Open dynamically a part [message #1074342] |
Fri, 26 July 2013 10:42  |
Hello ,
I have a browser and i want open a new part when i double click on a node. I follow some instruction in previous post but i have an incomprehensible error . Therefore when i click on a node nothing happend handlers execute methode not called
Thanks you for your answers
My error stack:
!ENTRY org.eclipse.equinox.event 4 0 2013-07-26 16:06:48.300
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/application/Contribution/object/SET] to handler org.eclipse.e4.ui.services.internal.events.UIEventHandler@3f651673
!STACK 0
java.lang.ClassCastException: org.eclipse.e4.ui.model.application.commands.impl.HandlerImpl cannot be cast to org.eclipse.e4.ui.model.application.ui.MUIElement
at org.eclipse.ui.internal.WorkbenchPage$5.handleEvent(WorkbenchPage.java:4957)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4688)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:205)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.impl.ContributionImpl.setObject(ContributionImpl.java:131)
at org.eclipse.e4.ui.internal.workbench.addons.HandlerProcessingAddon.processActiveHandler(HandlerProcessingAddon.java:158)
at org.eclipse.e4.ui.internal.workbench.addons.HandlerProcessingAddon.access$0(HandlerProcessingAddon.java:151)
at org.eclipse.e4.ui.internal.workbench.addons.HandlerProcessingAddon$2.handleEvent(HandlerProcessingAddon.java:120)
at org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl.setContext(PartImpl.java:399)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:614)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1096)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:66)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer$9.widgetSelected(StackRenderer.java:885)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1081)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:778)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3061)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1753)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:278)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at test.rcp.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
My handlers
public class OpenNodeDatastoreBrowserHandler {
public OpenNodeDatastoreBrowserHandler() {
System.out.println("objet appelé");
@Execute
public void openNode(
@Named(IServiceConstants.ACTIVE_SELECTION) Item selectedItem,EPartService partService,EModelService modelService, MApplication app) {
System.out
.println("OpenTreeNodeHandler - Handler invoked with selected item "
+ selectedItem);
String partId="test.rcp.inputpart.dataseteditor";
//String partId = createEditorPartIdFor(selectedItem);
MPart editorPart = partService.findPart(partId);
if (editorPart == null) {
System.out.println("OpenTreeNodeHandler - No editor found with id="
+ partId);
editorPart = createEditorFor(selectedItem);
MPartStack editorsStack = (MPartStack) modelService.find(
"sample.part.stack.editors", app);
editorsStack.getChildren().add(editorPart);
System.out.println("OpenTreeNodeHandler - Editor with id=" + partId
+ " created and added to stack");
} else {
+ " already exists");
partService.activate(editorPart);
+ " activated");
private String createEditorPartIdFor(Item selectedItem) {
return "sample.editor." + selectedItem.toString();
private MPart createEditorFor(Item selectedItem) {
MPart editorPart = MBasicFactory.INSTANCE.createPart();
editorPart.setElementId(createEditorPartIdFor(selectedItem));
String shortName = selectedItem.toString();
editorPart.setLabel(shortName);
editorPart.setTooltip(shortName);
editorPart.setCloseable(true);
editorPart
.setContributionURI("bundleclass://test.rcp/com.itf.tvt.tool.datastore.gui.DatasetEditorPart");
return editorPart;
my listener for the tree
treeViewer.addDoubleClickListener(new IDoubleClickListener() {
@SuppressWarnings("restriction")
public void doubleClick(DoubleClickEvent event) {
IStructuredSelection selection = ((IStructuredSelection) event
.getSelection());
System.out.println(selection);
if (!selection.isEmpty()) {
System.out.println(selectionService);
selectionService.setSelection(selection.getFirstElement());
// ParameterizedCommand command = commandService
// .createCommand(
// "test.rcp.command.datastore.browser.opennode",
// null);
.getCommand("test.rcp.command.datastore.browser.opennode");
// Check if the command is defined
System.out.println("command defini:" + command.isDefined());
// Activate Handler, assume AboutHandler() class exists
// already
handlerService.activateHandler(
new OpenNodeDatastoreBrowserHandler());
ParameterizedCommand cmd = commandService
.createCommand(
null);
// Check if the command can get executed
System.out.println(handlerService.canExecute(cmd));
// Execute the command
handlerService.executeHandler(cmd);
// System.out.println(command.getCommand().isHandled());
// IHandlerService hs = (IHandlerService)
// locationService.getService(IHandlerService.class)
// handlerService.executeHandler(command);
[Updated on: Fri, 26 July 2013 10:42] by Moderator
Re: Open dynamically a part [message #1075470 is a reply to message #1075277] |
Mon, 29 July 2013 09:35   |
I am going to assume that the node (or button or whatever) is a child of the Datastore Browser part. With that, your application model looks fine. My only comment is be careful with the o.e.u.internal.*Handler's eg:
<handlers xmi:id="_BpYwkOk5EeKK7dLmcrkNfg" elementId="test.rcp.handler.4" contributionURI="bundleclass://org.eclipse.ui/org.eclipse.ui.internal.CloseAllHandler"/>
I have not worked with these much, so someone else might be able to speak to this better than I am. Depending upon your application (3.x, migration, pure E4), you might be better off using something like o.e.e4.ui.internal.workbench.handlers.SaveAllHandler.
But to echo what Sopot said, Quote:Is this a pure e4 app?
In addition, what version of Eclipse are you targeting? (4.2.2, 4.3.0, ... ?)
JD
Re: Open dynamically a part [message #1075888 is a reply to message #1075470] |
Tue, 30 July 2013 05:25  |
I have find a solution but i think that not the best way :/
So what's the best practise ?
I add a IDoubleClickListener to my TreeView :
boolean partExist = false;
for(MPart part: partService.getParts() ){
if(part.getLabel().equals(event.getSelection().toString())){
partService.showPart(part, PartState.ACTIVATE);
partExist=true;
if(partExist)break;
if(!partExist){
MPart part = partService
.createPart("com.itf.tvt.tool.datastore.gui.partdescriptor.dataseteditor");
part.setLabel(event.getSelection().toString());
// // If multiple parts of this type is allowed
// // in the application model,
// // then the provided part will be shown
// // and returned
partService.showPart(part, PartState.ACTIVATE);}
[Updated on: Wed, 31 July 2013 04:29] by Moderator
FUDForum. Page generated in 0.04562 seconds
