Home » Modeling » EMF » Unset on isMany containment-ref doesn't trigger detachment
Unset on isMany containment-ref doesn't trigger detachment [message #1075325] Mon, 29 July 2013 04:38 Go to next message
Calling unSet on a single-valued containment ref triggers detachment. Calling unSet on a many-valued containment ref does not, leaving the previously-referenced objects in limbo.
Why the difference?
Caspar
[Updated on: Mon, 29 July 2013 04:40] by Moderator
Re: Unset on isMany ref does not trigger detachment [message #1075344 is a reply to message #1075325] Mon, 29 July 2013 05:07 Go to previous messageGo to next message
Caspar,
Comments below.
> objects that were previously referenced from the feature in limbo.
A generated eUnset just does getAbcs().clear() and that's implemented to
handle inverse removals in
org.eclipse.emf.common.notify.impl.NotifyingListImpl.clear() so I'm
doubtful of your assertion because such a problem would have been
noticed many years ago. Not only that, when stepping through this logic
in the debugger just now, I see that it's working as expected, i.e., the
contained objects have their eContainer set to null.
> Why the difference?
I don't think there is a difference but I can look at a test case that
reproduces the problem if you provide one.
> Thanks
> Caspar
Re: Unset on isMany ref does not trigger detachment [message #1075370 is a reply to message #1075344] Mon, 29 July 2013 06:07 Go to previous messageGo to next message
Hi Ed,
Thanks for your quick response.
I should have mentioned that I'm invoking eUnSet reflectively.
Your point about the *generated* eUnset made me realize
I have none; which then made me realize the ref actually has
unsettable=false in my model. But so does the single-valued
containment ref I was testing.
So, my mistake.. but I do still wonder why the behavior isn't
the same, and why the setting delegate doesn't detect
the attempt to unset a non-unsettable feature.
Caspar
Re: Unset on isMany ref does not trigger detachment [message #1075391 is a reply to message #1075370] Mon, 29 July 2013 06:51 Go to previous messageGo to next message
Caspar,
Comments below.
On 29/07/2013 12:07 PM, Caspar De Groot wrote:
> Hi Ed,
I assumed that...
> I have none;
Reflective delegation?
Unsettable just means there's an extra state to distinguish having just
the default value as opposed to having been explicitly set to a value
that happens to be the same as the default value. For many-valued
features, that means you'd have to call clear on the list for eIsSet to
return true. In no case does it mean you can't unset the feature...
It doesn't mean what you assumed. Unless the feature is changeable
false, it's always possible to unset the feature.
> Thanks
> Caspar
Re: Unset on isMany ref does not trigger detachment [message #1076373 is a reply to message #1075391] Wed, 31 July 2013 05:17 Go to previous messageGo to next message
[quote title=Ed Merks wrote on Mon, 29 July 2013 06:51]
>> I have none;
Yes.
So this distinction only affects the return value of the isSet
method? It has no bearing on eUnset at all?
But then if a feature has unsettable=false, what is the correct
isSet behavior? To always return true? Or is isSet undefined for
features that have unsettable=false?
That's for sure Wink
Thanks again.
Caspar
Re: Unset on isMany ref does not trigger detachment [message #1076389 is a reply to message #1076373] Wed, 31 July 2013 05:51 Go to previous messageGo to next message
Caspar,
Comments below.
>>> I have none;
> Yes.
>> just the default value as opposed to having been explicitly set to a
>> value that happens to be the same as the default value.
Yes.
In general there are the following expectations.
* When you first create an EObject x, x.eIsSet(f) will be false for
each f in x.eClass().getEAllStructuralFeatures().
* After you call x.eUnset(f), x.eIsSet(f) will be false.
* After you call x.eSet(f, value), the value of x.eIsSet(f) depends on
whether f is an unsettable feature. If f is unsettable then it will
be true, if f is not unsettable, then it will be the same as testing
(value == null ? f.getDefaultValue() == null ?
value.equals(f.getDefaultValue()).
So the difference between unsettable features and non-unsettable
features is that for unsettable features there is one more state than
can be represented with only the values of the type. You'll see in
generated models, that's an extra boolean or an extra bit flag, in
dynamic/reflective models in the settings array, it's a special marker
value not from the data type. So unsettable features are always eIsSet
true after a call to eSet and false after a call to eUnset. For normal
(non unsettable features), eIsSet depends purely on whether the current
value of the feature is equal to the default value for the feature, so
calling eSet or eUnset will not change the state if you set to a value
equal to the default, or unset when it already had the default value.
> That's for sure ;)
> Thanks again.
> Caspar
Re: Unset on isMany ref does not trigger detachment [message #1076452 is a reply to message #1076389] Wed, 31 July 2013 08:19 Go to previous message
Hi Ed,
That's a thorough explanation, I really appreciate it.
Thanks a lot
Caspar
Previous Topic:Customizing conext menu
Next Topic:[Solved] URI reference between XMI files
Current Time: Wed Sep 24 12:16:48 EDT 2025
Powered by FUDForum. Page generated in 0.04361 seconds
