Home » Archived » BIRT » Cognos Cubes as a Data Source
Cognos Cubes as a Data Source [message #159735] Wed, 10 May 2006 02:53 Go to next message
Originally posted by: p.corbett.ecu.edu.au
I am using:
Actuate BIRT Report Designer Professional
Version: 2.0.1
Build id: 20060222-1204
Is there any way to use a Congnos Powerplay Cube (.mdc) as a BIRT data
source?
Thanks.
Re: Cognos Cubes as a Data Source [message #159941 is a reply to message #159735] Wed, 10 May 2006 14:19 Go to previous message
Peter,
There are two general ways in which this can be done:
A. (Requires less work) Use a BIRT scripted datasource to programmatically
access a given Cognos cube from a given BIRT Report. The following URLs
provides more info on this approach
http://www.eclipse.org/downloads/download.php?file=/birt/dow nloads/demos/scripted_data_src.wmv&r=1
http://www.eclipse.org/birt/phoenix/deploy/#extending
B. (Requires more work) Extend BIRT with using the Open Data Access (ODA)
Extension API
In this way you can allow any Cognos Cube to be accessed from any BIRT
report in a generic fashion. You will be able to find more info on how to
extend BIRT in an Addison-Wesley book called "Integrating and Extending
BIRT" which should become available in the next few weeks. Another good
source of info is to monitor the postings in this forum and the BIRT Eclipse
website.
Mihail
"Peter Corbett" <p.corbett@ecu.edu.au> wrote in message
news:f465112993a9bc8b9eeab0ba5eb39625$1@www.eclipse.org...
> I am using:
> Actuate BIRT Report Designer Professional Version: 2.0.1
> source?
> Thanks.
Previous Topic:How do you detect if a dataset returns no values
Next Topic:Table header group
Current Time: Fri Oct 31 04:16:03 EDT 2025
Powered by FUDForum. Page generated in 0.03396 seconds
