Re: Observation button and mapping buttons disabled [message #1066038 is a reply to message #1066019] |
Sat, 29 June 2013 08:45 |
Did you add the RCP accessor to your AUT? You have to copy the bundle and add a startup line to your AUT's configuration (check the documentation on configuring RCP AUTs). If you don't see your AUT in the "Running AUTs" view you probably missed this. If, on the other hand, the AUT is listed you might have found a bug.
- Achim
Re: Observation button and mapping buttons disabled [message #1066259 is a reply to message #1066038] |
Mon, 01 July 2013 18:06 |
Jiajian Lei Messages: 36 Registered: June 2013 |
Member |
I have added the org.eclipse.jubula.rc.rcp_2.1.0.201306171048.jar to the plugin folder in my RCP directory and tried to add 'org.eclipse.jubula.rc.rcp' or 'org.eclipse.jubula.rc.rcp_2.1.0.201306171048' in config.ini. It's still no t working though - the Observation button and mapping buttons disabled and nothing is shown in Running AUT windows.
Screenshot is attached.
[Updated on: Mon, 01 July 2013 18:27] Report message to a moderator
Re: Observation button and mapping buttons disabled [message #1066287 is a reply to message #1066279] |
Mon, 01 July 2013 22:20 |
Member |
I just tried generated the Mail Template with Indigo RCP, and it's still not working.
I followed through every instruction on the tutorial though. To add the RCP accessor to my AUT, I just extract rcp-support.zip and copy the jar file (org.eclipse.jubula.rc.rcp_2.1.0.201306171048.jar) to the plugins folder in my AUT product directory, right? Then I add 'org.eclipse.jubula.rc.rcp' to the end of 'osgi.bundles=' in config.ini under 'jubula_destination_product\mail2\configuration'
If I open my AUT through Jubula and go to about/installations details, it shows one jubula plugin, 'Jubula Remote Control - RCP Common' for plug-in name.
How come there is nothing shown in the Running AUT window and the progress bar for 'starting AUT with AUT MAIL2 Test' just hangs?
[Updated on: Mon, 01 July 2013 23:17] Report message to a moderator
Re: Observation button and mapping buttons disabled [message #1066446 is a reply to message #1066355] |
Tue, 02 July 2013 17:00 |
Member |
Thanks for the response. I tried adding 'org.eclipse.update.configurator#3:start,org.eclipse.jubula.rc.rcp' to the end of osgi.bundle in config.ini, it still didn't fix the issue.(I replaced @ with # since it was being recognized as an email format)
Also, when I copied the content within rcp-support.zip into my AUT plugins folder, I noticed there was only one bundle file, which is the org.eclipse.jubula.rc.rcp_2.1.0.201306171048.jar. That was the only bundle file that I added to my AUT plugins folder.
[Updated on: Tue, 02 July 2013 17:08] Report message to a moderator
FUDForum. Page generated in 0.03948 seconds
