Home » Modeling » Papyrus » How to add a Node in the Nodes field?
How to add a Node in the Nodes field? [message #1068183] Fri, 12 July 2013 10:41 Go to next message
Hi, I'm searching for a long time how to make my own node and
put it in the Nodes field in the Palette.
All the tutorials that I saw, only say the same thing, the basic
how to use the papyrus.
Thanks Very Happy
Re: How to add a Node in the Nodes field? [message #1069212 is a reply to message #1068183] Mon, 15 July 2013 08:28 Go to previous messageGo to next message
If you want to create a tool in the palette for a profile stereotype:
- create your uml profile (you can use Papyrus to create a profile). The stereotype must extend a model element, for which there is already a tool in Papyrus.
- load the profile into the uml model, where you want to use the stereotype (select the root "Model" element in the model explorer view. rightclick on the element and load the profile).
- rightclick on the palette and choose "customize" and create the tool for the stereotype (there is a section that is called "stereotype application" or so)
Re: How to add a Node in the Nodes field? [message #1074014 is a reply to message #1069212] Thu, 25 July 2013 19:51 Go to previous messageGo to next message
Thanks man, I will try, but I coudn't load
nothing, only import, and the created profile
doesn't appear...
Re: How to add a Node in the Nodes field? [message #1074152 is a reply to message #1074014] Fri, 26 July 2013 03:46 Go to previous messageGo to next message
You need to "apply" the profile (From the "Profile" tab in the properties view of your UML Model). "Apply" is different from "Import": To use a profile, you need to apply it. To extend a profile, you need to import it.
Camille
Re: How to add a Node in the Nodes field? [message #1823636 is a reply to message #1074152] Mon, 30 March 2020 10:38 Go to previous messageGo to next message
does Customize Palette still work this way currently? I tried in version 2020-03 to add an element in the palette for a profile stereotype I created. I applied the profile to my model, and I could open "Customize Palette", but there was no option to add a new palette, I can only rename the elements:
index.php/fa/37708/0/
[Updated on: Tue, 31 March 2020 03:07] by Moderator
Re: How to add a Node in the Nodes field? [message #1834101 is a reply to message #1823636] Mon, 02 November 2020 11:59 Go to previous messageGo to next message
Hello Susanne, I am having the same issue as you were concerning the palette customisation. Were you able to fix that?
Thank you!
Re: How to add a Node in the Nodes field? [message #1834102 is a reply to message #1823636] Mon, 02 November 2020 12:00 Go to previous message
Thank you!
Previous Topic:Enable display of stereotype compartments from language extension plugins
Next Topic:Palette Customization Papyrus 2020
Current Time: Sun Oct 19 05:00:33 EDT 2025
Powered by FUDForum. Page generated in 0.32725 seconds
