Re: eclipse is freezing when build workspace [message #1067578 is a reply to message #1067541] |
Tue, 09 July 2013 12:15 |
Ed Merks Messages: 33142 Registered: July 2009 |
Edit your eclipse.ini file and increase the value for the -Xmx1024m
option. Note that with a 32bit VM there's a limit on how big you can
make it so if you make it too big, the VM won't start.
On 09/07/2013 1:05 PM, li tan wrote:
> Message:An internal error occurred during: "Build Project".
> Exception Stack Trace:
> eclipse.buildId=I20120608-1400
> java.version=1.7.0_25
> java.vendor=Oracle Corporation
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
> Framework arguments: -product org.eclipse.epp.package.jee.product
> Command-line arguments: -os win32 -ws win32 -arch x86 -product
> Error
> Tue Jul 09 17:03:28 CST 2013
> java.lang.OutOfMemoryError: Java heap space
> at
> org.eclipse.wst.jsdt.internal.compiler.parser.Parser.isErrorState(Parser.java:5549)
> at
> org.eclipse.wst.jsdt.internal.compiler.parser.Parser.parse(Parser.java:5679)
> at
> org.eclipse.wst.jsdt.internal.compiler.parser.Parser.parse(Parser.java:6036)
> at
> org.eclipse.wst.jsdt.internal.compiler.parser.Parser.parse(Parser.java:5988)
> at
> org.eclipse.wst.jsdt.internal.compiler.parser.Parser.dietParse(Parser.java:4593)
> at
> org.eclipse.wst.jsdt.internal.compiler.Compiler.internalBeginToCompile(Compiler.java:559)
> at
> org.eclipse.wst.jsdt.internal.compiler.Compiler.beginToCompile(Compiler.java:328)
> at
> org.eclipse.wst.jsdt.internal.compiler.Compiler.compile(Compiler.java:342)
> at
> org.eclipse.wst.jsdt.internal.core.builder.AbstractImageBuilder.compile(AbstractImageBuilder.java:288)
> at
> org.eclipse.wst.jsdt.internal.core.builder.BatchImageBuilder.compile(BatchImageBuilder.java:86)
> at
> org.eclipse.wst.jsdt.internal.core.builder.AbstractImageBuilder.compile(AbstractImageBuilder.java:227)
> at
> org.eclipse.wst.jsdt.internal.core.builder.BatchImageBuilder.build(BatchImageBuilder.java:58)
> at
> org.eclipse.wst.jsdt.internal.core.builder.JavaBuilder.buildAll(JavaBuilder.java:291)
> at
> org.eclipse.wst.jsdt.internal.core.builder.JavaBuilder.build(JavaBuilder.java:199)
> at
> org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
> at
> org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
> at
> org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
> at
> org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
> at
> org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
> at
> org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
> at
> org.eclipse.core.internal.resources.Workspace.buildInternal(Workspace.java:513)
> at
> org.eclipse.core.internal.resources.Workspace.build(Workspace.java:432)
> at
> org.eclipse.ui.actions.BuildAction$1.runInWorkspace(BuildAction.java:305)
> at
> org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
> Session Data:
> :cry:
Ed Merks
FUDForum. Page generated in 0.08260 seconds
