[CDO] [message #1065982] |
Fri, 28 June 2013 12:22 |
I have two RCP applications accessing a model instance on a CDO server.
Updates flow in real-time both ways as each user saves his/her model and
the UI is dynamically updated. Pretty cool.
In one scenario a series of integer values are updated on one side (lane
numbers) and when delta notifications are sent to the other user, I get
the stack trace pasted below.
Never had this error before I migrated from base EMF to CDO and tried
this multi-user access to the model.
Here's the snippet from NotificationImpl.java where the error occurs:
public int getNewIntValue()
if (primitiveType != PRIMITIVE_TYPE_INT) throw new
IllegalStateException();
return (int)newSimplePrimitiveValue;
The debugger shows that the value of 'primitiveType' is -1, rather than
the expected value of 5 (PRIMITIVE_TYPE_INT).
Here's the stack trace:
[ERROR] IllegalStateException
java.lang.IllegalStateException
org.eclipse.emf.common.notify.impl.NotificationImpl.getNewIntValue(NotificationImpl.java:943)
com.humanfactor.rw.model.ecore.regatta.provider.validation.RegattaValidationAdapterFactory$22.getAffectedObjects(RegattaValidationAdapterFactory.java:1193)
com.humanfactor.emf.validation.adapter.ModelValidationAdapter.notifyChanged(ModelValidationAdapter.java:367)
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
org.eclipse.emf.common.notify.impl.NotificationChainImpl.dispatch(NotificationChainImpl.java:98)
org.eclipse.emf.common.notify.impl.NotificationChainImpl.dispatch(NotificationChainImpl.java:86)
org.eclipse.emf.internal.cdo.view.CDOViewImpl.sendDeltaNotifications(CDOViewImpl.java:949)
org.eclipse.emf.internal.cdo.view.CDOViewImpl.doInvalidate(CDOViewImpl.java:833)
org.eclipse.emf.internal.cdo.view.CDOViewImpl$InvalidationRunnable.run(CDOViewImpl.java:1554)
at org.eclipse.net4j.util.concurrent.QueueRunner.work(QueueRunner.java:26)
at org.eclipse.net4j.util.concurrent.QueueRunner.work(QueueRunner.java:1)
org.eclipse.net4j.util.concurrent.QueueWorker.doWork(QueueWorker.java:86)
at org.eclipse.net4j.util.concurrent.QueueWorker.work(QueueWorker.java:77)
org.eclipse.net4j.util.concurrent.Worker$WorkerThread.run(Worker.java:206)
11:55:23 DEBUG (BasicCDOViewContextListener.java:31) - Received event
CDOViewInvalidationEvent:
{RacingCrew@OID8974=CDORevisionDelta[RacingCrew@OID8974:0v3 -->
[CDOFeatureDelta[laneNumber, SET, value=4, oldValue=4]]],
RacingCrew@OID8961=CDORevisionDelta[RacingCrew@OID8961:0v3 -->
[CDOFeatureDelta[laneNumber, SET, value=5, oldValue=5]]],
RacingCrew@OID8968=CDORevisionDelta[RacingCrew@OID8968:0v3 -->
[CDOFeatureDelta[laneNumber, SET, value=2, oldValue=3]]],
com.humanfactor.rw.model.ecore.regatta.impl.RaceImpl (raceStatus:
preliminary, raceNumber: 2a)=CDORevisionDelta[Race@OID8959:0v3 -->
[CDOFeatureDelta[racingCrew, LIST, list=[CDOFeatureDelta[racingCrew,
MOVE, from=0, to=2, value=OID8971]]]]],
RacingCrew@OID8971=CDORevisionDelta[RacingCrew@OID8971:0v3 -->
[CDOFeatureDelta[laneNumber, SET, value=3, oldValue=1]]],
RacingCrew@OID8965=CDORevisionDelta[RacingCrew@OID8965:0v3 -->
[CDOFeatureDelta[laneNumber, SET, value=1, oldValue=2]]],
RacingCrew@OID8979=CDORevisionDelta[RacingCrew@OID8979:0v4 -->
[CDOFeatureDelta[laneNumber, SET, value=6, oldValue=UNSPECIFIED]]]}
11:55:23 DEBUG (CDOViewContextListener.java:43) - Refreshing viewer
FUDForum. Page generated in 0.02602 seconds
