Home » Language IDEs » AspectJ » ajdt on luna?
| Re: ajdt on luna? [message #1219650 is a reply to message #1081426] |
Thu, 05 December 2013 03:44   |
Hallo all,
I have a problem with opening project in Jubula.
When I go menu---Test---open
error message appears said:
An error occured
Reason: 3004: Unexpected error occured
Can anyone help me ?
Details:
3004: Unexpected error occurred.
org.eclipse.e4.core.di.InjectionException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: org.h2.jdbc.JdbcSQLException: General error: java.lang.RuntimeException: File ID mismatch got=0 expected=37 pos=33183 true org.h2.store.DiskFile:C:\Users\Louis\.jubula\database\embedded.data.db blockCount:0; SQL statement:
SELECT ID, CLASS_ID, IS_ACTIVE, IS_GENERATED, GUID, COMM_TXT, NAME, PARENT_PROJ, TIMESTAMP, VERSION, FK_PARAM_INTERFACE, CONF_MAJ_VERS, AUT_CONT, EXECOBJ_CONT, SPECOBJ_CONT, TDC_CONT, PROJECT_PROPERTIES FROM NODE WHERE ((CONF_MAJ_VERS = ?) AND (CLASS_ID = ?)) [50000-117]
Error Code: 50000
Call: SELECT ID, CLASS_ID, IS_ACTIVE, IS_GENERATED, GUID, COMM_TXT, NAME, PARENT_PROJ, TIMESTAMP, VERSION, FK_PARAM_INTERFACE, CONF_MAJ_VERS, AUT_CONT, EXECOBJ_CONT, SPECOBJ_CONT, TDC_CONT, PROJECT_PROPERTIES FROM NODE WHERE ((CONF_MAJ_VERS = ?) AND (CLASS_ID = ?))
bind => [2 parameters bound]
Query: ReadAllQuery(referenceClass=ProjectPO sql="SELECT ID, CLASS_ID, IS_ACTIVE, IS_GENERATED, GUID, COMM_TXT, NAME, PARENT_PROJ, TIMESTAMP, VERSION, FK_PARAM_INTERFACE, CONF_MAJ_VERS, AUT_CONT, EXECOBJ_CONT, SPECOBJ_CONT, TDC_CONT, PROJECT_PROPERTIES FROM NODE WHERE ((CONF_MAJ_VERS = ?) AND (CLASS_ID = ?))")
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:231)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:212)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:831)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:724)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:708)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:647)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.jubula.app.Launcher.start(Launcher.java:242)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DatabaseException
Error Code: 50000
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:333)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:644)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:535)
at org.eclipse.persistence.internal.sessions.AbstractSession.basicExecuteCall(AbstractSession.java:1717)
at org.eclipse.persistence.sessions.server.ServerSession.executeCall(ServerSession.java:566)
at org.eclipse.persistence.sessions.server.ClientSession.executeCall(ClientSession.java:207)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:207)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:193)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeSelectCall(DatasourceCallQueryMechanism.java:264)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.selectAllRows(DatasourceCallQueryMechanism.java:646)
at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectAllRowsFromTable(ExpressionQueryMechanism.java:2611)
at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectAllRows(ExpressionQueryMechanism.java:2570)
at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLevelReadQuery(ReadAllQuery.java:420)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1081)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:844)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1040)
at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:392)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1128)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2871)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1516)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1498)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1463)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.executeReadQuery(EJBQueryImpl.java:485)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.getResultList(EJBQueryImpl.java:742)
at org.eclipse.jubula.client.core.persistence.ProjectPM.findAllProjects(ProjectPM.java:156)
at org.eclipse.jubula.client.core.persistence.ProjectPM.findAllProjects(ProjectPM.java:130)
at org.eclipse.jubula.client.ui.rcp.handlers.project.OpenProjectHandler.checkAllAvailableProjects(OpenProjectHandler.java:382)
at org.eclipse.jubula.client.ui.rcp.handlers.project.OpenProjectHandler.executeImpl(OpenProjectHandler.java:534)
at org.eclipse.jubula.client.ui.handlers.AbstractHandler.execute(AbstractHandler.java:46)
at org.eclipse.jubula.client.ui.handlers.project.AbstractProjectHandler.execute(AbstractProjectHandler.java:35)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 34 more
Caused by: org.h2.jdbc.JdbcSQLException: General error: java.lang.RuntimeException: File ID mismatch got=0 expected=37 pos=33183 true org.h2.store.DiskFile:C:\Users\Louis\.jubula\database\embedded.data.db blockCount:0; SQL statement:
at org.h2.message.Message.getSQLException(Message.java:105)
at org.h2.message.Message.convert(Message.java:274)
at org.h2.message.Message.convert(Message.java:243)
at org.h2.command.Command.executeQueryLocal(Command.java:144)
at org.h2.command.Command.executeQuery(Command.java:123)
at org.h2.jdbc.JdbcPreparedStatement.executeQuery(JdbcPreparedStatement.java:99)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeSelect(DatabaseAccessor.java:931)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:607)
... 69 more
Caused by: java.lang.RuntimeException: File ID mismatch got=0 expected=37 pos=33183 true org.h2.store.DiskFile:C:\Users\Louis\.jubula\database\embedded.data.db blockCount:0
at org.h2.message.Message.throwInternalError(Message.java:185)
at org.h2.store.DiskFile.getRecord(DiskFile.java:571)
at org.h2.store.Storage.getRecord(Storage.java:94)
at org.h2.index.ScanIndex.getNextRow(ScanIndex.java:259)
at org.h2.index.ScanCursor.next(ScanCursor.java:62)
at org.h2.table.TableFilter.next(TableFilter.java:319)
at org.h2.command.dml.Select.queryFlat(Select.java:493)
at org.h2.command.dml.Select.queryWithoutCache(Select.java:561)
at org.h2.command.dml.Query.query(Query.java:236)
at org.h2.command.CommandContainer.query(CommandContainer.java:82)
at org.h2.command.Command.executeQueryLocal(Command.java:142)
... 73 more
Current Time: Wed Nov 05 19:01:22 EST 2025
Powered by FUDForum. Page generated in 0.02870 seconds
