Home » Language IDEs » Java Development Tools (JDT) » M9: Refactoring / change signature
M9: Refactoring / change signature [message #158773] |
Fri, 14 May 2004 14:44  |
Originally posted by: rndzank.comcast.net.not_this.net
For some reason, this refactoring doesn't work for me (just tried it in I0514) -
whatever change I make, after OK, nothing happens. Also, if I open preview,
there are no changes shown.
Is this unfinished feature? Bad configuration?
thx
r.
Re: M9: Refactoring / change signature [message #158830 is a reply to message #158808] |
Fri, 14 May 2004 18:39   |
Strange, I created a small example, and everything works.
The problems I had were in a project and workspace created and copied from
previous builds (M8, several Ixxx and Nxxx builds have let their
footprints in the workspace as well, I'm sure).
Will try new workspace, because the existing (after deleting
..metadata dir) complains when importing the project - something
about "Attempted to beginRule: R/, does not match outer scope rule:
P:/....".
No clue...
r.
Adam Kiezun wrote:
>> in I0514) - whatever change I make, after OK, nothing happens. Also,
>> if I open preview, there are no changes shown.
>> thx
>> r.
> works for me in m7.
> show us your test case.
> a.
Re: M9: Refactoring / change signature [message #158924 is a reply to message #158870] |
Sun, 16 May 2004 22:39   |
Please, is there anyone with any suggestion?
So far I found that no matter how I configure and compile the project,
some packages can be searched, and some not (and consequence is that
some can be refactored, some not).
What I tried and didn't help:
- remove built class files and rebuild
- refresh the project
- clean and build
- remove index files from jdt.core
- edit the .classpath file and change order of source directories
Little about the project structure:
- several source dirs
- several include/exclude patterns
r.
> Adam, you are right. The project has basic problems with Java searching.
> The project is big one and quite messy.
> Is there a chance to get a guess what could be the critical point there?
> Thanks
> r.
>>> from
>>> P:/....".
>>> No clue...
>> refactorings like 'change sig' use java search. if search returns no
>> refs to a method, the refactoring can do nothing.
>> you can use that test to verify if it's refactoring that's broken or
>> something in lower layers.
>> a.
Re: M9: Refactoring / change signature [message #158956 is a reply to message #158924] |
Mon, 17 May 2004 05:39   |
It looks like you ran into
https://bugs.eclipse.org/bugs/show_bug.cgi?id=62267.
I don't know any workaround at this time. Sorry.
Jerome
"Richard Nemec" <rndzank.comcast.net@not_this.net> wrote in message
news:c89880$o0i$1@eclipse.org...
> - clean and build
> Thanks
> r.
> > Thanks
> > r.
> >>> from
> >>> P:/....".
> >>> No clue...
> >> a.
Re: M9: Refactoring / change signature [message #158964 is a reply to message #158956] |
Mon, 17 May 2004 05:56   |
Wouldn't that bug cause consistent no-search/no-refactoring
across the whole workspace?
In my case, I can search/refactor some packages but cannot
others.
> Jerome
>>- clean and build
>>Thanks
>>r.
>>>Thanks
>>>r.
>>>>>from
>>>>>P:/....".
>>>>>No clue...
>>>>a.
Re: M9: Refactoring / change signature [message #159021 is a reply to message #158964] |
Mon, 17 May 2004 06:57   |
If you have steps to reproduce, please enter a bug report and I will
investigate.
news:c8a1ra$hqt$1@eclipse.org...
> others.
> > Jerome
> >>- clean and build
> >>Thanks
> >>r.
searching.
there?
> >>>Thanks
> >>>r.
> >>>>>from
> >>>>>P:/....".
> >>>>>No clue...
> >>>>a.
Re: M9: Refactoring / change signature [message #159037 is a reply to message #159021] |
Mon, 17 May 2004 08:17   |
Jerome, thanks for provoking me to finding the steps to reproduce.
Basically I reduced the whole project to single source directory
with some INCLUDEs and come EXCLUDEs. And there you have the problem:
- if ANY includes are present, the search and refactoring is crippled
- if ONLY excludes are configured for the project, search and refact.
are just fine
I cannot afford creating and watching a bug report - would it be possible
to file one with these steps? (just one new project with few sources and
some INCLUDE dirs) Or, perhaps, there already has been something filed?
r.
P.S. The more detailed steps are:
- Plain M9 (0514) install
- new workspace, new project
- new source dir and few java classes in some packages
- configure project to INCLUDE some packages
- the included packages will not have search capabilities
> investigate.
>>others.
>>>Jerome
>>>>- clean and build
>>>>Thanks
>>>>r.
> searching.
> there?
>>>>>Thanks
>>>>>r.
>>>>>>>from
>>>>>>>P:/....".
>>>>>>>No clue...
>>>>>>a.
Re: M9: Refactoring / change signature [message #159060 is a reply to message #159037] |
Mon, 17 May 2004 09:03   |
I'm not aware of such a problem (there is no existing bug report that
describes this problem).
I just tried the steps you gave and it worked fine for me. You will have to
give even more detailed steps such as what include pattern you use, what are
the name of the packages, what search query failed, etc.
Jerome
news:c8aa39$sis$1@eclipse.org...
> are just fine
> Thanks
> r.
> > investigate.
> >>others.
> >>>Jerome
> >>>>- clean and build
> >>>>Thanks
> >>>>r.
> > searching.
> > there?
> >>>>>Thanks
> >>>>>r.
copied
> >>>>>>>from
> >>>>>>>P:/....".
> >>>>>>>No clue...
> >>>>>>a.
Re: M9: Refactoring / change signature [message #159147 is a reply to message #159060] |
Mon, 17 May 2004 20:43   |
Here are the steps I just recreated. Thanks for looking into that.
Plain install I0514 (I'm on Win2003 if that matters)
No plugins
Start
Create new Java project ABC
Separate source and classes
Finish
Create package com.abc.one
In that package, create class ABC (OK all defaults)
In that class, create method 'public void abc() {}'
Put cursor on the method and
- Shift-Alt-C (refactor signature)
- Alt-A (add arg)
- Alt-W (preview)
- the diff shows the method to be refactored (and the tree on the top shows
class structure)
Now, go to project preferences
Open JavaBuildPath/Source, select ABC/src/inclusion filter
Click Edit
Add 'com/' and close everything (OK)
Repeat the refactoring with preview:
- Alt-A (add arg)
- Alt-W (preview)
- the diff doesn't show any changes and the tree on the top doesn't shows the
class structure
> Jerome
>> are just fine
>>Thanks
>>r.
>>>investigate.
>>>>others.
>>>>>Jerome
>>>>>>- clean and build
>>>>>>Thanks
>>>>>>r.
>>>searching.
>>>there?
>>>>>>>Thanks
>>>>>>>r.
> copied
>>>>>>>>>from
>>>>>>>>>P:/....".
>>>>>>>>>No clue...
>>>>>>>>a.
Re: M9: Refactoring / change signature [message #159155 is a reply to message #159147] |
Mon, 17 May 2004 20:48   |
Also can be reproduced in I0517 :(
r.
> No plugins
> Start
> Finish
> - Alt-A (add arg)
> - Alt-W (preview)
> shows class structure)
> Click Edit
> - Alt-A (add arg)
> - Alt-W (preview)
> shows the class structure
>> have to
>> what are
>> Jerome
>>> are just fine
>>> possible
>>> Thanks
>>> r.
>>>> investigate.
>>>>> others.
>>>>>> Jerome
>>>>>>> project,
>>>>>>> - clean and build
>>>>>>> Thanks
>>>>>>> r.
>>>> searching.
>>>> there?
>>>>>>>> Thanks
>>>>>>>> r.
>> copied
>>>>>>>>>> from
>>>>>>>>>> rule:
>>>>>>>>>> P:/....".
>>>>>>>>>> No clue...
>>>>>>>>> returns no
>>>>>>>>> broken or
>>>>>>>>> a.
Re: M9: Refactoring / change signature [message #159172 is a reply to message #159155] |
Tue, 18 May 2004 04:36   |
Thanks for your steps. I now understand the problem. I've entered
https://bugs.eclipse.org/bugs/show_bug.cgi?id=62608 to track it down. Add
yourself to the CC list if you want to be notified when it is resolved.
Also, in the meantime you can use 'com/**' as the inclusion filter. This
should work as you expect.
Jerome
news:c8bm42$k8n$1@eclipse.org...
> r.
> > No plugins
> > Start
> > Finish
> > - Alt-A (add arg)
> > - Alt-W (preview)
> > Click Edit
> > - Alt-A (add arg)
> > - Alt-W (preview)
> >> have to
> >> what are
> >> Jerome
> >>> are just fine
> >>> possible
and
filed?
> >>> Thanks
> >>> r.
> >>>> investigate.
> >>>>> others.
> >>>>>> Jerome
> >>>>>>> project,
that
> >>>>>>> - clean and build
> >>>>>>> Thanks
> >>>>>>> r.
> >>>> searching.
> >>>> there?
> >>>>>>>> Thanks
> >>>>>>>> r.
> >> copied
> >>>>>>>>>> from
their
> >>>>>>>>>> rule:
> >>>>>>>>>> P:/....".
> >>>>>>>>>> No clue...
> >>>>>>>>> returns no
> >>>>>>>>> broken or
> >>>>>>>>> a.
Re: M9: Refactoring / change signature [message #159249 is a reply to message #159218] |
Tue, 18 May 2004 09:10  |
You're welome. With good steps, it's easier to fix :-)
news:c8cvig$491$1@eclipse.org...
> Whoa! You already fixed it!
> THANKS Jerome!
> r.
> P.S. If I find time I'll try to find steps to reproduce another issue
> with project with overlapping sources where I had to configure the second
> source using exclusion entry to include some dirs. But that may be more
> complicated. Anyway, thanks a lot.
Add
> > Jerome
Current Time: Sun Aug 17 00:51:25 EDT 2025
Powered by FUDForum. Page generated in 0.07824 seconds
