Eclipse 3.7 Logging facility without ui plugins [message #1077950] |
Fri, 02 August 2013 10:54 |
John M. Messages: 198 Registered: July 2010 |
I am trying to establish a logging environment for my command line application.
First try was to use slf4j and logback, but it seems that they always require ui plugins.
Using the new DI Logger facility isn't applicable for me, because I am not using the ui.workbench plugin, which contains a proper implementation of the Logger interface (WorkbenchLogger).
I haven't found any other yet.
LogService from OSGi is a possibility which is working, but it seems that it logs only errors. Is there a way to configure it?
At the moment I can use log4j (1.2), but I need a fragment project to get it running (http://www.eclipsezone.com/eclipse/forums/t99588.html).
Is there a way to use slf4j without any ui?
FUDForum. Page generated in 0.03131 seconds
