Home » Eclipse Projects » Eclipse 4 » Fragment/Perspective/Placeholder problem
Fragment/Perspective/Placeholder problem [message #1065848] Thu, 27 June 2013 14:49 Go to next message
Hello all. I have three projects in my workspace:
- MainApp (contains Application.e4xmi with a TrimmedWindow [id="MainAppWindow"] and PerspectiveStack [id="MainPerspectiveStack"])
- PartFragment (contributes a Part [id="MySharedPartFromFragment"] to the Shared Elements of MainAppWindow)
- PerspectiveFragment (imports MySharedPartFromFragment and contributes a Perspective [id="SnippetPerspectiveFromFragment"] to the Snippets section of the MainApp with a PlaceHolder that references MySharedPartFromFragment)
In MainApp I have a processor that copies all Perspective Snippets into the MainPerspectiveStack (via modelService.cloneSnippet).
After MainApp starts SnippetPerspectiveFromFragment does exist in the model as a child of MainPerspectiveStack. The problem I'm having is that when I switch to the SnippetPerspectiveFromFragment perspective I see a blank MPart where MySharedPartFromFragment should be.
index.php/fa/15396/0/
Here's the xmi of SnippetPerspectiveFromFragment:
      <children xsi:type="advanced:Perspective" xmi:id="_eQH4lN9WEeKrsvusXvNxVg" elementId="SnippetPerspectiveFromFragment" contributorURI="platform:/plugin/PerspectiveFragment" label="SnippetPerspectiveFromFragment">
        <tags>PerspectiveTemplate</tags>
        <children xsi:type="basic:PartSashContainer" xmi:id="_eQH4ld9WEeKrsvusXvNxVg" elementId="perspectivefragment.partsashcontainer.0" contributorURI="platform:/plugin/PerspectiveFragment">
          <children xsi:type="basic:PartStack" xmi:id="_eQH4lt9WEeKrsvusXvNxVg" elementId="perspectivefragment.partstack.0" contributorURI="platform:/plugin/PerspectiveFragment" containerData="10000" selectedElement="_eQH4l99WEeKrsvusXvNxVg">
            <children xsi:type="advanced:Placeholder" xmi:id="_eQH4l99WEeKrsvusXvNxVg" elementId="perspectivefragment.placeholder.0" contributorURI="platform:/plugin/PerspectiveFragment">
              <ref xsi:type="basic:Part" href="platform:/plugin/PerspectiveFragment/PerspectiveFragment.e4xmi#_7qsI4N9FEeKti89ripk2GQ"/>
            </children>
          </children>
        </children>
      </children>
And what it looks like in the live editor:
index.php/fa/15397/0/
Any help is appreciated. I have attached the three projects.
  • Attachment: MainApp.PNG
    (Size: 19.68KB, Downloaded 2459 times)
  • Attachment: appModel1.PNG
    (Size: 5.26KB, Downloaded 2434 times)
  • Attachment: MainApp.zip
    (Size: 30.06KB, Downloaded 256 times)
Re: Fragment/Perspective/Placeholder problem [message #1066567 is a reply to message #1065848] Wed, 03 July 2013 04:11 Go to previous messageGo to next message
Probably the issue is connected to the "empty" perspective in the "MainApp/Application.e4xmi/Application/Windows/Trimmed Window/Controls/Perspective Stack" perspective stack. After removing it from model it works for me. I attach the fixed version of the MainApp project
Daniel
Re: Fragment/Perspective/Placeholder problem [message #1067377 is a reply to message #1066567] Mon, 08 July 2013 09:14 Go to previous messageGo to next message
Thanks for taking the time to look at this, Daniel.
I downloaded your modified MainApp, but I still see the blank MPart after setting the SelectedElement of MainPerspectiveStack to SnippetPerspectiveFromFragment:
index.php/fa/15505/0/
I also see an exception in the console when switching to SnippetPerspectiveFromFragment:
!ENTRY org.eclipse.equinox.event 4 0 2013-07-08 08:25:11.520
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/SET] to handler org.eclipse.e4.ui.services.internal.events.UIEventHandler@4c56666d
!STACK 0
java.lang.IllegalArgumentException:
	at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
	at org.eclipse.core.runtime.Assert.isLegal(Assert.java:47)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElementsRecursive(ModelServiceImpl.java:286)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findPerspectiveElements(ModelServiceImpl.java:385)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findPlaceholderFor(ModelServiceImpl.java:591)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:551)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:543)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.switchPerspective(PartServiceImpl.java:504)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:124)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:66)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4688)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:205)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
	at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.eSet(PerspectiveStackImpl.java:198)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1071)
	at org.eclipse.emf.edit.command.SetCommand.doExecute(SetCommand.java:722)
	at org.eclipse.emf.edit.command.AbstractOverrideableCommand.execute(AbstractOverrideableCommand.java:125)
	at org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:78)
	at org.eclipse.emf.databinding.edit.internal.EMFEditValueProperty.doSetValue(EMFEditValueProperty.java:45)
	at org.eclipse.core.databinding.property.value.ValueProperty.setValue(ValueProperty.java:86)
	at org.eclipse.core.internal.databinding.property.value.SimplePropertyObservableValue.doSetValue(SimplePropertyObservableValue.java:108)
	at org.eclipse.core.databinding.observable.value.AbstractObservableValue.setValue(AbstractObservableValue.java:60)
	at org.eclipse.core.internal.databinding.observable.masterdetail.DetailObservableValue.doSetValue(DetailObservableValue.java:138)
	at org.eclipse.core.databinding.observable.value.DecoratingObservableValue.setValue(DecoratingObservableValue.java:105)
	at org.eclipse.core.databinding.UpdateValueStrategy.doSet(UpdateValueStrategy.java:500)
	at org.eclipse.core.databinding.ValueBinding$3$1.run(ValueBinding.java:199)
	at org.eclipse.core.databinding.observable.Realm$1.run(Realm.java:147)
	at org.eclipse.core.databinding.observable.Realm.safeRun(Realm.java:151)
	at org.eclipse.core.databinding.observable.Realm.exec(Realm.java:169)
	at org.eclipse.core.databinding.ValueBinding$3.run(ValueBinding.java:190)
	at org.eclipse.core.databinding.ValueBinding.doUpdate(ValueBinding.java:154)
	at org.eclipse.core.databinding.ValueBinding.access$4(ValueBinding.java:143)
	at org.eclipse.core.databinding.ValueBinding$1.handleValueChange(ValueBinding.java:46)
	at org.eclipse.core.databinding.observable.value.ValueChangeEvent.dispatch(ValueChangeEvent.java:71)
	at org.eclipse.core.databinding.observable.ChangeManager.fireEvent(ChangeManager.java:127)
	at org.eclipse.core.databinding.observable.value.DecoratingObservableValue.fireValueChange(DecoratingObservableValue.java:57)
	at org.eclipse.core.databinding.observable.value.DecoratingObservableValue.handleValueChange(DecoratingObservableValue.java:95)
	at org.eclipse.core.databinding.observable.value.DecoratingObservableValue$1.handleValueChange(DecoratingObservableValue.java:69)
	at org.eclipse.core.databinding.observable.value.AbstractObservableValue.fireValueChange(AbstractObservableValue.java:76)
	at org.eclipse.core.internal.databinding.property.value.SimplePropertyObservableValue.notifyIfChanged(SimplePropertyObservableValue.java:124)
	at org.eclipse.core.internal.databinding.property.value.SimplePropertyObservableValue.access$2(SimplePropertyObservableValue.java:116)
	at org.eclipse.core.internal.databinding.property.value.SimplePropertyObservableValue$1$1.run(SimplePropertyObservableValue.java:70)
	at org.eclipse.core.internal.databinding.property.value.SimplePropertyObservableValue$1.handleEvent(SimplePropertyObservableValue.java:67)
	at org.eclipse.core.databinding.property.NativePropertyListener.fireChange(NativePropertyListener.java:68)
	at org.eclipse.jface.internal.databinding.viewers.SelectionChangedListener.selectionChanged(SelectionChangedListener.java:37)
	at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:164)
	at org.eclipse.jface.util.SafeRunnable$1.run(SafeRunnable.java:128)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:162)
	at org.eclipse.jface.viewers.StructuredViewer.updateSelection(StructuredViewer.java:2188)
	at org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1211)
	at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1241)
	at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:239)
	at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:233)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:403)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
	at org.eclipse.e4.tools.emf.liveeditor.OpenLiveDialogHandler.run(OpenLiveDialogHandler.java:60)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:285)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:504)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:555)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:376)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.access$0(KeyBindingDispatcher.java:322)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:84)
	at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1056)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1081)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
	at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1108)
	at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1104)
	at org.eclipse.swt.widgets.Widget.wmSysKeyDown(Widget.java:2576)
	at org.eclipse.swt.widgets.Control.WM_SYSKEYDOWN(Control.java:5385)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4690)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4977)
	at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
	at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2549)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:331)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:162)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
This exception seems to be caused by PartServiceImpl.switchPerspective(...) because it is calling ModelServiceImpl.bringToTop(MPart[elementID="MySharedPartFromFragment"]). Since MySharedPartFromFragment's eContainer is a ModelFragmentsImpl we get a null MWindow from the getTopLevelWindowFor(MPart[elementID="MySharedPartFromFragment"]) call from bringToTop(...). I'm guessing this is a bug, but maybe it is by design???
  • Attachment: MainApp1.png
    (Size: 18.05KB, Downloaded 2233 times)
Re: Fragment/Perspective/Placeholder problem [message #1067780 is a reply to message #1067377] Wed, 10 July 2013 10:41 Go to previous messageGo to next message
Do you use the latest Kepler release or other version? I'am asking since I have double checked it with Kepler and it works for me. So after removing the empty perspective from the model (see the 'snapshot2.png' attachment) and running the application I get the valid part (see the 'snapshot.png' attachment)
Daniel
  • Attachment: snapshot.png
    (Size: 35.80KB, Downloaded 303 times)
  • Attachment: snapshot2.png
    (Size: 38.94KB, Downloaded 331 times)
Re: Fragment/Perspective/Placeholder problem [message #1067786 is a reply to message #1065848] Wed, 10 July 2013 10:55 Go to previous messageGo to next message
Thanks for the response, Daniel. I am using Kepler Release build id 20130614-0229. I also see the problem in Juno SR2.
Your attached screenshot (snapshot.png) is exactly what I see when I first run the application. I've been seeing that exact screenshot all along- even with a non-empty Perspective stack (as attached in my first post). The issue happens when I run the application, open the live editor, and switch the Selected Element of MainPerspectiveStack to the SnippetPerspectiveFromFragment Perspective.
This screenshot is the initial state (same as yours):
index.php/fa/15557/0/
This screenshot is the bad state after I switch perspectives to SnippetPerspectiveFromFragment:
index.php/fa/15558/0/
Re: Fragment/Perspective/Placeholder problem [message #1097342 is a reply to message #1067786] Thu, 29 August 2013 11:21 Go to previous messageGo to next message
Hi Smith,
How about the status of this problem?
I have the same problem and googled your post. My result is the same as yours. It looks like the DI is not working. But no any further clue.
Seymour
Re: Fragment/Perspective/Placeholder problem [message #1097413 is a reply to message #1097342] Thu, 29 August 2013 13:28 Go to previous messageGo to next message
seymour yee wrote on Thu, 29 August 2013 11:21
Hi Smith,
Seymour
Nope, no solution as of yet. As a workaround I just removed all my Placeholders from the Perspective defined in a Snippet. I still don't understand why it isn't working correctly. If you figure it out please let me know!
Re: Fragment/Perspective/Placeholder problem [message #1102394 is a reply to message #1067786] Thu, 05 September 2013 14:20 Go to previous message
It sounds like there is a potential issue with the live model editor. Have you tried these steps with a different application (say the IDE)? (Outcome?)
JD
Previous Topic:Compatibility with JSR-107 caching annotations?
Next Topic:e4 application Compilation impossible with tycho
Current Time: Fri Nov 07 19:30:03 EST 2025
Powered by FUDForum. Page generated in 0.07327 seconds
