Home » Eclipse Projects » Equinox » Getting a lock required more than 10000 ms.
Getting a lock required more than 10000 ms. [message #1066622] Wed, 03 July 2013 09:31 Go to next message
I have a problem with my bundles. I have a product based on eclipse and it uses Declarative Services. This product runs just fine usually.
However. When I update the product (using p2), the old bundles seem to interfere with the resolution process of my OSGI environment, and my product just freezes during launch.
In the osgi debug print I can see the following:
DEBUG 138 Resolver.disableComponents() my.bundle.osgicomponent
WARNING 138 Getting a lock required more than 10000 ms. There might be a synchronization problem in this callstack or just the build/dispose process of some components took too long!
java.lang.Exception: Debug stacktrace
	at org.eclipse.equinox.internal.ds.InstanceProcess.getLock(InstanceProcess.java:120)
	at org.eclipse.equinox.internal.ds.InstanceProcess.disposeInstances(InstanceProcess.java:293)
	at org.eclipse.equinox.internal.ds.Resolver.disposeComponentConfigs(Resolver.java:717)
	at org.eclipse.equinox.internal.ds.Resolver.disableComponents(Resolver.java:693)
	at org.eclipse.equinox.internal.ds.SCRManager.stoppingBundle(SCRManager.java:554)
	at org.eclipse.equinox.internal.ds.SCRManager.bundleChanged(SCRManager.java:233)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:847)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEventPrivileged(Framework.java:1568)
	at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1504)
	at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1499)
	at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:506)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:566)
	at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1206)
	at org.eclipse.osgi.framework.internal.core.PackageAdminImpl.suspendBundle(PackageAdminImpl.java:326)
	at org.eclipse.osgi.framework.internal.core.PackageAdminImpl.processDelta(PackageAdminImpl.java:467)
	at org.eclipse.osgi.framework.internal.core.PackageAdminImpl.doResolveBundles(PackageAdminImpl.java:251)
	at org.eclipse.osgi.framework.internal.core.PackageAdminImpl$1.run(PackageAdminImpl.java:174)
	at java.lang.Thread.run(Thread.java:722)
DEBUG 138 InstanceProcess.disposeInstances(): unregistering component my.bundle.osgicomponent
If I remove all the old bundles from the plugins directory, the problem disappears again.
I have tried a ton of things, but I'm unable to determine what I'm missing here. Even if it is polling the old bundles, they should be compatible and not have this kind of result. As a matter of fact, if I remove all but one of the old bundles and keep the one old bundle that hardly contains any code and is only used by a component indirectly, has no Imports of any of my other packages and no OSGI components itself, it STILL fails.
It would help if I understood what this getLock() failure entails exactly. What is going on in the background that this might be blocking ?
Re: Getting a lock required more than 10000 ms. [message #1067722 is a reply to message #1066622] Wed, 10 July 2013 05:54 Go to previous messageGo to next message
Remove org.eclipse.update.configurator from the product, or set org.eclipse.update.reconcile=false
Re: Getting a lock required more than 10000 ms. [message #1067785 is a reply to message #1067722] Wed, 10 July 2013 10:47 Go to previous message
I think it is the issue for the Equinox forum - http://www.eclipse.org/forums/index.php?t=thread&frm_id=31. Please post it there
Daniel
Previous Topic:p2 installation question
Next Topic:Starter Kit OSX 64 doesn't start
Current Time: Wed Nov 05 10:45:10 EST 2025
Powered by FUDForum. Page generated in 0.03995 seconds
