Separaters have no label hence we
                // need to check for null
                if (element.getLabel() != null)
                    if (element.getLabel().contains("Exit"))
                        list.add(element);
            menu.getChildren().removeAll(list);
            // Now add a new menu entry
            MDirectMenuItem menuItem = MMenuFactory.INSTANCE.
                    createDirectMenuItem();
            menuItem.setLabel("Another Exit");
            menuItem.setContributionURI("bundleclass://"
                    + "com.example.e4.rcp.todo.contribute/"
                    + MyTest.class.getName());
            menu.getChildren().add(menuItem);
        MWindow window = application.getChildren().get(0);
        for (MWindowElement windowElement : window.getChildren())
            System.out.println(windowElement.getElementId());
[Updated on: Mon, 05 August 2013 13:21]
Report message to a moderator
Re: e4 compatability layer: add toolbar item in main toolbar [message #1080107 is a reply to message #1080081] Mon, 05 August 2013 13:28 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=376486
Re: e4 compatability layer: add toolbar item in main toolbar [message #1080165 is a reply to message #1080107] Mon, 05 August 2013 14:55 Go to previous message
Ahhh thanks
Previous Topic:Loading data when Application starts
Next Topic:IMenueService and CoolbarManager
Current Time: Fri Apr 26 11:47:14 GMT 2024
Powered by FUDForum. Page generated in 0.03301 seconds
