Glassfish 4.0 and Kepler [message #1077590] |
Thu, 01 August 2013 23:02 |
Christopher Sharp Messages: 5 Registered: September 2012 |
I just installed Glassfish 4.0 and Eclipse Kepler with the aim of developing code for JabaServer Faces 2.2. Although Eclipse is working and I can get Glassfish 4.0 to start up manually, and runs on localhost:8080, with the console on localhost:4848, I am unable to get Glassfish running from Eclipse. It tries to start up, then fails with the message:
Unable to start server due to the following issues:
Wrong user name or password. Killing startup process.
In Eclipse I have the following configurations:
Path is <path>\domains\domain1 set up
Admin name is "admin"
Admin Password is "admin", I also tried "adminadmin" which is the default.
Server Port Number is 8080
Admin Server Port Number is 4848
User Anonymous Connection for Admin Commands: checked
Preserver Sessions Across Redeployment: checked
User Jar Archives: unchecked
I tried the first of the three check boxes both checked and unchecked.
Finally, the JRE is jre7 in the runtime environment.
No matter what I do, I am unable to get Glassfish to work with Eclipse. I tried to uninstall Glassfish from Eclipse then re-install it again, as well as closing Eclipse then restarting it.
In an earlier version of Eclipse I have Glassfish 3 working correctly. I would be grateful if somebody could kindly help me get this fixed - many thanks.
FUDForum. Page generated in 0.08555 seconds
