Re: Eclipse fails to deploy ear on Jboss [message #1066970 is a reply to message #1066956] |
Fri, 05 July 2013 09:36 |
tester tester Messages: 8 Registered: July 2012 |
I'm using JBoss Tools from marketplace already. Besides I elaborated the task and found that this "convert to maven project" creates an additional "m2e-wtp" folder in the target directory. Obviously it depends on this directory to make the Drag&Drop-deployment correctly. This additional directory also appears if one does "righclick on folder-> project facets->Jboss Maven integration".
I'm sorry if I didn't post in the correct subforum, as I don't know where exactly the error lies. It looked to me that the simple Drag&Drop feature (which exists from the beginning in an eclipse installation) does somehow an error itself, therefore I wrote in here.
However it still does not make sense, because - why is there Drag&Drop possible in the first place if it doesn't work correctly, except doing some workaround...
[Updated on: Fri, 05 July 2013 09:37] Report message to a moderator
FUDForum. Page generated in 0.03848 seconds
