Home » Language IDEs » C / C++ IDE (CDT) » Max heap 512m(Eclipse .ini won't allow the heap to be increased)
Max heap 512m [message #1067677] Wed, 10 July 2013 00:05 Go to next message
I am trying to compile a program with a large header file, and so I tried to change the values in the eclipse.ini file. It will allow me to change all of the values except for the max heap size. That is stuck at 512 MB. If I make it any bigger, eclipse fails to start with "Failed to start the Java VM".Does anybody know a fix for this?
Thanks.
Re: Max heap 512m [message #1067944 is a reply to message #1067677] Thu, 11 July 2013 07:26 Go to previous messageGo to next message
What did you exactly change in the eclipse.ini file? In principle, you should replace the line "-Xmx384m" with "-Xmx1024m".
Re: Max heap 512m [message #1067949 is a reply to message #1067944] Thu, 11 July 2013 07:56 Go to previous messageGo to next message
I only changed the numbers. Everything else is "out of the box". The settings shown below cause the error. If I change it back to -Xmx512m it works fine.
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.200.v20130521-0416
-product
org.eclipse.epp.package.cpp.product
--launcher.defaultAction
openFile
--launcher.XXMaxPermSize
1024M
-showsplash
org.eclipse.platform
1024m
openFile
--launcher.appendVmargs
-vmargs
-Dosgi.requiredJavaVersion=1.6
-Xms256m
-Xmx1024m
Re: Max heap 512m [message #1067990 is a reply to message #1067949] Thu, 11 July 2013 11:07 Go to previous messageGo to next message
You should not increase the XXMaxPermSize.
Re: Max heap 512m [message #1068049 is a reply to message #1067990] Thu, 11 July 2013 15:33 Go to previous message
I had forgotten I'd done that. Anyways - that worked. Thanks!! You rock!
Previous Topic:How to use Eclipse with OpenCV liabrary
Next Topic:Eclipse marks macros from inttypes.h as syntax errors
Current Time: Thu Sep 25 23:45:30 EDT 2025
Powered by FUDForum. Page generated in 0.04063 seconds
