Home » Modeling » QVT-Relations » Generate qvtr file programmatically
Generate qvtr file programmatically [message #1069206] Mon, 15 July 2013 08:15 Go to next message
I want to generate a simple qvtr file programmatically. My idea was to exploit the qvtd Xtext editor: I want to make changes to the in-memory representation of the ecore model and use the xtext serialization to write the model to a file.
I am using QVTd 0.9.0 since I am on Juno (in 0.9.0 the import declaration cause parse errors, that why they are in comments)
In a first step, I load a template file and try to make a copy of it, which fails.
--import requester:'requester.ecore'::requester;
--import provider:'provider.ecore'::provider;
transformation model2requester(source:provider, target:requester){
my code is as follows:
private TopLevelCS root;
private RelationModel rm;
private URI uri;
private void initialize(){
//new VTrelationStandaloneSetup().createInjectorAndDoEMFRegistration();
		QVTrelationStandaloneSetup.doSetup();
		URI templateUri = URI.createPlatformPluginURI("/"+Activator.ID+"/qvtr/template.qvtr",true);
		ResourceSet rs = new ResourceSetImpl();
		Resource templateResource = rs.getResource(templateUri, true);
		root = (TopLevelCS) templateResource.getContents().get(0);
		rm = (RelationModel) root.getPivot();
		org.eclipse.ocl.examples.pivot.Package pack = rm.getNestedPackage().get(0);
		XtextResource r = (XtextResource) rs.createResource(uri);
		r.getContents().add(rm);
		r.setValidationDisabled(true);
		SaveOptions.Builder b = SaveOptions.newBuilder();
		b.noValidation();
		b.format();
		Map options = b.getOptions().toOptionsMap();
		try {
			r.save(options);
		} catch (IOException e2) {
			// TODO Auto-generated catch block
			e2.printStackTrace();
What I get is:
org.eclipse.xtext.parsetree.reconstr.XtextSerializationException: Serialization failed
<# of serialized tokens>: <EObject path> "<serializable fragment, starting from the end>":
-> <possible reasons for not continuing>
1:RelationModel'template.qvtr': "'template.qvtr'":
-> StringLiteralExpCS_NameAssignment: NamedElement(RelationModel).name is not set.
-> Can not leave rule 'StringLiteralExpCS' since the current object 'RelationModel' has features with unconsumed values: 'nestedPackage':1
at org.eclipse.xtext.parsetree.reconstr.impl.AbstractParseTreeConstructor.serialize(AbstractParseTreeConstructor.java:686)
at org.eclipse.xtext.parsetree.reconstr.impl.AbstractParseTreeConstructor.serialize(AbstractParseTreeConstructor.java:693)
at org.eclipse.xtext.parsetree.reconstr.impl.AbstractParseTreeConstructor.serializeSubtree(AbstractParseTreeConstructor.java:716)
at org.eclipse.xtext.parsetree.reconstr.Serializer.serialize(Serializer.java:61)
at org.eclipse.xtext.parsetree.reconstr.Serializer.serialize(Serializer.java:67)
at org.eclipse.xtext.resource.XtextResource.doSave(XtextResource.java:316)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1417)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:986)
The error message confuses me, because RelationModel.name is set. How can I solve this?
Simon
Re: Generate qvtr file programmatically [message #1069226 is a reply to message #1069206] Mon, 15 July 2013 09:04 Go to previous messageGo to next message
Sorry. The Pivot2CS functionality is really only implemented for OCL,
where it is critical to the Ecore->Pivot->Text for the OCLinEcore editor
and is also used by an API-less UML->Pivot->OCLcs CompleteOCLSplitter
facility.
The QVT extensions to OCL do not differ dramatically between AS and CS
so it shouldn't be that hard to emulate for instance the two classes in
org.eclipse.ocl.examples.xtext.oclinecore.pivot2cs to realize
org.eclipse.qvtd.xtext.qvtrelation.pivot2cs. However while the Xtext
serialization capability is powerful, it can also be troublesome. There
is no problem in multiple concrete syntazes producing the same abstract
syntax. In the reverse direction the serializer can be obscure while
warning you that it doesn't know how to resolve an ambiguity. Sometimes
the Xtext grammar exposition has to be revised.
Doing this is low on my priority list because there is separate work on
auto-generating the AS <> CS mappings and so any manual contribution now
will be discarded in a year or so.
Ed Willink
On 15/07/2013 13:15, Goood Guy wrote:
> which fails.
> private URI uri;
> URI templateUri =
> b.noValidation();
> b.format();
> try {
> r.save(options);
> What I get is:
> at
> at
> at
> at
> at
> at
> at
> at
> can I solve this?
> Simon
Re: Generate qvtr file programmatically [message #1069253 is a reply to message #1069226] Mon, 15 July 2013 10:16 Go to previous messageGo to next message
Thanks. I guess the next most clean way is to use a M2T transformation (e.g. xpand) instead of the xtext serialization.
Re: Generate qvtr file programmatically [message #1069279 is a reply to message #1069253] Mon, 15 July 2013 11:28 Go to previous messageGo to next message
xpand has been merged into xtend.
The Xtext serialization mostly does a good job of the M2T. Its the AS to
CS M2M that's missing, so if you did M2T directly from the AS you would
have to do the trivial QVT AS to CS but also the much less trivial OCL
AS to CS as well.
Ed Willink
Re: Generate qvtr file programmatically [message #1071180 is a reply to message #1069279] Fri, 19 July 2013 10:04 Go to previous messageGo to next message
ok, my plan now is to create the QVTrelation programmatically and create the qvtr file via an xtend transformation (my transformations are very basic, so I do not need to cover complete QVT/OCL):
root = QVTrelationFactory.eINSTANCE.createRelationModel();
transformation = QVTrelationFactory.eINSTANCE.createRelationalTransformation();
root.getNestedPackage().add(transformation);
providerPackage = PivotFactory.eINSTANCE.createPackage();
providerPackage.setName("providerPackage");
requesterPackage = PivotFactory.eINSTANCE.createPackage();
requesterPackage.setName("requesterPackage");
I think to create the Packages programmatically is no good idea respectively its hopefully unnecessary:
How can I load an Ecore model to create a Pivot model instance that contains the types from the ecore model?
Re: Generate qvtr file programmatically [message #1071219 is a reply to message #1071180] Fri, 19 July 2013 11:20 Go to previous messageGo to next message
org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot does the work.
org.eclipse.ocl.examples.pivot.manager.MetaModelmanager.loadResource
generally supports loading and loader discovery.
Search the references, for examples of usage.
Ed Willink
> transformation =
Re: Generate qvtr file programmatically [message #1078053 is a reply to message #1071219] Fri, 02 August 2013 09:28 Go to previous messageGo to next message
I wonder if there is an easier way to navigate from an EObject to the corresponding Pivot object.
At the moment I am using this code, but I hope that I can randomly access a corresponding Pivot object. But how can I do it?
private org.eclipse.ocl.examples.pivot.Type getType(org.eclipse.ocl.examples.pivot.Package p, EObject e){
		for(org.eclipse.ocl.examples.pivot.Type t:p.getOwnedType()){
			URI uriFromEcore = EcoreUtil.getURI(e);
			URI uriFromPivot = EcoreUtil.getURI(t.getETarget());
			if(uriFromEcore.equals(uriFromPivot)){
				return t;
		return null;
Re: Generate qvtr file programmatically [message #1078163 is a reply to message #1078053] Fri, 02 August 2013 12:14 Go to previous messageGo to next message
MetaModelManager.getPivotOf() will cope with UML or Ecore or ... as the
source
MetaModelManager.getPivotOfEcore() is only Ecore.
Ed Willink
> return t;
> return null;
Re: Generate qvtr file programmatically [message #1110210 is a reply to message #1078163] Mon, 16 September 2013 10:45 Go to previous messageGo to next message
when I run my application as standalone outside of Eclipse, the following code causes an error:
requesterPackage = (Package) Ecore2Pivot.importFromEcore(requesterMMManager, "", requester);
Exception in thread "main" org.eclipse.ocl.examples.pivot.utilities.IllegalLibraryException: No OCL Standard Library content available
at org.eclipse.ocl.examples.pivot.manager.PivotStandardLibrary.getRequiredLibraryType(PivotStandardLibrary.java:278)
at org.eclipse.ocl.examples.pivot.manager.PivotStandardLibrary.resolveRequiredSimpleType(PivotStandardLibrary.java:377)
at org.eclipse.ocl.examples.pivot.manager.PivotStandardLibrary.getBooleanType(PivotStandardLibrary.java:127)
at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.initializeEcore2PivotMap(Ecore2Pivot.java:482)
at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.getEcore2PivotMap(Ecore2Pivot.java:326)
at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.resolveDataType(Ecore2Pivot.java:615)
at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.resolveType(Ecore2Pivot.java:670)
at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.update(Ecore2Pivot.java:752)
at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.importObjects(Ecore2Pivot.java:467)
at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.getPivotRoot(Ecore2Pivot.java:412)
at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.importFromEcore(Ecore2Pivot.java:208)
I think I have to register something what is usually done by the Eclipse platform.
So what do I have to do to run the Ecore2Pivot in standalone mode?
Re: Generate qvtr file programmatically [message #1110219 is a reply to message #1110210] Mon, 16 September 2013 10:59 Go to previous messageGo to next message
Sorry, I should read http://help.eclipse.org/kepler/index.jsp?topic=%2Forg.eclipse.ocl.doc%2Fhelp%2FPivotStandalone.html first
Re: Generate qvtr file programmatically [message #1110495 is a reply to message #1110219] Mon, 16 September 2013 20:32 Go to previous messageGo to next message
Ok, now I execute the following code:
		    org.eclipse.ocl.examples.pivot.OCL.initialize(resourceSet);
		    org.eclipse.ocl.examples.pivot.model.OCLstdlib.install();
		    org.eclipse.ocl.examples.pivot.delegate.OCLDelegateDomain.initialize(resourceSet);
In general, this works when I execute my program as standalone.
However, I want to execute my program in terms of a 3rd party evaluation tool. The tool loads the jar files of my program dynamically. But then, I got this strange error:
Exception in thread "main" java.lang.ExceptionInInitializerError
at org.eclipse.ocl.common.internal.options.CommonOptions.<clinit>(CommonOptions.java:25)
at org.eclipse.ocl.examples.pivot.delegate.OCLDelegateDomain.initialize(OCLDelegateDomain.java:80)
at org.eclipse.ocl.examples.pivot.delegate.OCLDelegateDomain.initialize(OCLDelegateDomain.java:63)
at de.upb.swt.rsdl.data.matcher.evaluation.Owl2Ecore.setup(Owl2Ecore.java:129)
at de.upb.swt.rsdl.data.matcher.evaluation.Owl2Ecore.<init>(Owl2Ecore.java:65)
at de.upb.swt.rsdl.data.matcher.evaluation.Bridge.align(Bridge.java:101)
at eu.sealsproject.omt.client.Client.match(Client.java:318)
at eu.sealsproject.omt.client.Client.<init>(Client.java:244)
at eu.sealsproject.omt.client.Client.main(Client.java:117)
Caused by: java.lang.NullPointerException
at org.eclipse.ocl.common.OCLConstants.<clinit>(OCLConstants.java:22)
... 9 more
See http://git.eclipse.org/c/mdt/org.eclipse.ocl.git/tree/plugins/org.eclipse.ocl.common/src/org/eclipse/ocl/common/internal/options/CommonOptions.java and http://git.eclipse.org/c/mdt/org.eclipse.ocl.git/tree/plugins/org.eclipse.ocl.common/src/org/eclipse/ocl/common/OCLConstants.java.
So, OCLConstants.class.getPackage() returns null. I've exported my plugin as a runnable jar file to include all dependencies. Maybe the problem arises from a repackaging. On the other hand maybe the dependencies cannot be loaded by the evaluation tool. Does anyone have an idea what is going wrong?
Or the
Re: Generate qvtr file programmatically [message #1110652 is a reply to message #1110495] Tue, 17 September 2013 02:32 Go to previous messageGo to next message
<clinit> is often a bad class initialization.
I'm a bit confused that
public interface OCLConstants
public static final String PLUGIN_ID =
OCLConstants.class.getPackage().getName();
can go wrong. I can only suggest that you help the Java init out by invoking
OCLConstants.class.getName() yourself before referencing any of its content.
Ed Willink
> at
> at
> at
> at
> at
> at
> at
> ... 9 more
> See
> and
> Or the
Re: Generate qvtr file programmatically [message #1854019 is a reply to message #1110652] Thu, 28 July 2022 04:41 Go to previous message
JFYI I tried years ago and had the same issues with all the OCL pivots and stuff
The goal was to generate a qvtr to copy models elements in a model (It is not easy with QVTR or at least it was not years ago), based on the publication https://github.com/perelengo/qvtr-copy-paterns/blob/master/Refinement_Transformation_Support_for_QVT_Relational_Transformations.pdf
, so in the end i resolved by generating an QVT AST with XSL. And then print the AST to QVTR with a XSL printer:
https://github.com/perelengo/qvtr-copy-paterns/blob/master/ecore_metamodel_to_copy_qvtr.qvtr -> This takes the ecore schema and generates the QVTR AST
https://github.com/perelengo/qvtr-copy-paterns/blob/master/qvt-pretty-printer.xsl -> this gets the AST and prints the QVTR
Maybe helps having a side solution.
Previous Topic:Developing plugins that use qvt-r
Next Topic:Drops and Updates are now Builds
Current Time: Fri Oct 31 11:42:46 EDT 2025
Powered by FUDForum. Page generated in 0.05751 seconds
