Generate qvtr file programmatically [message #1069206] |
Mon, 15 July 2013 12:15 |
Simon Schwichtenberg Messages: 127 Registered: September 2011 |
I want to generate a simple qvtr file programmatically. My idea was to exploit the qvtd Xtext editor: I want to make changes to the in-memory representation of the ecore model and use the xtext serialization to write the model to a file.
I am using QVTd 0.9.0 since I am on Juno (in 0.9.0 the import declaration cause parse errors, that why they are in comments)
In a first step, I load a template file and try to make a copy of it, which fails.
--import requester:'requester.ecore'::requester;
--import provider:'provider.ecore'::provider;
transformation model2requester(source:provider, target:requester){
my code is as follows:
private TopLevelCS root;
private RelationModel rm;
private URI uri;
private void initialize(){
//new VTrelationStandaloneSetup().createInjectorAndDoEMFRegistration();
QVTrelationStandaloneSetup.doSetup();
URI templateUri = URI.createPlatformPluginURI("/"+Activator.ID+"/qvtr/template.qvtr",true);
ResourceSet rs = new ResourceSetImpl();
Resource templateResource = rs.getResource(templateUri, true);
root = (TopLevelCS) templateResource.getContents().get(0);
rm = (RelationModel) root.getPivot();
org.eclipse.ocl.examples.pivot.Package pack = rm.getNestedPackage().get(0);
XtextResource r = (XtextResource) rs.createResource(uri);
r.getContents().add(rm);
r.setValidationDisabled(true);
SaveOptions.Builder b = SaveOptions.newBuilder();
b.noValidation();
b.format();
Map options = b.getOptions().toOptionsMap();
try {
r.save(options);
} catch (IOException e2) {
e2.printStackTrace();
What I get is:
org.eclipse.xtext.parsetree.reconstr.XtextSerializationException: Serialization failed
<# of serialized tokens>: <EObject path> "<serializable fragment, starting from the end>":
-> <possible reasons for not continuing>
1:RelationModel'template.qvtr': "'template.qvtr'":
-> StringLiteralExpCS_NameAssignment: NamedElement(RelationModel).name is not set.
-> Can not leave rule 'StringLiteralExpCS' since the current object 'RelationModel' has features with unconsumed values: 'nestedPackage':1
at org.eclipse.xtext.parsetree.reconstr.impl.AbstractParseTreeConstructor.serialize(AbstractParseTreeConstructor.java:686)
at org.eclipse.xtext.parsetree.reconstr.impl.AbstractParseTreeConstructor.serialize(AbstractParseTreeConstructor.java:693)
at org.eclipse.xtext.parsetree.reconstr.impl.AbstractParseTreeConstructor.serializeSubtree(AbstractParseTreeConstructor.java:716)
at org.eclipse.xtext.parsetree.reconstr.Serializer.serialize(Serializer.java:61)
at org.eclipse.xtext.parsetree.reconstr.Serializer.serialize(Serializer.java:67)
at org.eclipse.xtext.resource.XtextResource.doSave(XtextResource.java:316)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1417)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:986)
The error message confuses me, because RelationModel.name is set. How can I solve this?
Simon
Re: Generate qvtr file programmatically [message #1069226 is a reply to message #1069206] |
Mon, 15 July 2013 13:04 |
Ed Willink Messages: 7655 Registered: July 2009 |
Sorry. The Pivot2CS functionality is really only implemented for OCL,
where it is critical to the Ecore->Pivot->Text for the OCLinEcore editor
and is also used by an API-less UML->Pivot->OCLcs CompleteOCLSplitter
facility.
The QVT extensions to OCL do not differ dramatically between AS and CS
so it shouldn't be that hard to emulate for instance the two classes in
org.eclipse.ocl.examples.xtext.oclinecore.pivot2cs to realize
org.eclipse.qvtd.xtext.qvtrelation.pivot2cs. However while the Xtext
serialization capability is powerful, it can also be troublesome. There
is no problem in multiple concrete syntazes producing the same abstract
syntax. In the reverse direction the serializer can be obscure while
warning you that it doesn't know how to resolve an ambiguity. Sometimes
the Xtext grammar exposition has to be revised.
Doing this is low on my priority list because there is separate work on
auto-generating the AS <> CS mappings and so any manual contribution now
will be discarded in a year or so.
Ed Willink
On 15/07/2013 13:15, Goood Guy wrote:
> which fails.
> private URI uri;
> URI templateUri =
> b.noValidation();
> b.format();
> try {
> r.save(options);
> What I get is:
> at
> at
> at
> at
> at
> at
> at
> at
> can I solve this?
> Regards,
> Simon
FUDForum. Page generated in 0.04741 seconds
