Home » Language IDEs » Java Development Tools (JDT) » Sysdeo Eclipse Preferences Now Broken?
Sysdeo Eclipse Preferences Now Broken? [message #157390] Wed, 05 May 2004 19:57 Go to next message
Has anyone else noticed that in the recent Eclipse builds the preferences
page for the Sysdeo tomcat plugin no longer works?
I investigated; here is the log statement:
java.lang.NoSuchMethodError:
org.eclipse.jdt.internal.ui.wizards.dialogfields.ListDialogF ield.setElements
(Ljava/util/List;)V
com.sysdeo.eclipse.tomcat.editors.ProjectListEditor.updatePr ojectsList(Proje
ctListEditor.java:65)
com.sysdeo.eclipse.tomcat.editors.ProjectListEditor.<init>(ProjectListEditor
..java:39)
com.sysdeo.eclipse.tomcat.TomcatPreferencePage.createContent s(TomcatPreferen
cePage.java:123)
org.eclipse.jface.preference.PreferencePage.createControl(Pr eferencePage.jav
a:217)
...... // etc.
The strange thing is that the latest revisions of ListDialogField in Eclipse
CVS still has the setElements(java.util.Collection) method which should
support the above perfectly fine. I thought it may be because Eclipse is
starting on JRE 1.5 on my local environment, so I started with JRE 1.4 using
the -vm tag - no luck though.
Does anyone have any bright ideas? As a workaround I installed Eclipse 2.1
in another directory and copied the Tomcat pref_store info over to the
..plugins directory under my .metadata directory. The 2.1 -> 3.0 conversion
code picked up the changes from there.
R.J.
Re: Sysdeo Eclipse Preferences Now Broken? [message #157432 is a reply to message #157390] Thu, 06 May 2004 04:30 Go to previous message
Originally posted by: thomas_maeder.ch.ibm.com
I figure the change is not binary compatible. The sysdeo plugin is using
internal classes; you'll have to wait for an updated version of the
plugin, sorry.
Thomas
> (Ljava/util/List;)V
> at
> at
> .java:39)
> at
> cePage.java:123)
> at
> a:217)
> ..... // etc.
> R.J.
Previous Topic:Debugger not working
Next Topic:Eclipse Ant Tasks don't work on using the Ant Launcher in M8
Current Time: Wed Nov 05 05:04:28 EST 2025
Powered by FUDForum. Page generated in 0.03671 seconds
