Dali and Plug-in Tooling Conflicts [message #1069259] |
Mon, 15 July 2013 14:37 |
I am trying to create a plug-in that wraps JPA (EclipseLink) and exposes a small number of my own persistence methods. I've set up a JSE plugin project and added the JPA facet. The tools base is:
Kepler: 4.3.0 Build id: I20130605-2000
Dali EclipseLink and JPA Support: 3.3.0
I am not using Maven.
I want to use both eclipse plug-in tools and JPA (Dali) tools. The problem I'm facing is that the plugin tooling wants the META-INF folder to be located directly off the project root folder while the Dali tooling wants the META-INF folder to be located within the project/src folder.
For example, when META-INF is located at the project root, I get generation errors from "JPA Tools -> Generate Tables from Entities..." presumably because it can't locate persistence.xml When I move META-INF under the src folder, I can generate tables but I get dependency resolution errors because my plug-in dependencies can't be resolved by the plugin builder.
Am I missing something or does anyone have reasonable workarounds?
Pls let me know if there's a better spot in the forums to post this.
Thanks.
FUDForum. Page generated in 0.03505 seconds
