Exception switching perspectives after upgrade to Juno [message #1077233] |
Thu, 01 August 2013 12:08 |
Luís de Sousa Messages: 214 Registered: July 2009 |
Dear all,
I upgraded yesterday from Indigo to Juno, and while so far everything seems to be working ok, I'm getting an exception every time I switch perspectives:
Quote:An error has occurred. See error log for more details.
org.eclipse.ui.internal.WorkbenchPage.findPerspective(Lorg/eclipse/ui/IPerspectiveDescriptor;)Lorg/eclipse/ui/internal/Perspective;
In the log there's the following:
!ENTRY org.eclipse.ui.workbench 4 2 2013-08-01 13:52:11.378
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
java.lang.NoSuchMethodError: org.eclipse.ui.internal.WorkbenchPage.findPerspective(Lorg/eclipse/ui/IPerspectiveDescriptor;)Lorg/eclipse/ui/internal/Perspective;
at org.eclipse.papyrus.ui.perspectiveconfiguration.PapyrusPerspectiveListener.perspectiveActivated(PapyrusPerspectiveListener.java:117)
at org.eclipse.ui.internal.PerspectiveListenerList$1.run(PerspectiveListenerList.java:74)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.PerspectiveListenerList.fireEvent(PerspectiveListenerList.java:58)
at org.eclipse.ui.internal.PerspectiveListenerList.firePerspectiveActivated(PerspectiveListenerList.java:72)
at org.eclipse.ui.internal.WorkbenchWindow.firePerspectiveActivated(WorkbenchWindow.java:1264)
at org.eclipse.ui.internal.WorkbenchPage$4.handleEvent(WorkbenchPage.java:2805)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4299)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:380)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
at org.eclipse.e4.ui.workbench.addons.perspectiveswitcher.PerspectiveSwitcher$13.widgetSelected(PerspectiveSwitcher.java:439)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1276)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3562)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3186)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
I found the report of a similar problem at StackOverflow, where it is suggested a restart with the -clean option should bring things back to normal. In my case it didn't work out.
Any clues on how to solve this issue are welcome. Thank you.
[Updated on: Thu, 01 August 2013 12:10] Report message to a moderator
FUDForum. Page generated in 0.08542 seconds
