Home » Eclipse Projects » Eclipse Platform » Modifying the editor's content
Modifying the editor's content [message #159736] Thu, 20 November 2003 16:29 Go to next message
Hello !
So, my plugin is a popup menu item from the JavaEditor's popup menu. My
code is called properly. Now I am trying to find a way to insert text in
the javaeditor.
My plugin is an IEditorActionDelegate so the methods I implement are :
public void run(IAction action)
public void setActiveEditor(IAction action, IEditorPart targetEditor)
So does anyone know how I can access the content of the editor from (I
guess) the IEditorPart instance ?
To be more precise, when the user right click in the java editor and
select my menu item, I want to insert some text at current position in the
text. So I need to get the caret's position which I know how to get, and I
need access to the text, to a way to update that text.
Any ideas ?
Max.
Re: Modifying the editor's content [message #159973 is a reply to message #159736] Fri, 21 November 2003 05:34 Go to previous messageGo to next message
Originally posted by: eclipse.tkilla.ch
Maxime Poulin wrote:
> Hello !
> the javaeditor.
if (targetEditor instanceof ITextEditor) {
IDocumentProvider provider= ((ITextEditor)
targetEditor).getDocumentProvider();
IEditorInput input= targetEditor.getEditorInput();
IDocument document= provider.getDocument(input);
document.replace(caretPosition, length, "new text");
-tom
Re: Modifying the editor's content [message #160109 is a reply to message #159973] Fri, 21 November 2003 09:59 Go to previous message
Cool !
Thank you Tom !
Previous Topic:CVS I/O Interrupted
Next Topic:Statusline-messages from Navigator
Current Time: Sat Nov 01 04:08:47 EDT 2025
Powered by FUDForum. Page generated in 0.03693 seconds
