Home » Archived » BIRT » how to pass parameter for year,quarter,month
how to pass parameter for year,quarter,month [message #1073297] Wed, 24 July 2013 09:37 Go to next message
sir i have attached a report which i have created in sample db for my requirement but its showing some error and i dono how to pass parameter by script in before open so can u able to pass parameter i.e i can't able to pass parameter for year,quarter,month
kindly provide sampledb for this ..its urgent needed...
thank u in advance
Re: how to pass parameter for year,quarter,month [message #1073458 is a reply to message #1073297] Wed, 24 July 2013 17:03 Go to previous message
Take a look at this modified report. I used a separate dataSet to fill the values for the parameters and created a display value field to look like the fields you wanted and an integer field of just the straight month and quarter value for the actual parameter value. This really only needs to be done for the month.
Then, I added a couple lines to your beforeOpen script of your msrp dataSet to limit the query results by the parameter values selected.
Hope this helps.
Previous Topic:Birt view internalizational
Next Topic:Barcodes? - barcode4j?
Current Time: Thu Nov 06 15:51:15 EST 2025
Powered by FUDForum. Page generated in 0.04154 seconds
