Home » Newcomers » Newcomers » Unhandled event loop exception ,No more handles(Eclispe in the packages of adt-bundle-windows-x86_64-20130717,always occured this problem)
Unhandled event loop exception ,No more handles [message #1076247] Tue, 30 July 2013 22:50 Go to next message
The OS of my computer is Windows 7 64bit.
Android SDK and eclipse are from adt-bundle-windows-x86_64-20130717.zip which is downloaded from the android developer guide website.
My problem is when I click from the Package explorer on the left to anywhere in an opened file in the workbench,error dialog will occur,the error info is below:
No more handles
After I click OK button,then it will show another dialog that ask me whether I want to exit the workbench or not.
Is anyone who in troble with this problem? Is there any solution to it?
More error info is below:
Session Data:
eclipse.buildId=v22.0.4-741630
java.version=1.7.0_25
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN
Framework arguments: -product com.android.ide.eclipse.adt.package.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product com.android.ide.eclipse.adt.package.product
Exception Stack Trace:
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:4387)
at org.eclipse.swt.SWT.error(SWT.java:4276)
at org.eclipse.swt.SWT.error(SWT.java:4247)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.Control.createHandle(Control.java:704)
at org.eclipse.swt.widgets.Label.createHandle(Label.java:199)
at org.eclipse.swt.widgets.Control.createWidget(Control.java:744)
at org.eclipse.swt.widgets.Control.<init>(Control.java:112)
at org.eclipse.swt.widgets.Label.<init>(Label.java:101)
at org.eclipse.ui.texteditor.StatusLineContributionItem.fill(StatusLineContributionItem.java:182)
at org.eclipse.jface.action.SubContributionItem.fill(SubContributionItem.java:59)
at org.eclipse.jface.action.StatusLineManager.update(StatusLineManager.java:327)
at org.eclipse.ui.internal.WorkbenchPage.updateActivations(WorkbenchPage.java:265)
at org.eclipse.ui.internal.WorkbenchPage.access$15(WorkbenchPage.java:243)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:172)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$2.run(PartServiceImpl.java:193)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:191)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:596)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:549)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:105)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:61)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1447)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2328)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4572)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2069)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4989)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2541)
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:80)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3129)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3753)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Re: Unhandled event loop exception ,No more handles [message #1076448 is a reply to message #1076247] Wed, 31 July 2013 08:08 Go to previous messageGo to next message
It sounds like something is leaking window handles. I've not sen that
with just the Eclipse IDE itself, so most likely an Android-specific
issue best asked about on an Android-specific forum...
> No more handles
> Session Data:
> java.vendor=Oracle Corporation
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
Re: Unhandled event loop exception ,No more handles [message #1080272 is a reply to message #1076448] Mon, 05 August 2013 14:17 Go to previous messageGo to next message
I've recently begun having this error as well. I upgraded to kepler from juno just before it started happening. Now, after having removed all of eclipse from my environment (at least I think I did) I reinstall Juno and immediately experience this issue. Note that this isn't an Android development box. Any new information on this problem?
Here's my stack trace:
eclipse.buildId=M20130204-1200
java.version=1.7.0_04
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
Error
Mon Aug 05 11:04:09 PDT 2013
Re: Unhandled event loop exception ,No more handles [message #1080851 is a reply to message #1080272] Tue, 06 August 2013 08:58 Go to previous messageGo to next message
James,
If this was just a pervasive problem, everyone would see it... What
else, if anything, do you have installed in the base package you
downloaded from Eclipse?
On 06/08/2013 2:48 PM, James Karavias wrote:
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Unhandled event loop exception ,No more handles [message #1080972 is a reply to message #1080851] Tue, 06 August 2013 12:24 Go to previous messageGo to next message
Ed,
Thanks for asking that so gently. Embarrassed
The package I've installed is Eclipse for Java EE developers (Juno). Windows 64bit. Its strictly the package as downloaded. I have had other versions on this machine but believe I've eliminated any remnants of them. This morning the way I reproduced it was to create a new workspace, import a maven project, open the package explorer and a source file in the java editor (not WindowBuilder) and then click somewhere in the package explorer panel, then back in the java editor. It happens every time. It doesn't seem to matter which editor I'm using. I can get it to happen by editing the POM
Possibly relevant is that I had been seeing situations in my prior install where windows were not repainting completely or that moving the mouse pointer along packages in the explorer would result in the package names dissappearing.
It doesn't produce the exact same stack trace each time. Deeper stack frames vary by which widget is being updated.
I am using this on a Lenovo W520 with 16gb running Windows 7 pro. SP 1. Displaying on 3 monitors. The GPU is NVIDIA Quadro 1000M; driver version 9.18.13.593.
What additional information would be helpful?
Jim
Re: Unhandled event loop exception ,No more handles [message #1081011 is a reply to message #1080972] Tue, 06 August 2013 13:27 Go to previous messageGo to next message
James,
If you have reproducible steps, please outline them carefully and open a
bugzilla. Please try to reproduce it minimally, i.e., just with one of
the download packages and test what additional things you must install
for the problem to start appearing. I really doubt that JDT is the
source of the problem; once you run out of window handles, the problems
will appear everywhere, and everyone would be complaining. So you see
the problem in Juno? You probably should try Kepler instead then...
On 06/08/2013 6:24 PM, James Karavias wrote:
> Ed,
> Thanks for asking that so gently. :blush:
> Jim
Re: Unhandled event loop exception ,No more handles [message #1081728 is a reply to message #1081011] Wed, 07 August 2013 12:02 Go to previous messageGo to next message
Well, I am seeing the same issue with Kepler. I will try fresh installs on different machines.
Jim
Re: Unhandled event loop exception ,No more handles [message #1087773 is a reply to message #1081728] Fri, 16 August 2013 00:31 Go to previous messageGo to next message
I have removed SWT and still have the same problem with Kepler.
People had this problem before with Indigo or older version.
I am going to try Juno to see if it's better.
Re: Unhandled event loop exception ,No more handles [message #1088115 is a reply to message #1087773] Fri, 16 August 2013 11:49 Go to previous message
You removed SWT? Eclipse needs it to run at all.
Previous Topic:Can't get Eclipse and Tomcat working properly together
Next Topic:Second Indigo instance hangs on startup
Current Time: Fri Oct 31 18:48:45 EDT 2025
Powered by FUDForum. Page generated in 0.32000 seconds
