Home » Eclipse Projects » GEF » Location of child parts in container
Location of child parts in container [message #159649] Mon, 29 November 2004 23:10 Go to next message
I have an EditPart which uses a LabeledContainer and which accepts parts
that are Labels, using ToolbarLayout to position them vertically. I
would like to put ConnectionAnchors on the sides of the container that
line up with the contained parts. I thought to do this in
refreshChildren for the container but I can't figure out how to get the
actual location of the children. I have tried traversing the child
EditParts and the children of the LabeledContainer Figure but getBounds
always returns the same unhelpful values. I thought to try
translateToParent but that seems to be hardwired to do nothing. Is this
method too early to get the rendered location? It seems to run after
refreshVisuals.
Thanks.
Re: Location of child parts in container [message #159802 is a reply to message #159649] Tue, 30 November 2004 11:37 Go to previous messageGo to next message
Your anchor should derive the location when it is asked getLocation. If you
do it any sooner, the figures aren't in the correct place. For performance
reasons, layouts only occur hopefully once and in the order of depencies,
such as connections depending on their nodes.
"Barry Lay" <blay@laysercomputing.com> wrote in message
news:cogrs1$flo$1@www.eclipse.org...
> refreshVisuals.
> Thanks.
Re: Location of child parts in container [message #159820 is a reply to message #159802] Tue, 30 November 2004 14:17 Go to previous messageGo to next message
Thank you, that got the job done. Incidently, what does the parameter
do? The API mentions that the anchor "...may use the given reference
Point..." but doesn't say what it refers to. I notice that the logic
diagram example ignores it.
Re: Location of child parts in container [message #159854 is a reply to message #159820] Tue, 30 November 2004 15:54 Go to previous message
See ChopboxAnchor for an example
news:coigvs$kp7$1@www.eclipse.org...
you
performance
depencies,
Previous Topic:TextFlow and BlockFlow is-a Figure?
Next Topic:Tie into Save All
Current Time: Sun Nov 09 17:48:11 EST 2025
Powered by FUDForum. Page generated in 0.03361 seconds
