| Ant error reporting [message #157647] |
Mon, 17 November 2003 04:33  |
Originally posted by: sthoden.web.de
When I started Ant within Eclipse I got less output,
compared to invoking Ant over a command line interface?
I checked the all ant options in the dialog Window/preferences,
but no improvement.
BTW: I'm using Ant in combination with IDLgen.
Any hints?
TIA svente
| Re: Ant error reporting [message #157774 is a reply to message #157647] |
Mon, 17 November 2003 10:53  |
Which version of Eclipse are you using?
Which version of Ant are you using with Eclipse?
Which version of Ant do you use at the commandline?
Are you using the same Java VM for both Ant builds?
Are you sure at the command line you are not specifying -verbose?
If the Eclipse Ant you are using matches the commandline Ant version, I
would appreciate a bug report with a build file that exhibits the differing
behavior.
BTW, what is IDLgen?
Darins
"Sven Thoden" <sthoden@web.de> wrote in message
news:bpa4gr$htf$1@eclipse.org...
> but no improvement.
> Any hints?
> TIA svente
FUDForum. Page generated in 0.50356 seconds
